Hi @pablovilmac,
I’ve just sent an email to you.
Hi @Fomi,
Can I please have access to the online compiler?
Tim Baker
timm.bakerr (at) gmail (dot) com
RAK7204
Thanks,
Tim
Hi.
compiler is ok but on 5205 the at+set_config=device:gps_timeout: is not working.
any suggestion?
thanks
What did you get in return for sending the command?
Hi @FLorenzi,
Yes, in the latest version SDK, we’ve removed all of sensors, because we think that the sensors including GPS should be implemented in “Application” and open source, not in RUI SDK. That’s why this AT command can not work.
BTW, in the next version SDK, we’ll open source all AT commands as a part of “Allication”, so that you can customize the AT command as your usecase.
hi.
When will you release the new version of SDK?
I need to know if I can wait for it or implement another solution for the matter.
@All
We will upgrade the RUI Compile Server at UTC time 2019-10-16 01:00-06:00 and do not use it during this time.
We will reply here after the upgrade is complete.
Hi @FLorenzi,
For RAK811, we’ll release it in this week.
For RAK5205, we can release it next week, because it need 2 more days.
@All
I am very sorry that the online server is currently in the final testing phase and is scheduled to go online on 2019-10-17.
@All
The build server has been upgraded.
Hi, Fomi,
I am using the code from:
Products_practice_based_on_RUI-master\based on RAK811\app_5205
and copied to: /home/rak10030/application/811-H
I just compiled for RAK811 using:
rak_rui_build 811-H
…//Source/stm/STML151/application/at_cmd.c: In function ‘lora_join’:
…//Source/stm/STML151/application/at_cmd.c:115:5: error: too many arguments to function ‘rui_lora_get_status’
rui_lora_get_status(false,&app_lora_status);*
In file included from …//Source/stm/STML151/application/at_cmd.c:2:0:
…//Source/rui/rui.h:806:10: note: declared here
…//Source/stm/STML151/application/at_cmd.c: In function ‘lora_region’:
…//Source/stm/STML151/application/at_cmd.c:174:5: error: too many arguments to function ‘rui_lora_get_status’
…//Source/stm/STML151/application/at_cmd.c: In function ‘lora_send’:
…//Source/stm/STML151/application/at_cmd.c:242:5: error: too many arguments to function ‘rui_lora_get_status’
stm/Makefile_stm32l151cb:247: recipe for target ‘_build/at_cmd.o’ failed
make: *** [_build/at_cmd.o] Error 1
Thanks and regards
Boh Lim
Hi @bohlimsim,
I think you have used this API “rui_lora_get_status” incorrectly.
Please have a look at the definition of this API in our online RUI API reference:
https://doc.rakwireless.com/developer-tools/developer-tools/rui-lora-get-status
As you see, there is only one parameter for this API, and the type of this parameter is uinit8_t.
I just tried compiling the unmodifed sample code and got the same errors. It seems the example code for the RAK5205 will not compile.
Martin
The definition for “RUI_LORA_STATUS_T” seems to be missing from the rui.h file…
@All
We will upgrade the RUI Compile Server at UTC time 2019-10-22 01:00-06:00 and do not use it during this time.
Hey I would also like to apply for the Online compiler
Email: [email protected], [email protected]
Module used: [
RAK811 WisNode Lora Module & RAK7243C Pilot Gateway
I didn’t change any code - was using the original codes.
I saw your team is doing some upgrade, will try later again to compile the codes (no code changes from me)
Thanks!
Thanks and regards
Boh Lim
