I am using the built in server.
I have set the band to USA.
In this case I am trying ABP mode. Sill no luck.
I get an error 96 or something like that.
Absolutely nothing shows up in the kernel log
OK Work Mode: LoRaWAN
Region: US915
MulticastEnable: false
DutycycleEnable: false
Send_repeat_cnt: 0
Join_mode: ABP
DevAddr: 00000001
AppsKey: E657A03C127576324F701ABC802186C4
NwksKey: 045FF6E1AE7D308DA611EC39905206F9
Class: A
Joined Network:true
IsConfirm: confirm
AdrEnable: true
EnableRepeaterSupport: false
RX2_CHANNEL_FREQUENCY: 923300000, RX2_CHANNEL_DR:8
RX_WINDOW_DURATION: 3000ms
RECEIVE_DELAY_1: 1000ms
RECEIVE_DELAY_2: 2000ms
JOIN_ACCEPT_DELAY_1: 5000ms
JOIN_ACCEPT_DELAY_2: 6000ms
Current Datarate: 3
Primeval Datarate: 3
ChannelsTxPower: 0
UpLinkCounter: 1
DownLinkCounter: 0
Class: A
Joined Network:true
IsConfirm: confirm
AdrEnable: true
Current Datarate: 3
ChannelsTxPower: 0
UpLinkCounter: 2
DownLinkCounter: 0
Thu Jul 2 08:12:39 2020 kern.notice kernel: [ 0.000000] Linux version 3.18.45 ([email protected]) (gcc version 4.8.3 (OpenWrt/Linaro GCC 4.8-2014.04 r158) ) #1 Wed Jul 1 09:40:54 CST 2020
Thu Jul 2 08:12:39 2020 kern.info kernel: [ 0.000000] Board has DDR2
Thu Jul 2 08:12:39 2020 kern.info kernel: [ 0.000000] Analog PMU set to hw control
Thu Jul 2 08:12:39 2020 kern.info kernel: [ 0.000000] Digital PMU set to hw control
Thu Jul 2 08:12:39 2020 kern.info kernel: [ 0.000000] SoC Type: MediaTek MT7628AN ver:1 eco:2
Thu Jul 2 08:12:39 2020 kern.info kernel: [ 0.000000] bootconsole [early0] enabled
Thu Jul 2 08:12:39 2020 kern.info kernel: [ 0.000000] CPU0 revision is: 00019655 (MIPS 24KEc)
Thu Jul 2 08:12:39 2020 kern.info kernel: [ 0.000000] MIPS: machine is Mediatek MT7628AN evaluation board
Thu Jul 2 08:12:39 2020 kern.info kernel: [ 0.000000] Determined physical RAM map:
Thu Jul 2 08:12:39 2020 kern.info kernel: [ 0.000000] memory: 08000000 @ 00000000 (usable)
Thu Jul 2 08:12:39 2020 kern.info kernel: [ 0.000000] Initrd not found or empty - disabling initrd
Thu Jul 2 08:12:39 2020 kern.warn kernel: [ 0.000000] Zone ranges:
Thu Jul 2 08:12:39 2020 kern.warn kernel: [ 0.000000] Normal [mem 0x00000000-0x07ffffff]
Thu Jul 2 08:12:39 2020 kern.warn kernel: [ 0.000000] Movable zone start for each node
Thu Jul 2 08:12:39 2020 kern.warn kernel: [ 0.000000] Early memory node ranges
Thu Jul 2 08:12:39 2020 kern.warn kernel: [ 0.000000] node 0: [mem 0x00000000-0x07ffffff]
Thu Jul 2 08:12:39 2020 kern.info kernel: [ 0.000000] Initmem setup node 0 [mem 0x00000000-0x07ffffff]
Thu Jul 2 08:12:39 2020 kern.debug kernel: [ 0.000000] On node 0 totalpages: 32768
Thu Jul 2 08:12:39 2020 kern.debug kernel: [ 0.000000] free_area_init_node: node 0, pgdat 80325d60, node_mem_map 81000000
Thu Jul 2 08:12:39 2020 kern.debug kernel: [ 0.000000] Normal zone: 256 pages used for memmap
Thu Jul 2 08:12:39 2020 kern.debug kernel: [ 0.000000] Normal zone: 0 pages reserved
Thu Jul 2 08:12:39 2020 kern.debug kernel: [ 0.000000] Normal zone: 32768 pages, LIFO batch:7
Thu Jul 2 08:12:39 2020 kern.warn kernel: [ 0.000000] Primary instruction cache 64kB, VIPT, 4-way, linesize 32 bytes.
