RAK3172 AU915 on actility server
…Could we disable dwell time control on actility server?..or Do i need change something on the rak3172 for work with lowest dr0 and dr1?..is the joint req with dr2 allways?
This is a question to ask Actility.
Dwell Time enable/disabled is controlled by the LoRaWAN server. The RAK3172 should enable/disable it depending on the response of the LNS it gets during the join request.
You will still have to Join on DR2 if using OTAA. Not sure how it will work with ABP.
I was never able to disable Dwell Time on AS923-3 with a Chirpstack Server V4.
