I’m working with a RAK3172 module, using Arduino API. I would like to attach to this module a DHT22 sensor to send data using P2P, but itsn’t working. I guess is the library i’m using is not compatible with the microcontroller of this module. Can you please recommend me a library or if anyone have worked before with a RAK3172 + DHT22 who can help me with any pearl of wisdom, I will be very thankful.
Which library are you trying to use?
What is not working?
Do you get compilation errors, if yes, can you post them here.
Do you use one of our example codes, if yes, which one?
I will send the missing definitions to our R&D team, but not sure when they will implement it, it is the first time I saw this error.
For the DHT22, I do not have that sensor. I worked with DHT11 and DHT22 before and their single wire protocol is quite difficult to catch. I had to write my own library DHTesp to get them to work with Espressif ESP MCU’s.
It could be that RUI3 is not able to catch the length of the zero’s and one’s in the data stream correct.
I will forward this as well to our R&D team, but not sure if it can be fixed soon.