Thu Jul 2 08:12:39 2020 kern.warn kernel: [ 0.000000] Primary data cache 32kB, 4-way, PIPT, no aliases, linesize 32 bytes
Thu Jul 2 08:12:39 2020 kern.debug kernel: [ 0.000000] pcpu-alloc: s0 r0 d32768 u32768 alloc=1*32768
Thu Jul 2 08:12:39 2020 kern.debug kernel: [ 0.000000] pcpu-alloc: [0] 0
Thu Jul 2 08:12:39 2020 kern.warn kernel: [ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 32512
Thu Jul 2 08:12:39 2020 kern.notice kernel: [ 0.000000] Kernel command line: console=ttyS0,57600 rootfstype=squashfs,jffs2
Thu Jul 2 08:12:39 2020 kern.info kernel: [ 0.000000] PID hash table entries: 512 (order: -1, 2048 bytes)
Thu Jul 2 08:12:39 2020 kern.info kernel: [ 0.000000] Dentry cache hash table entries: 16384 (order: 4, 65536 bytes)
Thu Jul 2 08:12:39 2020 kern.info kernel: [ 0.000000] Inode-cache hash table entries: 8192 (order: 3, 32768 bytes)
Thu Jul 2 08:12:39 2020 kern.info kernel: [ 0.000000] Writing ErrCtl register=000705a3
Thu Jul 2 08:12:39 2020 kern.info kernel: [ 0.000000] Readback ErrCtl register=000705a3
Thu Jul 2 08:12:39 2020 kern.warn kernel: [ 0.000000] Memory: 126144K/131072K available (2646K kernel code, 130K rwdata, 540K rodata, 192K init, 188K bss, 4928K reserved)
Thu Jul 2 08:12:39 2020 kern.info kernel: [ 0.000000] SLUB: HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
Thu Jul 2 08:12:39 2020 kern.info kernel: [ 0.000000] NR_IRQS:256
Thu Jul 2 08:12:39 2020 kern.info kernel: [ 0.000000] intc: using register map from devicetree
Thu Jul 2 08:12:39 2020 kern.info kernel: [ 0.000000] CPU Clock: 580MHz
Thu Jul 2 08:12:39 2020 kern.crit kernel: [ 0.000000] clocksource_of_init: no matching clocksources found
Thu Jul 2 08:12:39 2020 kern.info kernel: [ 0.050000] Calibrating delay loop… 385.84 BogoMIPS (lpj=1929216)
Thu Jul 2 08:12:39 2020 kern.info kernel: [ 0.060000] pid_max: default: 32768 minimum: 301
Thu Jul 2 08:12:39 2020 kern.info kernel: [ 0.060000] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
Thu Jul 2 08:12:39 2020 kern.info kernel: [ 0.070000] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
Thu Jul 2 08:12:39 2020 kern.info kernel: [ 0.080000] pinctrl core: initialized pinctrl subsystem
Thu Jul 2 08:12:39 2020 kern.info kernel: [ 0.090000] NET: Registered protocol family 16
Thu Jul 2 08:12:39 2020 kern.debug kernel: [ 0.100000] rt2880-pinmux pinctrl: try to register 47 pins …
Thu Jul 2 08:12:39 2020 kern.debug kernel: [ 0.100000] pinctrl core: registered pin 0 (io0) on rt2880-pinmux
Thu Jul 2 08:12:39 2020 kern.debug kernel: [ 0.100000] pinctrl core: registered pin 1 (io1) on rt2880-pinmux
Thu Jul 2 08:12:39 2020 kern.debug kernel: [ 0.100000] pinctrl core: registered pin 2 (io2) on rt2880-pinmux
Thu Jul 2 08:12:39 2020 kern.debug kernel: [ 0.100000] pinctrl core: registered pin 3 (io3) on rt2880-pinmux
Thu Jul 2 08:12:39 2020 kern.debug kernel: [ 0.100000] pinctrl core: registered pin 4 (io4) on rt2880-pinmux
Thu Jul 2 08:12:39 2020 kern.debug kernel: [ 0.100000] pinctrl core: registered pin 5 (io5) on rt2880-pinmux
Thu Jul 2 08:12:39 2020 kern.debug kernel: [ 0.100000] pinctrl core: registered pin 6 (io6) on rt2880-pinmux
