RAK3172 Baud rate much too slow
Well, if we use the RAK811 way.
The module goes to sleep and wakes-up up by detecting activity on RX line.
The MCU sends any character.
We don’t use LoRaWAN, P2P exclusively.
The slow baud is a huge bottleneck.
Getting the data out of the module at 9600 baud 128 bytes is 133ms with no gaps.
More like 200ms with the gaps between the characters.
For a battery powered application this is 200ms wasted.
NO we don’t want to lock ourselves into a module.
Using that MCU.
The Lora module should default to 115200, and changeable.
9600 baud is totally not usable for us . PERIOD.
Thank you
Frank
Maybe for you, but not for most users.
This is primarily a LoRaWAN device, intended to infrequently send and even less frequently receive quite short messages, with an emphasis on low standby power consumption since it’s the kind of thing that sleeps for 20 minutes and wakes up for a few fractions of a second over a period of 5-6 seconds.
If you want something odd, you may just have to implement suitable firmware yourself.
This is how the RAK811 works.
Intended for the exact same market,
Indeed ALL other manufacturers use 115200 baud as a default.
Having a 9600 baud rate uses more power, not less.
The module needs to be on 12X longer to get data in or out on the UART.
We don’t don’t be burdened with maintaining firmware in the radio module.
This defeats the point of the module.
Abusively yelling about things is unproductive, and will be removed.
In terms of actual technical tradeoffs,
You are only looking at one part of the issue, and ignoring the other part.
For most users using the module as intended, a small fraction of a second occurring only once every few minutes and accompanied by the much more power costly actual usage of the radio, is really no cost at all.
In contrast, lower power consumption while asleep is very key, but comes at the cost of a slower wakeup process, which needs either a distinct wakeup trigger with a gap before the actual serial data, or a slower baud rate.
This module’s firmware is really designed and optimized for a different usage than you are looking for - it can do custom LoRa schemes, but it’s really designed for LoRaWAN usage where it would primarily transmit short messages infrequently with very long sleep periods in between.
You’ll always have more flexibility for unique usage when you run your own firmware directly against the radio, either on the CPU in this module, or on that in your own. For your rather unique use case, I’d agree that 9600 baud is on the slow side, which is why your needs are the textbook example of a situation where you really want your own firmware, rather than a serial command one that’s optimized for the quite different sleep/wake pattern of a LoRaWAN node.
Aesthetically, I also dislike the idea of 9600 baud even for LoRaWAN, but after looking at the tradeoff in detail, it’s actually the better choice - I’d call your attention to section 3.6.9 of the STM32WLE5xx data sheet which documents the exact baud rate limit for the LSE-clocked wakeup mode of the LPUART as already explained, and section 5.3.8 which gives wakeup times from stop mode which would be hard pressed to capture the first bits of 115200 baud traffic without a framing error, unless a faster oscillator were left on (costing power) or some other pre-wake scheme were used. Each chip which could be used in a product such as this offers its own unique sets of tradeoffs - an improvement in one area has a cost in another, and one doesn’t always agree with the designer’s choices.
The LPUART wakeup is a clever enough solution to a problem I recently faced on an other project that I’m going to keep it in mind for a future strategy, since it allows getting a very low power sleep without needing to impose any particular behavioral rules on the interacting code.
I totally disagree with you.
Sleeping has got nothing to do with baud rate sir.
It’s more of waking up issue.
Hi @frank_r ,
There is a new FW going to be released and I am updating now the documentation. You can upload this latest FW using RAK DFU Tool (for the .bin file) or STM32CubeProgrammer if you want to upload the .hex file with bootloader.
Command is AT+BAUD=115200.
Currently, you can switch to 4800, 9600 or 115200.
Btw guys, I hope we can all be civil in this public forum and avoid using capital letters. It might cause misinterpretations on the ideas you want to share :slight_smile:
Thanks Carl,
What is the default power-up baud rate?
Sounds like 9600??
In my application it needs to boot up at 115200 baud.
Thank you
Frank
Yes. The default is still 9600.
Thanks Carl,
Is the new baud rate stored in FLASH?
If the module is power cycled, does it start at 9600?
Frank
Yes. It will start on the newly configured baud rate.
So if you set it in production as 115200, that will be the new baudrate and not the default 9600.
Thanks Carl,
Does the OK message appear at 9600 or 115200 baud?
Frank
All behaviors are the same. But if you are changing the baud rate, the settings won’t take effect unless you restart the device via ATZ or power recycle.
Hi Carl,
The document indicates that the module must restarted for the new baud rate to take effect.
This means hardware reset?
Thank you
Frank
Thanks Carl,
Thus a hardware reset will do also.
Why is the SF limited to 6?
The chipset can do 5.
This limits the maximum bit rate.
The higher bit rates is extremely useful for OTA firmware upgrades.
Frank
Carl,
What is the maximum payload in P2P?
The AT command document doesn’t say.
Looks like 250 bytes (500 hex characters)
Frank
Carl,
In AT+PRECV=65535 how does it know when packet is fully received?
I see there is no sleep command.
How to put the device into sleep mode?
If it goes into sleep mode automatically, how long does it take to wake-up?
Do you just send a command to wake it and wait for OK?
Thank You
Frank
Hi @frank_r ,
SF5 will be supported on the next FW update. No exact schedule yet. We just released the latest version.
Maximum payload in p2p mode is 255.
P2P packets have no confirmation built-in. You have to include it in your application code if needed.
RAK3172 sleeps automatically so there is no sleep command. Any input to LPUART will wake it up.
