Hi Carlowan, thanks for your answer
this is the complete upload message received in TTN, I am usin a Milesihgt UG32 as a gateway an RAL10701-PLUS as a device. The documentation talks about a payload message coming from FPORT:1 or 2 wtih a 10 bytes. But i am receiving a payload from fport:5 with 7 bytes and with another structure. I tryed to decode the 7 bytes but i think is differente format
“name”: “as.up.data.forward”,
“time”: “2025-05-30T03:41:38.002422583Z”,
“identifiers”: [
“device_ids”: {
“device_id”: “medidorcampo”,
“application_ids”: {
“application_id”: “pruebas-lorawan”
“dev_eui”: “AC1F09FFFE18BBE2”,
“join_eui”: “AC1F09FFF9150701”,
“dev_addr”: “01726892”
“data”: {
“@type”: “type.googleapis.com/ttn.lorawan.v3.ApplicationUp”,
“end_device_ids”: {
“correlation_ids”: [
“as:up:01JWFMFWAFP9BCHN3YTFS05MJN”,
“gs:conn:01JWF3A3ZC03KXWHCAF52E8JWM”,
“gs:up:host:01JWF3A3ZH34J792AA9HHXE8B8”,
“gs:uplink:01JWFMFW3T34H0EPA65S12EFXG”,
“ns:uplink:01JWFMFW3VZSHVVXRHF7FBPSC3”,
“rpc:/ttn.lorawan.v3.GsNs/HandleUplink:01JWFMFW3TY9N4GA6W4MQX6YPC”,
“rpc:/ttn.lorawan.v3.NsAs/HandleUplink:01JWFMFWAFZN3AJJC6FM7G1547”
“received_at”: “2025-05-30T03:41:37.999996353Z”,
“uplink_message”: {
“session_key_id”: “AZcfQCTBcC8MIlUmLMrLcg==”,
“f_port”: 5,
“f_cnt”: 26,
“frm_payload”: “TlVMTAAAgA==”,
“decoded_payload”: {
“altitude”: “NaN”,
“error”: “GPS fix not meeting quality criteria (hdop must be <3 & sats must be >= 1) current hdop: NaN & sats:undefined”,
“hdop”: “NaN”,
“latitude”: -20.289749,
“location”: “(-20.289749,107.085835)”,
“longitude”: 107.085835,
“sats”: null
“rx_metadata”: [
“gateway_ids”: {
“gateway_id”: “gatewayug63”,
“eui”: “24E124FFFEFAF7CF”
“time”: “2025-05-30T03:41:37.567439Z”,
“timestamp”: 834617436,
“rssi”: -80,
“channel_rssi”: -80,
“snr”: 13.5,
“uplink_token”: “ChkKFwoLZ2F0ZXdheXVnNjMSCCThJP/++vfPENyA/Y0DGgwI8dHkwQYQ0Ojm9gIg4M7NmKWMBA==”,
“channel_index”: 7
“settings”: {
“data_rate”: {
“lora”: {
“bandwidth”: 125000,
“spreading_factor”: 7
“data_rate_index”: 5,
“coding_rate”: “4/5”,
“frequency”: “918200000”,
“received_at”: “2025-05-30T03:41:37.787049333Z”,
“confirmed”: true,
“consumed_airtime”: “0.056576s”
“origin”: “8adcfc352fcc”,
“visibility”: {
“rights”: [
“RIGHT_APPLICATION_TRAFFIC_READ”
“unique_id”: “01JWFMFWAJNJEMEGVTX1KSDJES”
Thanks for your help
