Hi everyone,
I am working with the module, and I am doing some tests with the standalone module using RUI3. I am using the “SPI.h” and “SD.h” libraries. My code basically does a write test on a SD CARD by printing a timeStamp every second in a TXT file. The problem arises after hours the module stops writing/restarts and does not complete the 24 hour cycle. Attached is some code. Does anyone know what could be happening.
#include <SD.h>
#include <SPI.h>
int segundos=0;
int minutos=0;
int horas=0;
int pin=PA13;
//unsigned long cont;
void setup() {
pinMode(pin,OUTPUT);
// Open serial communications and wait for port to open:
Serial.begin(9600);//, RAK_AT_MODE);
// initialize serial communication at 115200 bits per second, and use the custom mode
//Serial1.begin(115200, RAK_CUSTOM_MODE);
delay(2000);
while (!Serial) {
; // wait for serial port to connect. Needed for native USB port only
Serial.print("Initializing SD card...");
// see if the card is present and can be initialized:
if (!SD.begin(PA4)) {
Serial.println("Card failed, or not present");
// don't do anything more:
while (1);
Serial.println("card initialized.");
void loop() {
//digitalWrite(PA13,HIGH);
segundos=segundos+1;
if (segundos>=60){
segundos=segundos-60;
minutos=minutos+1;
if(minutos>=60){
minutos=minutos-60;
horas=horas+1;
digitalWrite(pin,HIGH);
delay(500);
digitalWrite(pin,LOW);
delay(500);
File dataFile = SD.open("datarak.txt", FILE_WRITE);
// if the file is available, write to it:
if (dataFile) {
dataFile.print(horas);
dataFile.print(":");
if(minutos<10){
dataFile.print("0");
dataFile.print(minutos);
if(segundos<10){
dataFile.println(segundos);
//dataFile.println();
dataFile.close();
// print to the serial port too:
}// if the file isn't open, pop up an error:
else {
Serial.println("error opening datalog.txt");
Serial.print(horas);
Serial.print(":");
if(minutos<10){
Serial.print("0");
Serial.print(minutos);
Serial.print(":");
if(segundos<10){
Serial.print("0");
Serial.println(segundos);
