I use the RAK3172 module for a 434 MHz LoRa APRS application but I don´t get a SubGHz interrupt during transmission. The output from my code is the following:
APRS Demo
Application version: V1.3.0
Radio version: V1.3.0
Radio settings
LoRa Bandwidth: 125 kHz
LoRa Spreading factor: 12
LoRa Frequency: 433775000
Device reset...
Initialization successful!
Go
I tested the code before on an STM32WL Nucleo and there it runs fine. So I think there is some issue with the port to the RAK platform.
Thank you for sharing your work. However, I am not sure if we can help you substantially on this custom application. If there is any hardware support or clarification you need, we can help. But on the firmware side, we cannot (unless if it is based on RUI3).
Best assistance I can give you is give the schematic of RAK3172 so you can map the pins in the Nucleo board. I do not have the 4xx Mhz version of RAK3172 so cannot confirm the firmware you develop.
That’s why you should ask STM, they are the manufacturer of the STM32WLE5 with the integrated LoRa transceiver.
We are only putting required electronic parts around it, put it on a PCB and put a metal cap on it.
What you can do, in our RUI3 API we support the 433MHz as well and RUI3 is open source. You can check for differences in your application and what we do with RUI3.
