About the function
Serial.println(api.system.bat.get());
Is it possible to modify it to read another ADC that 1 ?
That is not possible at the moment and api.system.bat.get() works only if you have actually a circuit that can read the battery voltage.
You can use the Analog IO functions to read from another analog pin.
thank you so much!
One more question Beegee
how can i a do on arduino to detect this message ?
“+EVT:LINKCHECK:0:26:1:-28:8”
For example, if he link is down, the event not occurs
void receiveCallback(SERVICE_LORA_RECEIVE_T *data)
MYLOG("RX-CB", "RX, port %d, DR %d, RSSI %d, SNR %d", data->Port, data->RxDatarate, data->Rssi, data->Snr);
for (int i = 0; i < data->BufferSize; i++)
Serial.printf("%02X", data->Buffer[i]);
Serial.print("\r\n");
tx_active = false;
i need to detect this message
+EVT:LINKCHECK:1:0:0:0:0****strong text
There is no callback, but you can check the result in the RX callback with api.lorawan.linkcheck.get();
i changed the software…
but it´s always returning 0
[UPLINK] Sending packet...
[UPLINK] Packet enqueued, size 6
Network link status = 0
[TX-CB] TX status 0
+EVT:TX_DONE
+EVT:LINKCHECK:0:25:1:-29:8
[RX-CB] RX, port 0, DR 10, RSSI -29, SNR 8
Network link status = 0 <---------------------
if i power off the lora gateway
[UPLINK] Start
92539
3.29
[TX-CB] TX status 0
+EVT:TX_DONE
i would like to get acess to the +EVT:LINKCHECK values
X:X:X:X
void loop()
api.system.sleep.all();
// api.system.scheduler.task.destroy();
Serial.printf("Network link status = %d\r\n", api.lorawan.linkcheck.get());
The third and forth value are in the RX callback value, the second one is not available with the API at the moment.
yes, i agree, but if you POWER off the GATEWAY MODEM, you can´t get the
[RX-CB] event to get that values…
I want to detect if the GATEWAY is OFF
to solve temporarily, i had to include on service_lora.c
extern bool LINKCHECK_ERROR;
and
case MLME_LINK_CHECK:
linkcheck_flag = 1;
DemodMargin = mlmeConfirm->DemodMargin;
NbGateways = mlmeConfirm->NbGateways;
linkcheck_state = mlmeConfirm->Status;
if(linkcheck_state!= LORAMAC_EVENT_INFO_STATUS_OK)
udrv_serial_log_printf("+EVT:LINKCHECK:1:0:0:0:0\r\n");
//miguel
LINKCHECK_ERROR = 1;
break;
and on main Arduino code
bool LINKCHECK_ERROR = 0;
And monitor that…
