Hi i am facing an issue where i was trying to send data to TTN using this code
- This example shows LoRaWan protocol joining the network in OTAA mode, class A, region EU868.
- Device will send uplink every 20 seconds.
#include <DHT.h>
#define DHTPIN PB2 // Digital pin connected to the DHT sensor
#define DHTTYPE DHT11 // Type of the DHT sensor
#define sensorPin PB3
int sensorValue = 0;
DHT dht(DHTPIN, DHTTYPE);
#define OTAA_PERIOD (20000)
LoRaWAN band setting:
RAK_REGION_EU433
RAK_REGION_CN470
RAK_REGION_RU864
RAK_REGION_IN865
RAK_REGION_EU868
RAK_REGION_US915
RAK_REGION_AU915
RAK_REGION_KR920
RAK_REGION_AS923
#define OTAA_BAND (RAK_REGION_IN865)
#define OTAA_DEVEUI {0xAC, 0x1F, 0x08, 0xFF, 0xFE, 0x07, 0x4A, 0x7D}
#define OTAA_APPEUI {0x23, 0x00, 0x00, 0x98, 0x00, 0x00, 0x23, 0x00}
#define OTAA_APPKEY {0xE4, 0xA3, 0xEE, 0xE4, 0x09, 0x53, 0x6A, 0x2F, 0xB1, 0xB7, 0xE1, 0x79, 0x11, 0xC4, 0x1D, 0x43}
/ Packet buffer for sending */
uint8_t collected_data[64] = { 0 };
void recvCallback(SERVICE_LORA_RECEIVE_T * data)
if (data->BufferSize > 0) {
Serial.println(“Something received!”);
Serial.printf(“%x”, data->Buffer[i]);
Serial.print(“\r\n”);
Serial.printf(“Join status: %d\r\n”, status);
- enum type for LoRa Event
RAK_LORAMAC_STATUS_OK = 0,
RAK_LORAMAC_STATUS_ERROR,
RAK_LORAMAC_STATUS_TX_TIMEOUT,
RAK_LORAMAC_STATUS_RX1_TIMEOUT,
RAK_LORAMAC_STATUS_RX2_TIMEOUT,
RAK_LORAMAC_STATUS_RX1_ERROR,
RAK_LORAMAC_STATUS_RX2_ERROR,
RAK_LORAMAC_STATUS_JOIN_FAIL,
RAK_LORAMAC_STATUS_DOWNLINK_REPEATED,
RAK_LORAMAC_STATUS_TX_DR_PAYLOAD_SIZE_ERROR,
RAK_LORAMAC_STATUS_DOWNLINK_TOO_MANY_FRAMES_LOSS,
RAK_LORAMAC_STATUS_ADDRESS_FAIL,
RAK_LORAMAC_STATUS_MIC_FAIL,
RAK_LORAMAC_STATUS_MULTICAST_FAIL,
RAK_LORAMAC_STATUS_BEACON_LOCKED,
RAK_LORAMAC_STATUS_BEACON_LOST,
RAK_LORAMAC_STATUS_BEACON_NOT_FOUND,
if (status == RAK_LORAMAC_STATUS_OK) {
Serial.println(“Successfully sent”);
} else {
Serial.println(“Sending failed”);
void setup()
dht.begin();
Serial.begin(115200, RAK_AT_MODE);
delay(2000);
Serial.println("RAKwireless LoRaWan OTAA Example");
if(api.lorawan.nwm.get() != 1)
Serial.printf("Set Node device work mode %s\r\n",
api.lorawan.nwm.set(1) ? "Success" : "Fail");
api.system.reboot();
// OTAA Device EUI MSB first
uint8_t node_device_eui[8] = OTAA_DEVEUI;
// OTAA Application EUI MSB first
uint8_t node_app_eui[8] = OTAA_APPEUI;
// OTAA Application Key MSB first
uint8_t node_app_key[16] = OTAA_APPKEY;
if (!api.lorawan.appeui.set(node_app_eui, 8)) {
Serial.printf("LoRaWan OTAA - set application EUI is incorrect! \r\n");
return;
if (!api.lorawan.appkey.set(node_app_key, 16)) {
Serial.printf("LoRaWan OTAA - set application key is incorrect! \r\n");
return;
if (!api.lorawan.deui.set(node_device_eui, 8)) {
Serial.printf("LoRaWan OTAA - set device EUI is incorrect! \r\n");
return;
if (!api.lorawan.band.set(OTAA_BAND)) {
Serial.printf("LoRaWan OTAA - set band is incorrect! \r\n");
return;
if (!api.lorawan.deviceClass.set(RAK_LORA_CLASS_A)) {
Serial.printf("LoRaWan OTAA - set device class is incorrect! \r\n");
return;
if (!api.lorawan.njm.set(RAK_LORA_OTAA)) // Set the network join mode to OTAA
Serial.printf("LoRaWan OTAA - set network join mode is incorrect! \r\n");
return;
if (!api.lorawan.join()) // Join to Gateway
Serial.printf("LoRaWan OTAA - join fail! \r\n");
return;
/** Wait for Join success */
api.lorawan.join();
delay(10000);
if (!api.lorawan.adr.set(true)) {
Serial.printf("LoRaWan OTAA - set adaptive data rate is incorrect! \r\n");
return;
if (!api.lorawan.rety.set(1)) {
Serial.printf("LoRaWan OTAA - set retry times is incorrect! \r\n");
return;
if (!api.lorawan.cfm.set(1)) {
Serial.printf("LoRaWan OTAA - set confirm mode is incorrect! \r\n");
return;
/** Check LoRaWan Status*/
Serial.printf("Duty cycle is %s\r\n", api.lorawan.dcs.get()? "ON" : "OFF"); // Check Duty Cycle status
Serial.printf("Packet is %s\r\n", api.lorawan.cfm.get()? "CONFIRMED" : "UNCONFIRMED"); // Check Confirm status
uint8_t assigned_dev_addr[4] = { 0 };
Serial.printf("Device Address is %02X%02X%02X%02X\r\n", assigned_dev_addr[0], assigned_dev_addr[1], assigned_dev_addr[2], assigned_dev_addr[3]); // Check Device Address
Serial.printf("Uplink period is %ums\r\n", OTAA_PERIOD);
Serial.println("");
void uplink_routine()
float temperature = dht.readTemperature();
float humidity = dht.readHumidity();
sensorValue = analogRead(sensorPin);
uint8_t temp = (uint8_t)(temperature + 0.5f);
uint8_t humi = (uint8_t)(temperature + 0.5f);
/** Payload of Uplink */
uint8_t data_len = 0;
collected_data[data_len++] = temp; //Data Channel: 4
collected_data[data_len++] = humi; //Type: Analog Input
collected_data[data_len++] = sensorValue;
Serial.println("Data Packet:");
for (int i = 0; i < data_len; i++) {
Serial.printf("0x%02X ", collected_data[i]);
Serial.println("");
/** Send the data package */
if (api.lorawan.send(data_len, (uint8_t *) & collected_data, 2, true, 1)) {
Serial.println("Sending is requested");
} else {
Serial.println("Sending failed");
void loop()
static uint64_t last = 0;
static uint64_t elapsed;
if ((elapsed = millis() - last) > OTAA_PERIOD) {
uplink_routine();
last = millis();
//Serial.printf("Try sleep %ums..", OTAA_PERIOD);
api.system.sleep.all(OTAA_PERIOD);
//Serial.println("Wakeup..");
But the Problem is when i put UART programer with Serial monitor this work but when i power them from 12V battery by converting to 3,5 volt by using LDO voltage regulator the device not able to join TTN network
