I updated RAK3172 version from 1.04 to 3.4.2-rui3_22q1_update.112
Below I have listed the commands that I run on Device A and the problem with receiving responses
ATZ\r\n \r\n RAKwireless RAK3172-E Example\r\n ------------------------------------------------------\r\n Current Work Mode: LoRa P2P.\r\n
AT+NWM=0\r\n \r\n RAKwireless RAK3172-E Example\r\n ------------------------------------------------------\r\n Current Work Mode: LoRa P2P.\r\n
AT+P2P=869525000:7:250:0:8:5\r\n OK\r\n
AT+PSEND=0D0076454BB0054C3230007BA5\r\n //data is received on second device (Device B) OK\r\n
AT+PRECV=65534\r\n OK\r\n
And now I have a problem. I don’t get the response from Device B. There is no data to read on serial port (I’m sure taht device B sends a reply)
When i changed version to 1.04 everything works fine.
Unfortunately, device B is an external device to which I do not have access and I do not know how exactly the transmission is implemented there. I can only say that communication with Device B worked, when Device A was in version 1.04
for a device A in pseudo-code it looks like this
while (true)
AT+VER=?\r\n
ATZ\r\n
AT+NWM=0\r\n
AT+PSEND=0D0076454BB0054C3230007BA5\r\n //data is received on second device (Device B )
AT+PRECV=65534\r\n
//waiting for data on serial port with timeout
I’am not sure that is a root couse.
I tried remove AT+NWM=0 command from my flow, because after ATZ i got info RAKwireless RAK3172-E Example\r\n ------------------------------------------------------\r\n Current Work Mode: LoRa P2P.\r\n
so i don’t need to change to P2P manually, but it doesn’t help.
I am not sure what your experience with AT+NWM=1 is but it should restart the module automatically. If you can give more info or details, we will check it