Thu Jul 2 08:12:39 2020 kern.debug kernel: [ 0.100000] pinctrl core: registered pin 7 (io7) on rt2880-pinmux
Thu Jul 2 08:12:39 2020 kern.debug kernel: [ 0.100000] pinctrl core: registered pin 8 (io8) on rt2880-pinmux
Thu Jul 2 08:12:39 2020 kern.debug kernel: [ 0.100000] pinctrl core: registered pin 9 (io9) on rt2880-pinmux
Thu Jul 2 08:12:39 2020 kern.debug kernel: [ 0.100000] pinctrl core: registered pin 10 (io10) on rt2880-pinmux
Thu Jul 2 08:12:39 2020 kern.debug kernel: [ 0.100000] pinctrl core: registered pin 11 (io11) on rt2880-pinmux
Thu Jul 2 08:12:39 2020 kern.debug kernel: [ 0.100000] pinctrl core: registered pin 12 (io12) on rt2880-pinmux
Thu Jul 2 08:12:39 2020 kern.debug kernel: [ 0.100000] pinctrl core: registered pin 13 (io13) on rt2880-pinmux
Thu Jul 2 08:12:39 2020 kern.debug kernel: [ 0.100000] pinctrl core: registered pin 14 (io14) on rt2880-pinmux
Thu Jul 2 08:12:39 2020 kern.debug kernel: [ 0.100000] pinctrl core: registered pin 15 (io15) on rt2880-pinmux
Thu Jul 2 08:12:39 2020 kern.debug kernel: [ 0.100000] pinctrl core: registered pin 16 (io16) on rt2880-pinmux
Thu Jul 2 08:12:39 2020 kern.debug kernel: [ 0.100000] pinctrl core: registered pin 17 (io17) on rt2880-pinmux
Thu Jul 2 08:12:39 2020 kern.debug kernel: [ 0.100000] pinctrl core: registered pin 18 (io18) on rt2880-pinmux
Thu Jul 2 08:12:39 2020 kern.debug kernel: [ 0.100000] pinctrl core: registered pin 19 (io19) on rt2880-pinmux
Thu Jul 2 08:12:39 2020 kern.debug kernel: [ 0.100000] pinctrl core: registered pin 20 (io20) on rt2880-pinmux
Thu Jul 2 08:12:39 2020 kern.debug kernel: [ 0.100000] pinctrl core: registered pin 21 (io21) on rt2880-pinmux
Thu Jul 2 08:12:39 2020 kern.debug kernel: [ 0.100000] pinctrl core: registered pin 22 (io22) on rt2880-pinmux
Thu Jul 2 08:12:39 2020 kern.debug kernel: [ 0.100000] pinctrl core: registered pin 23 (io23) on rt2880-pinmux
Thu Jul 2 08:12:39 2020 kern.debug kernel: [ 0.100000] pinctrl core: registered pin 24 (io24) on rt2880-pinmux
Thu Jul 2 08:12:39 2020 kern.debug kernel: [ 0.100000] pinctrl core: registered pin 25 (io25) on rt2880-pinmux
Thu Jul 2 08:12:39 2020 kern.debug kernel: [ 0.100000] pinctrl core: registered pin 26 (io26) on rt2880-pinmux
Thu Jul 2 08:12:39 2020 kern.debug kernel: [ 0.100000] pinctrl core: registered pin 27 (io27) on rt2880-pinmux
Thu Jul 2 08:12:39 2020 kern.debug kernel: [ 0.100000] pinctrl core: registered pin 28 (io28) on rt2880-pinmux
Thu Jul 2 08:12:39 2020 kern.debug kernel: [ 0.100000] pinctrl core: registered pin 29 (io29) on rt2880-pinmux
Thu Jul 2 08:12:39 2020 kern.debug kernel: [ 0.100000] pinctrl core: registered pin 30 (io30) on rt2880-pinmux
Thu Jul 2 08:12:39 2020 kern.debug kernel: [ 0.100000] pinctrl core: registered pin 31 (io31) on rt2880-pinmux
Thu Jul 2 08:12:39 2020 kern.debug kernel: [ 0.100000] pinctrl core: registered pin 32 (io32) on rt2880-pinmux
Thu Jul 2 08:12:39 2020 kern.debug kernel: [ 0.100000] pinctrl core: registered pin 33 (io33) on rt2880-pinmux
Thu Jul 2 08:12:39 2020 kern.debug kernel: [ 0.100000] pinctrl core: registered pin 34 (io34) on rt2880-pinmux
