at+set_config=lora:send_interval:1:10<- changed to this idk why and how but i it works
this uses X:Y. x=1 means auto send, y= seconds u want it to repeat
someone close this if possible
btw i encountered a new problem it is with regards to sending of data.
Wake up.
Battery Voltage = 3.951 V
BME680 sensor data:
Humidity:44.309 %RH
Temperature:30.8 degree
Pressure:1004.48 hPa
Gas_resistance: 5742 ohms
[LoRa]: send error 87
Go to Sleep.
why is there a error 87?
the first part i already got it working alr. the second problem i dont really understand The length of the packet exceeded that maximum allowed by the LoRa protocol.
but i found a previous user with the same error i just copied their solution. sorry for bothering you and thank you so much
the solution i used was to add At command lora:dr:5. all the other parameters i left it alone. then the data was able to be send to the lora network server.
i added “at+ set_config=loa:dr:5”. i also realised the ADR margin on my network server is 5 by default that is why i implemented the solution. Send Error 87 with 7204 and 5205 - LPWAN Nodes / RAK7205 / RAK5205 - RAKwireless Forum
i had to read this twice to understand what the problem on my end was. this is just to clear up the miscommunication.
also to follow up with what you said,
do you understand what this means?
