umutc
(umut)
November 11, 2024, 9:01pm
1
hello,
im using RAK3172 with esp32s3
im comminicate on uart2 rak3271 and esp32s3
i have a problem i sended AT+SEND=2:13344 example message but my message not arrived to chirpstack gateway
my code here :
#define Uart1BaudRate 115200
String comdata = "";
//char * buf1 = "AT+APPEUI=48FF000000000008\r\n";
//char * buf2 = "AT+DEVEUI=48E663FFFE300008\r\n";
//char * buf3 = "AT+APPSKEY=64A60D27D87E88D65BD7E0B734EDE2F0\r\n";
char * buf4 = "AT+JOIN=1:0:10:8\r\n";
char * buf5 = "AT+VER=?\r\n";
char * buf1 = "AT+APPEUI=5E9D1E0857CF25F1\r\n";
char * buf2 = "AT+DEVEUI=5E9D1E0857CF25F1\r\n";
char * buf3 = "AT+APPKEY=F921D50CD7D02EE3C5E6142154F274B2\r\n";
char * buf6 = "AT+APPEUI=?\r\n";
char * buf7 = "AT+DEVEUI=?\r\n";
char * buf8 = "AT+APPKEY=?\r\n";
char * buf9 = "AT+VER=?\r\n";
char * buf10 = "AT+CLASS=A\r\n";
char * buf11 = "AT+NJM=1\r\n";
char * buf12 = "AT+BAND=5\r\n";
char * buf13 = "AT+NWM=1\r\n";
char * buf14 = "AT+MASK=0002\r\n";
char * buf15 = "AT+CHE=2\r\n";
char * buf16 = "AT+CFM=0\r\n";
char * buf17 = "AT+SEND=2:12345678\r\n";
char * buf18 = "AT+RECV=?\r\n";
char * buf19 = "AT+DCS=0\r\n";
char * buf20 = "AT+CFS=?\r\n";
char * buf21 = "ATZ?\r\n";
// the setup routine runs once when you press reset:
void setup() {
// Serial1.begin(115200);
Serial1.begin(115200,SERIAL_8N1,18,17);
// Serial1.begin(115200,RAK_CUSTOM_MODE)
// Serial.setRxBufferSize(MaxUartRxBufferSize);//默认缓冲区位128 Byte,更改为 512 Byte
// Serial1.setRxBufferSize(MaxUartRxBufferSize);//默认缓冲区位128 Byte,更改为 512 Byte
//// while(Serial0.read()>= 0){}//clear serialport
// while(Serial1.read()>= 0){}//clear serialport
Serial1.write(buf21); // 将数据发送到UART1
delay(500);
while (Serial1.available() > 0)
comdata += char(Serial1.read());//readBytes
delay(2);
if (comdata.length() > 0)
Serial.println(comdata);
comdata = "";
delay(1000);
Serial1.write(buf14); // 将数据发送到UART1
delay(500);
delay(2);
comdata = "";
delay(1000);
Serial1.write(buf15); // 将数据发送到UART1
delay(500);
delay(2);
comdata = "";
delay(1000);
Serial1.write(buf13); // 将数据发送到UART1
delay(500);
delay(2);
comdata = "";
delay(1000);
delay(500);
delay(2);
comdata = "";
delay(1000);
Serial1.write(buf11); // 将数据发送到UART1
delay(500);
delay(2);
comdata = "";
delay(1000);
Serial1.write(buf10); // 将数据发送到UART1
delay(500);
delay(2);
comdata = "";
delay(1000);
Serial1.write(buf12); // 将数据发送到UART1
delay(500);
delay(2);
comdata = "";
delay(1000);
Serial1.write(buf2); // 将数据发送到UART1
delay(500);
delay(2);
comdata = "";
delay(1000);
Serial1.write(buf1); // 将数据发送到UART1
delay(500);
delay(2);
comdata = "";
delay(1000);
Serial1.write(buf3); // 将数据发送到UART1
delay(500);
delay(2);
comdata = "";
delay(1000);
Serial1.write(buf4); // 将数据发送到UART1
delay(500);
delay(2);
comdata = "";
delay(1000);
Serial1.write(buf5); // 将数据发送到UART1
delay(500);
delay(2);
comdata = "";
delay(1000);
// the loop routine runs over and over again forever:
void loop() {
// Serial.println("hello world !!!");
// Serial1.write(buf4); // 将数据发送到UART1
// delay(200);
Serial1.write(buf17); // 将数据发送到UART1
delay(500);
delay(2);
comdata = "";
delay(1000);
Serial1.write(buf18); // 将数据发送到UART1
delay(500);
delay(2);
comdata = "";
delay(1000);
delay(2);
comdata = "";
delay(10000); // delay in between reads for stability
beegee
(Bernd Giesecke)
November 12, 2024, 1:58am
2
umutc:
AT+SEND=2:13344
cannot work.