Thu Jul 2 08:12:39 2020 kern.debug kernel: [ 0.100000] pinctrl core: registered pin 35 (io35) on rt2880-pinmux
Thu Jul 2 08:12:39 2020 kern.debug kernel: [ 0.100000] pinctrl core: registered pin 36 (io36) on rt2880-pinmux
Thu Jul 2 08:12:39 2020 kern.debug kernel: [ 0.100000] pinctrl core: registered pin 37 (io37) on rt2880-pinmux
Thu Jul 2 08:12:39 2020 kern.debug kernel: [ 0.100000] pinctrl core: registered pin 38 (io38) on rt2880-pinmux
Thu Jul 2 08:12:39 2020 kern.debug kernel: [ 0.100000] pinctrl core: registered pin 39 (io39) on rt2880-pinmux
Thu Jul 2 08:12:39 2020 kern.debug kernel: [ 0.100000] pinctrl core: registered pin 40 (io40) on rt2880-pinmux
Thu Jul 2 08:12:39 2020 kern.debug kernel: [ 0.100000] pinctrl core: registered pin 41 (io41) on rt2880-pinmux
Thu Jul 2 08:12:39 2020 kern.debug kernel: [ 0.100000] pinctrl core: registered pin 42 (io42) on rt2880-pinmux
Thu Jul 2 08:12:39 2020 kern.debug kernel: [ 0.100000] pinctrl core: registered pin 43 (io43) on rt2880-pinmux
Thu Jul 2 08:12:39 2020 kern.debug kernel: [ 0.100000] pinctrl core: registered pin 44 (io44) on rt2880-pinmux
Thu Jul 2 08:12:39 2020 kern.debug kernel: [ 0.100000] pinctrl core: registered pin 45 (io45) on rt2880-pinmux
Thu Jul 2 08:12:39 2020 kern.debug kernel: [ 0.100000] pinctrl core: registered pin 46 (io46) on rt2880-pinmux
Thu Jul 2 08:12:39 2020 kern.debug kernel: [ 0.100000] pinctrl core: add 9 pinmux maps
Thu Jul 2 08:12:39 2020 kern.debug kernel: [ 0.100000] rt2880-pinmux pinctrl: found group selector 4 for i2c
Thu Jul 2 08:12:39 2020 kern.debug kernel: [ 0.100000] rt2880-pinmux pinctrl: found group selector 11 for i2s
Thu Jul 2 08:12:39 2020 kern.debug kernel: [ 0.100000] rt2880-pinmux pinctrl: found group selector 13 for spis
Thu Jul 2 08:12:39 2020 kern.debug kernel: [ 0.100000] rt2880-pinmux pinctrl: found group selector 17 for p1led_an
Thu Jul 2 08:12:39 2020 kern.debug kernel: [ 0.100000] rt2880-pinmux pinctrl: found group selector 18 for p2led_an
Thu Jul 2 08:12:39 2020 kern.debug kernel: [ 0.100000] rt2880-pinmux pinctrl: found group selector 19 for p3led_an
Thu Jul 2 08:12:39 2020 kern.debug kernel: [ 0.100000] rt2880-pinmux pinctrl: found group selector 20 for p4led_an
Thu Jul 2 08:12:39 2020 kern.debug kernel: [ 0.100000] rt2880-pinmux pinctrl: found group selector 7 for wdt
Thu Jul 2 08:12:39 2020 kern.debug kernel: [ 0.100000] rt2880-pinmux pinctrl: found group selector 15 for wled_an
Thu Jul 2 08:12:39 2020 kern.debug kernel: [ 0.100000] rt2880-pinmux pinctrl: request pin 4 (io4) for pinctrl
Thu Jul 2 08:12:39 2020 kern.debug kernel: [ 0.100000] rt2880-pinmux pinctrl: request pin 5 (io5) for pinctrl
Thu Jul 2 08:12:39 2020 kern.debug kernel: [ 0.100000] rt2880-pinmux pinctrl: request pin 0 (io0) for pinctrl
Thu Jul 2 08:12:39 2020 kern.debug kernel: [ 0.100000] rt2880-pinmux pinctrl: request pin 1 (io1) for pinctrl
Thu Jul 2 08:12:39 2020 kern.debug kernel: [ 0.100000] rt2880-pinmux pinctrl: request pin 2 (io2) for pinctrl
Thu Jul 2 08:12:39 2020 kern.debug kernel: [ 0.100000] rt2880-pinmux pinctrl: request pin 3 (io3) for pinctrl
