Hi, when i send AT+DR=0 or SF12 they respond AT_PARAM_ERROR, but the ADR is OFF and AU912 band support DataRate is form 0 to 7, and only let me use 2 to 7.
15:59:30.618 → [LoRa]TX:ATZ
15:59:30.664 → [LoRa]RX: __ _ _ _ _
15:59:30.710 → [LoRa]RX:| ___ / _ \ | | / / | | | () | |
15:59:30.895 → [LoRa]RX:| |/ / /\ | |/ / | | | | _ __ | | ___ ___ ___
LoRa (R) is a registered trademark or service mark of Semtech Corporation or its affiliates. LoRaWAN (R) is a licensed mark.
15:59:31.080 → [LoRa]RX:
15:59:31.126 → [LoRa]RX:___ ___ _ __ _ _ _ _
15:59:31.173 → [LoRa]RX:| __ | |/| | | '/ _ \ |/ _ / / |
15:59:31.220 → [LoRa]RX:| |\ | | | || |\ \ | | | / | /_ _
15:59:31.313 → [LoRa]RX:_| __| |/\ / /||_| _|_|_||/__/
15:59:31.359 → [LoRa]RX:================================================
15:59:31.406 → [LoRa]RX:RAK3172-H Vers.4 Feb 18 2022
15:59:31.451 → [LoRa]RX:Current Work Mode: LoRaWAN.
15:59:31.499 → [LoRa]TX:AT+NWM=1
15:59:31.545 → [LoRa]RX:
15:59:31.545 → [LoRa]RX:OK
15:59:31.545 → [LoRa]TX:AT+BAND=6
15:59:31.593 → [LoRa]RX:
15:59:31.593 → [LoRa]RX:OK
15:59:31.639 → [LoRa]TX:AT+MASK=0001
15:59:31.639 → [LoRa]RX:
15:59:31.685 → [LoRa]RX:OK
15:59:31.685 → [LoRa]TX:AT+DEVEUI=496F542DC1AEDE84
15:59:31.731 → [LoRa]RX:
15:59:31.777 → [LoRa]RX:OK
15:59:31.777 → [LoRa]TX:AT+APPEUI=1111111111111111
15:59:31.825 → [LoRa]RX:
15:59:31.871 → [LoRa]RX:OK
15:59:31.871 → [LoRa]TX:AT+APPKEY=11111111111111111111111111111111
15:59:31.965 → [LoRa]RX:
15:59:31.965 → [LoRa]RX:OK
15:59:32.011 → [LoRa]TX:AT+NJM=1
15:59:32.011 → [LoRa]RX:
15:59:32.057 → [LoRa]RX:OK
15:59:32.057 → [LoRa] Config Canales
15:59:32.057 → [LoRa] Open port 0 to 8
15:59:32.103 → [LoRa]TX:AT+MASK=0001
15:59:32.149 → [LoRa]RX:
15:59:32.149 → [LoRa]RX:OK
15:59:32.149 → [LoRa]TX:AT+ADR=0
15:59:32.196 → [LoRa]RX:
15:59:32.196 → [LoRa]RX:OK
15:59:32.242 → [LoRa]TX:AT+DR=0
15:59:32.242 → [LoRa]RX:
15:59:32.288 → [LoRa]RX:AT_PARAM_ERROR
I check ADR and try to set DR from 0 to 7 and this is the result
16:27:49.757 → [SHELL]/lora AT+ADR=?
16:27:49.757 → [LoRa]TX:AT+ADR=?
16:27:49.804 → [LoRa]RX:0
16:27:49.850 →
16:27:49.850 → [LoRa]RX:OK
16:27:55.724 → [SHELL]/lora AT+DR=?
16:27:55.771 → [LoRa]TX:AT+DR=?
16:27:55.771 → [LoRa]RX:2
16:27:55.817 → [LoRa]RX:
16:27:55.817 →
16:27:55.817 → [LoRa]RX:OK
16:27:59.152 → [SHELL]/lora AT+DR=0
16:27:59.152 → [LoRa]TX:AT+DR=0
16:27:59.199 → [LoRa]RX:
16:27:59.199 → [LoRa]RX:AT_PARAM_ERROR
16:27:59.246 → AT_PARAM_ERROR
16:28:02.475 → [SHELL]/lora AT+DR=1
16:28:02.475 → [LoRa]TX:AT+DR=1
16:28:02.522 → [LoRa]RX:
16:28:02.522 → [LoRa]RX:AT_PARAM_ERROR
16:28:02.569 → AT_PARAM_ERROR
16:28:04.964 → [SHELL]/lora AT+DR=2
16:28:04.964 → [LoRa]TX:AT+DR=2
16:28:05.010 → [LoRa]RX:
16:28:05.010 → [LoRa]RX:OK
16:28:05.057 → OK
16:28:09.737 → [SHELL]/lora AT+DR=3
16:28:09.737 → [LoRa]TX:AT+DR=3
16:28:09.783 → [LoRa]RX:
16:28:09.830 → [LoRa]RX:OK
16:28:09.830 → OK
16:28:12.943 → [SHELL]/lora AT+DR=4
16:28:12.943 → [LoRa]TX:AT+DR=4
16:28:12.991 → [LoRa]RX:
16:28:13.038 → [LoRa]RX:OK
16:28:13.038 → OK
16:28:14.873 → [SHELL]/lora AT+DR=5
16:28:14.919 → [LoRa]TX:AT+DR=5
16:28:14.965 → [LoRa]RX:
16:28:14.965 → [LoRa]RX:OK
16:28:15.011 → OK
16:28:17.974 → [SHELL]/lora AT+DR=6
16:28:17.974 → [LoRa]TX:AT+DR=6
16:28:18.022 → [LoRa]RX:
16:28:18.068 → [LoRa]RX:OK
16:28:18.068 → OK
16:28:20.747 → [SHELL]/lora AT+DR=7
16:28:20.793 → [LoRa]TX:AT+DR=7
16:28:20.840 → [LoRa]RX:
16:28:20.840 → [LoRa]RX:OK
16:28:20.840 → OK
i need set DR=0 for SF12, What am i doing wrong?
thanks.