The AT+SEND command expects the payload as HEX-ASCII code.
E.g. if your payload is a byte array of {1,3,8,4,4}, the AT+SEND command will look like
AT+SEND=2:0103080404
umutc
(umut)
November 12, 2024, 1:33pm
3
i still didnt get any message
umutc
(umut)
November 12, 2024, 8:45pm
4
char * buf3 = "AT+APPKEY=64A60D27D87E88D65BD7E0B734EDE2F0\r\n";
char * buf15 = "AT+CHE=1:2:3:4:5:6:7:8\r\n";
char * buf17 = "AT+SEND=2:1234\r\n";
char * buf19 = "AT+DCS=1\r\n";
char * buf21 = "ATR\r\n";
char * buf22 = "AT+ADR=1\r\n";
void sendCommand(const char* cmd) {
Serial1.write(cmd); // Komutu gönder
delay(500); // Yeterli zaman ver
String response = ""; // Yanıtı tutacak string
while (Serial1.available() > 0) {
response += char(Serial1.read()); // Yanıtı oku
if (response.length() > 0) {
Serial.println(response); // Yanıtı seri porttan yazdır
void setup() {
Serial1.begin(115200, SERIAL_8N1, 18, 17);
sendCommand("AT+DEBUG=1\r\n");
delay(1500);
//sendCommand(buf21);
sendCommand("ATE\r\n");
delay(3000);
sendCommand("AT+NWM=1\r\n");
delay(1000);
sendCommand("AT+NJM=1\r\n");
delay(1000);
sendCommand("AT+CLASS=A\r\n");
delay(1000);
sendCommand("AT+BAND=5\r\n");
delay(1000);
sendCommand(buf1);
delay(1000);
sendCommand(buf2);
delay(1000);
sendCommand(buf3);
delay(1000);
sendCommand("AT+MASK=0002\r\n");
delay(1000);
sendCommand("AT+CHE=1:2\r\n");
delay(1000);
sendCommand("AT+DR=4\r\n");
delay(1000);
sendCommand("AT+JOIN=1:0:10:8\r\n");
delay(1000);
// Diğer komutlarınızı da ekleyebilirsiniz
void loop() {
// Yine komutları gönderebilirsiniz
// sendCommand(buf17); // AT+SEND komutunu gönder
//delay(1000); // Sabit bir gecikme ile tekrar gönderim yapabilirsiniz
// delay(10000);
sendCommand("AT+SEND=2:0103080404\r\n");
delay(15000);
// sendCommand("AT+NJS=?\r\n");
// UART üzerinden gelen veriyi oku
if (Serial1.available() > 0) {
comdata = "";
comdata += char(Serial1.read()); // Veriyi oku
delay(2);
if (comdata.length() > 0) {
// Gelen veriyi konsola yazdır
Serial.println("Received data: ");
delay(100); // Delay, stabilite için
still same i didnt get any messeage
beegee
(Bernd Giesecke)
November 13, 2024, 5:56am
5
I am guessing you are missing some responses from the RAK3172.
Your implementation of void sendCommand() expects the RAK3172 to respond within 500ms. That is not guaranteed. Some commands can take longer before they respond.
I don’t see as well anywhere that you check the response. Beside of “OK” there can be errors.
Maybe you can have a look at the RUI3-AT-OTAA example. It is using a small (and not perfect) library to communicate from a host MCU with a RAK3172.
umutc
(umut)
November 13, 2024, 1:36pm
6
Thank you for answer @beegee
im using that library
but still not work
Starting loop-through - exit with 'ESC' key
Clear Serial1 RX buffer.