Thu Jul 2 08:12:39 2020 kern.debug kernel: [ 0.100000] rt2880-pinmux pinctrl: request pin 14 (io14) for pinctrl
Thu Jul 2 08:12:39 2020 kern.debug kernel: [ 0.100000] rt2880-pinmux pinctrl: request pin 15 (io15) for pinctrl
Thu Jul 2 08:12:39 2020 kern.debug kernel: [ 0.100000] rt2880-pinmux pinctrl: request pin 16 (io16) for pinctrl
Thu Jul 2 08:12:39 2020 kern.debug kernel: [ 0.100000] rt2880-pinmux pinctrl: request pin 17 (io17) for pinctrl
Thu Jul 2 08:12:39 2020 kern.debug kernel: [ 0.100000] rt2880-pinmux pinctrl: request pin 42 (io42) for pinctrl
Thu Jul 2 08:12:39 2020 kern.debug kernel: [ 0.100000] rt2880-pinmux pinctrl: request pin 41 (io41) for pinctrl
Thu Jul 2 08:12:39 2020 kern.debug kernel: [ 0.100000] rt2880-pinmux pinctrl: request pin 40 (io40) for pinctrl
Thu Jul 2 08:12:39 2020 kern.debug kernel: [ 0.100000] rt2880-pinmux pinctrl: request pin 39 (io39) for pinctrl
Thu Jul 2 08:12:39 2020 kern.debug kernel: [ 0.100000] rt2880-pinmux pinctrl: request pin 38 (io38) for pinctrl
Thu Jul 2 08:12:39 2020 kern.debug kernel: [ 0.100000] rt2880-pinmux pinctrl: request pin 44 (io44) for pinctrl
Thu Jul 2 08:12:39 2020 kern.debug kernel: [ 0.100000] rt2880-pinmux pinctrl: failed to lookup the sleep state
Thu Jul 2 08:12:39 2020 kern.info kernel: [ 0.120000] mt7621_gpio 10000600.gpio: registering 32 gpios
Thu Jul 2 08:12:39 2020 kern.info kernel: [ 0.130000] mt7621_gpio 10000600.gpio: registering 32 gpios
Thu Jul 2 08:12:39 2020 kern.info kernel: [ 0.140000] mt7621_gpio 10000600.gpio: registering 32 gpios
Thu Jul 2 08:12:39 2020 kern.info kernel: [ 0.150000] Advanced Linux Sound Architecture Driver Initialized.
Thu Jul 2 08:12:39 2020 kern.info kernel: [ 0.160000] Switched to clocksource MIPS
Thu Jul 2 08:12:39 2020 kern.info kernel: [ 0.160000] NET: Registered protocol family 2
Thu Jul 2 08:12:39 2020 kern.info kernel: [ 0.170000] TCP established hash table entries: 1024 (order: 0, 4096 bytes)
Thu Jul 2 08:12:39 2020 kern.info kernel: [ 0.190000] TCP bind hash table entries: 1024 (order: 0, 4096 bytes)
Thu Jul 2 08:12:39 2020 kern.info kernel: [ 0.200000] TCP: Hash tables configured (established 1024 bind 1024)
Thu Jul 2 08:12:39 2020 kern.info kernel: [ 0.210000] TCP: reno registered
Thu Jul 2 08:12:39 2020 kern.info kernel: [ 0.220000] UDP hash table entries: 256 (order: 0, 4096 bytes)
Thu Jul 2 08:12:39 2020 kern.info kernel: [ 0.230000] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
Thu Jul 2 08:12:39 2020 kern.info kernel: [ 0.240000] NET: Registered protocol family 1
Thu Jul 2 08:12:39 2020 kern.debug kernel: [ 0.250000] PCI: CLS 0 bytes, default 32
Thu Jul 2 08:12:39 2020 kern.debug kernel: [ 0.250000] alarmtimer alarmtimer: no of_node; not parsing pinctrl DT
Thu Jul 2 08:12:39 2020 kern.info kernel: [ 0.250000] futex hash table entries: 256 (order: -1, 3072 bytes)
Thu Jul 2 08:12:39 2020 kern.info kernel: [ 0.280000] squashfs: version 4.0 (2009/01/31) Phillip Lougher
Thu Jul 2 08:12:39 2020 kern.info kernel: [ 0.290000] jffs2: version 2.2 (NAND) (SUMMARY) (LZMA) (RTIME) (CMODE_PRIORITY) © 2001-2006 Red Hat, Inc.
