Hi. I have a RAK 10701-PLUS equip,ment, I wanbt to use it in LinkCheck Mode and transmit data and GPS to the TTN, I have a Milesight Gateway. Hoy to set it up?
To day ins sending data in fport:6 in 6 bytes paload.
Tha nks
Tha nks
Hi @Victor ,
It seems you are not running the Field Test Data Processor extension that’s why you only get uplinks on fport 5 (your question to different forum thread). You need a WisGate Edge to run this extension software.
Regarding linkcheck, the device is working immediately in LinkCheck mode. You can see the downlink parameters in the screen as well as the number of gateways.
Hi:
all the documentation talks about a 10 bytes payload coming in f_port:1. I my case I am receiving a 7 bytes payload and from f_port:5 . Do you have the decoder for the 7 bytes coming from fport_5? o the way th change a standar mode?
Hi @Victor ,
The bytes you get on fport5 represents the label tag. You can see in your TTN console that it shows NULL value.
You can change it in settings. For example, I changed mine to TEST.
This is the payload I will receive which is the hex representation of the ASCII word TEST.
To have the GPS data payload that you expect from fport1, you need to have a working integration to Field Test Data Processor extension in WisGate OS2.
I understand that you use non-RAK gateway. So we can force a manual downlink to activate the payload.
Please send as downlink:
Hex: 76312E312E30
Port:10
After scheduling and successfully received by the RAK10701-Plus field tester, you should start getting the GPS data on fport1.
Here’s how it should look like.
Thanks, It is works,
It is posible to set the RAK10701-Plus field tester, with GPS mode in fport:1 as default in the startup?
I observed when a turn off the equipmet , in the next restart the RAK begins in Fport = 5 again
Hi @Victor ,
On the current FW, it is not possible. The downlink in fport 10 is needed to activate the full payload.
This response is SO useful that I would respectfully BEG you to put this into the RAK10701 manual as “See here if you are not using RAK gateways”.
This is awesome. Thx.
Welcome to RAK forum @marlanw ,
This is more of a hack approach and you have to send this downlink everytime.
But I have a good news for you. I created a python app that you can run so simulate the behavior of the extension even if you have no wisgate.
The down side is you have to run it in your PC/laptop. Having a WisGate is still best since the extension is running on the background of the gateway.
First of all, thank you for your help, the workaround is working well on my side, I really appreciate it.
I have a couple of questions:
Where can I find or download the Python application you mentioned?
Also, with this tool that simulates the WisGate extension, will it be possible to get downlink statistics on the tester ? At the moment, I can only see uplink data.
Thanks again for your support !
can you share your python app?
i’m use gateway rak7393 with rakpios, i can’t see uplink status on field tester plus
