I was able to get the PPP network interface working on my RAK7244C with the quick start guide, but would prefer to change it to use a WWAN interface so it can work with ModemManager.
I tried the solution suggested in this thread: Very slow internet on RAK7243, but when I ran the install script I got “Driver for 5.4.72-v7l+ kernel not found”. I modified it to ignore the kernel version assuming (maybe wrongly) that higher versions would be compatible, and the install appeared to succeed. But I still don’t see the wwan0 interface. Any suggestions?
It’s my understanding that those I/O errors happen when the pins are already exported, so I don’t think that’s an issue. I checked each of the pin values and directions to make sure they were the same as the script.
When I tried running the quectel-CM command again I got the same output as before (network interface '' or qmidev '' is not exist).
I’m pretty certain that lack of power was never the issue here (and neither was insufficient current). The Pi, and by extension the RAK2013 LTE HAT attached to it, was always powered via the adapter it shipped with. The issue I ran into on step 10 was that the USB cable plugged in between the Pi and RAK2013 was charge-only, so the quectel-CM script couldn’t detect the device because no communication was happening over USB. When I swapped to a cable that could also handle data, it was able to find the device and the issue was resolved.
As for my question about setting up QMI without a USB cable, I just want to know whether it can be done through the GPIO pins like the PPP interface was.