Thu Jul 2 08:12:39 2020 kern.info kernel: [ 0.320000] msgmni has been set to 246
Thu Jul 2 08:12:39 2020 kern.info kernel: [ 0.320000] io scheduler noop registered
Thu Jul 2 08:12:39 2020 kern.info kernel: [ 0.330000] io scheduler deadline registered (default)
Thu Jul 2 08:12:39 2020 kern.info kernel: [ 0.340000] Serial: 8250/16550 driver, 3 ports, IRQ sharing disabled
Thu Jul 2 08:12:39 2020 kern.debug kernel: [ 0.360000] serial8250 serial8250: no of_node; not parsing pinctrl DT
Thu Jul 2 08:12:39 2020 kern.debug kernel: [ 0.360000] pinctrl core: add 1 pinmux maps
Thu Jul 2 08:12:39 2020 kern.debug kernel: [ 0.360000] rt2880-pinmux pinctrl: found group selector 10 for uart0
Thu Jul 2 08:12:39 2020 kern.debug kernel: [ 0.360000] rt2880-pinmux pinctrl: request pin 12 (io12) for 10000c00.uartlite
Thu Jul 2 08:12:39 2020 kern.debug kernel: [ 0.360000] rt2880-pinmux pinctrl: request pin 13 (io13) for 10000c00.uartlite
Thu Jul 2 08:12:39 2020 kern.info kernel: [ 0.360000] console [ttyS0] disabled
Thu Jul 2 08:12:39 2020 kern.info kernel: [ 0.360000] 10000c00.uartlite: ttyS0 at MMIO 0x10000c00 (irq = 28, base_baud = 2500000) is a 16550A
Thu Jul 2 08:12:39 2020 kern.info kernel: [ 0.380000] console [ttyS0] enabled
Thu Jul 2 08:12:39 2020 kern.info kernel: [ 0.390000] bootconsole [early0] disabled
Thu Jul 2 08:12:39 2020 kern.debug kernel: [ 0.410000] pinctrl core: add 1 pinmux maps
Thu Jul 2 08:12:39 2020 kern.debug kernel: [ 0.410000] rt2880-pinmux pinctrl: found group selector 3 for uart1
Thu Jul 2 08:12:39 2020 kern.debug kernel: [ 0.410000] rt2880-pinmux pinctrl: request pin 45 (io45) for 10000d00.uart1
Thu Jul 2 08:12:39 2020 kern.debug kernel: [ 0.410000] rt2880-pinmux pinctrl: request pin 46 (io46) for 10000d00.uart1
Thu Jul 2 08:12:39 2020 kern.info kernel: [ 0.410000] 10000d00.uart1: ttyS1 at MMIO 0x10000d00 (irq = 29, base_baud = 2500000) is a 16550A
Thu Jul 2 08:12:39 2020 kern.debug kernel: [ 0.430000] pinctrl core: add 1 pinmux maps
Thu Jul 2 08:12:39 2020 kern.debug kernel: [ 0.430000] rt2880-pinmux pinctrl: found group selector 2 for uart2
Thu Jul 2 08:12:39 2020 kern.debug kernel: [ 0.430000] rt2880-pinmux pinctrl: request pin 20 (io20) for 10000e00.uart2
Thu Jul 2 08:12:39 2020 kern.debug kernel: [ 0.430000] rt2880-pinmux pinctrl: request pin 21 (io21) for 10000e00.uart2
Thu Jul 2 08:12:39 2020 kern.info kernel: [ 0.430000] 10000e00.uart2: ttyS2 at MMIO 0x10000e00 (irq = 30, base_baud = 2500000) is a 16550A
Thu Jul 2 08:12:39 2020 kern.debug kernel: [ 0.450000] pinctrl core: add 1 pinmux maps
Thu Jul 2 08:12:39 2020 kern.debug kernel: [ 0.450000] rt2880-pinmux pinctrl: found group selector 8 for spi
