I’ve been able to mostly get a consistent connection between two RAK 3272 modules, but every now and then I get an AT_MODE_NO_SUPPORT on one of the modules. Im using two scripts on raspberry Pi’s, one to send and one to receive and it was working great earlier but now I’m back to having issues.
Current issue is with my receive script after the AT+P2P command-
import serial
import time
UART = serial.Serial('/dev/serial0',
baudrate=115200,
timeout=9.0,
parity=serial.PARITY_NONE,
stopbits=serial.STOPBITS_ONE)
UART.reset_output_buffer()
print("\r\nChecking LoRa Module Status...")
UART.write(b"AT\r\n")
rcv = UART.read_until(b'\r\n')
status = rcv.decode()
print(" ", status)
# "AT+P2P=freq():SF(5-12):BW(125,250,500):CodeRate(0-3):Preamble(2-655636):TXPower(5-22dBm)>"
print("\r\nConfiguring LoRa Module...")
UART.write(b"AT+P2P=917000000:7:500:0:8:20\r\n")
print(" ", status)
print("\r\nConfiguration Check:")
UART.write(b"AT+P2P=?\r\n")
rcv = rcv.decode()
list = rcv.split(":")
print("\r\n", list)
counter = 1
while True:
UART.write(b"AT+PRECV=0\r\n")
print("\r\n", counter, " Waiting for data...\r\n")
UART.write(b"AT+PRECV=65535\r\n")
print("Module Status- ", status)
# Reads until Event flag
rcv = UART.read_until(b"+EVT:")
# Reads remainign data after event flag
rcv = UART.read_until(b"\r\n")
if rcv:
rawdata = rcv.decode()
print("\r\nRaw Data- ", rawdata)
list = rawdata.split(':')
mode = list[0]
rsi = list[1]
snr = list[2]
hexdata = list[3]
data = bytes.fromhex(hexdata).decode("utf-8")
print("\r\nLora Mode:", mode, " Raw RSI:", rsi, " Connection Strength:", (1/(-1*int(rsi))*2000), " SNR:", snr)
print("\r\nData- ", data)
counter += 1
Console output is-
Send script for reference is-
import serial
import time
baudrate=115200,
timeout=2.0,
status = str(rcv)
print(" ", status)
print("\r\nConfiguring Work Mode...")
UART.write(b"AT+NWM=0\r\n")
print(" ", rcv.decode())
UART.write(b"AT+P2P=917000000:7:250:0:8:20\r\n")
rcv = rcv.decode()
list = rcv.split(':')
print("\r\n", list)
data = 0
counter = 0
#time.sleep(5)
while True:
print("\r\n", counter, " Sending...\r\n")
strdata = str(data)
bytedata = strdata.encode("utf-8")
hexdata = bytedata.hex()
hexdata = hexdata.encode("utf-8")
command = b"AT+PSEND=" + hexdata + b"\r\n"
UART.write(command)
#print("\r\nWrote-", command)
#UART.write(b"AT+PSEND=48656C6C6F\r\n")
print(" ", rcv.decode(), "Length-", len(hexdata))
time.sleep(1)
data += 1
counter += 1
Any suggestions/optimizations/fixes are greatly appreciated! Happy with the progress I made today but not sure why I’m having issues again
