For our use case we need to modify the LPWAN payload since we query Modbus devices at a high sampling interval and need to pack the data in a compact payload. As I understood from this post: Custom firmware, this is unfortunately not possible, since the code is not open source.
Is it possible to customize the hardware in the RAK7431 so that the lora Payload can be modified?
If yes, which components need to be replaced and what replacements are required?
How do we need to customize the code of the open source modules for this to work?
Are the hardware interfaces of the case still compatible with open source components?
Thank you for your help!