Thu Jul 2 08:12:39 2020 kern.debug kernel: [ 0.450000] rt2880-pinmux pinctrl: request pin 7 (io7) for 10000b00.spi
Thu Jul 2 08:12:39 2020 kern.debug kernel: [ 0.450000] rt2880-pinmux pinctrl: request pin 8 (io8) for 10000b00.spi
Thu Jul 2 08:12:39 2020 kern.debug kernel: [ 0.450000] rt2880-pinmux pinctrl: request pin 9 (io9) for 10000b00.spi
Thu Jul 2 08:12:39 2020 kern.debug kernel: [ 0.450000] rt2880-pinmux pinctrl: request pin 10 (io10) for 10000b00.spi
Thu Jul 2 08:12:39 2020 kern.info kernel: [ 0.450000] spi-mt7621 10000b00.spi: sys_freq: 193333333
Thu Jul 2 08:12:39 2020 kern.warn kernel: [ 0.460000] m25p80 spi32766.0: found w25q128, expected en25q64
Thu Jul 2 08:12:39 2020 kern.info kernel: [ 0.470000] m25p80 spi32766.0: w25q128 (16384 Kbytes)
Thu Jul 2 08:12:39 2020 kern.warn kernel: [ 0.480000] m25p80 spi32766.0: using chunked io
Thu Jul 2 08:12:39 2020 kern.notice kernel: [ 0.490000] 4 ofpart partitions found on MTD device spi32766.0
Thu Jul 2 08:12:39 2020 kern.notice kernel: [ 0.510000] Creating 4 MTD partitions on “spi32766.0”:
Thu Jul 2 08:12:39 2020 kern.notice kernel: [ 0.520000] 0x000000000000-0x000000030000 : “u-boot”
Thu Jul 2 08:12:39 2020 kern.notice kernel: [ 0.530000] 0x000000030000-0x000000040000 : “u-boot-env”
Thu Jul 2 08:12:39 2020 kern.notice kernel: [ 0.540000] 0x000000040000-0x000000050000 : “factory”
Thu Jul 2 08:12:39 2020 kern.notice kernel: [ 0.550000] 0x000000050000-0x000001000000 : “firmware”
Thu Jul 2 08:12:39 2020 kern.notice kernel: [ 0.630000] 2 uimage-fw partitions found on MTD device firmware
Thu Jul 2 08:12:39 2020 kern.notice kernel: [ 0.640000] 0x000000050000-0x000000173bb8 : “kernel”
Thu Jul 2 08:12:39 2020 kern.notice kernel: [ 0.650000] 0x000000173bb8-0x000001000000 : “rootfs”
Thu Jul 2 08:12:39 2020 kern.notice kernel: [ 0.660000] mtd: device 5 (rootfs) set to be root filesystem
Thu Jul 2 08:12:39 2020 kern.notice kernel: [ 0.670000] 1 squashfs-split partitions found on MTD device rootfs
Thu Jul 2 08:12:39 2020 kern.notice kernel: [ 0.680000] 0x000000960000-0x000001000000 : “rootfs_data”
Thu Jul 2 08:12:39 2020 kern.info kernel: [ 0.700000] tun: Universal TUN/TAP device driver, 1.6
Thu Jul 2 08:12:39 2020 kern.info kernel: [ 0.710000] tun: © 1999-2004 Max Krasnyansky <[email protected]>
Thu Jul 2 08:12:39 2020 kern.info kernel: [ 0.730000] ralink_soc_eth 10100000.ethernet eth0: ralink at 0xb0100000, irq 5
Thu Jul 2 08:12:39 2020 kern.info kernel: [ 0.740000] mt7621_wdt 10000120.watchdog: Initialized
Thu Jul 2 08:12:39 2020 kern.info kernel: [ 0.750000] TCP: cubic registered