Convert byte array to ASCII array
Result: 000102030405060708090A0B0C0D0E0F
Convert ASCII array to byte array
Result: {00,01,02,03,04,05,06,07,08,09,0A,0B,0C,0D,0E,0F,}
Get version
Ver: RUI_4.0.6_RAK3172-E
OK
LORAWAN mode set already
Get LoRaWAN class
Class 0 (0=A, 1=B, 2=C)
Get LoRaWAN region
Region 5
Get DR
Datarate 4
Get confirmed/unconfirmed mode
Mode 1 = Confirmed
Get LPM
LPM 0 = off
Get LPM level
LPM level 1
Get Join mode
Join mode 1 = OTAA
Get DevEUI
DevEUI: 48E663FFFE300008
Get AppEUI
AppEUI: 48FF000000000008
Get AppKey
AppKey: 64A60D27D87E88D65BD7E0B734EDE2F0
Get Device Address
Device Address: 00000000
Get App Session Key
AppSKey: 00000000000000000000000000000000
Get Network Session Key
NwSKey: 00000000000000000000000000000000
OTAA mode set already
Start Join request
Network join requested
Wait for join
Network not yet joined
Network joined
Set LPM
Set LPM level
Set Datarate
Set confirmed packet mode
Start send packet 1 failed: 0
Wait for TX/RX result
TX success - RX: , UserDataSize 19 PossibleDataSize 242 AdditionalFOptsSize 0
Frequency:902300000
Rx1Frequency:902500000
RxCFrequency:923300000
RxC Datarate:8
ChannelsDatarate:3
AdrAckCounter:0
ChannelsTxPower:0
OK
Start send packet 2 failed: 0
Frequency:902300000
RxC Datarate:8
ChannelsDatarate:3
AdrAckCounter:1
ChannelsTxPower:0
OK
Start send packet 3 failed: 0
Frequency:902300000
RxC Datarate:8
ChannelsDatarate:3
AdrAckCounter:2
ChannelsTxPower:0
OK
Start send packet 4 failed: 0
Frequency:902300000
RxC Datarate:8
ChannelsDatarate:3
AdrAckCounter:3
ChannelsTxPower:0
OK
Start send packet 5 failed: 0
Frequency:902300000
RxC Datarate:8
ChannelsDatarate:3
AdrAckCounter:4
ChannelsTxPower:0
OK
Start send packet 6 failed: 0
Frequency:902300000
RxC Datarate:8
ChannelsDatarate:3
AdrAckCounter:5
ChannelsTxPower:0
OK
Start send packet 7 failed: 0
Frequency:902300000
RxC Datarate:8
ChannelsDatarate:3
AdrAckCounter:6
ChannelsTxPower:0
OK
Start send packet 8 failed: 0
Frequency:902300000
RxC Datarate:8
ChannelsDatarate:3
AdrAckCounter:7
ChannelsTxPower:0
OK
Start send packet 9 failed: 0
Frequency:902300000
RxC Datarate:8
ChannelsDatarate:3
AdrAckCounter:8
ChannelsTxPower:0
OK
Start send packet 10 failed: 0
Frequency:902300000
RxC Datarate:8
ChannelsDatarate:3
AdrAckCounter:9
ChannelsTxPower:0
OK
Start send packet 11 failed: 0
Frequency:902300000
RxC Datarate:8
ChannelsDatarate:3
AdrAckCounter:10
ChannelsTxPower:0
OK
Start send packet 12 failed: 0
Frequency:902300000
RxC Datarate:8
ChannelsDatarate:3
AdrAckCounter:11
ChannelsTxPower:0
OK
Start send packet 13 failed: 0
Frequency:902300000
RxC Datarate:8
ChannelsDatarate:3
AdrAckCounter:12
ChannelsTxPower:0
OK
Start send packet 14 failed: 0
Frequency:902300000
RxC Datarate:8
ChannelsDatarate:3
AdrAckCounter:13
ChannelsTxPower:0
OK
Start send packet 15 failed: 0
Frequency:902300000
RxC Datarate:8
ChannelsDatarate:3
AdrAckCounter:14
ChannelsTxPower:0
OK
umutc
(umut)
November 13, 2024, 7:54pm
7
i dont see any message on Concentrator
beegee
(Bernd Giesecke)
November 14, 2024, 1:33am
8
You are using US915. Are you sure both the node and the gateway and you LNS are set to the same sub-channels?
umutc
(umut)
November 14, 2024, 5:52pm
9
beegee:
LNS
sendCommand("AT\r\n");
delay(3000);
delay(1000);
sendCommand("AT+VER=?\r\n");
delay(1500);
sendCommand("AT+DEBUG=0\r\n");
delay(1500);
delay(1000);
delay(1000);
sendCommand("AT+CLASS=C\r\n");
delay(1000);
delay(1000);
delay(1000);
sendCommand("AT+ADR=1\r\n");
delay(1000);
sendCommand("AT+CFM=1\r\n");
delay(1000);
sendCommand("AT+CHS=904900000\r\n");
delay(1000);
sendCommand("AT+JN1DL=5\r\n");
delay(1000);
sendCommand("AT+JN2DL=5\r\n");
delay(1000);
sendCommand("AT+RX1DL=5\r\n");
delay(1000);
sendCommand("AT+RX2DL=5\r\n");
delay(1000);
sendCommand("AT+RX2DR=8\r\n");
delay(1000);
sendCommand("AT+RX2FQ=923300000\r\n");
delay(1000);
//sendCommand("AT+TTX=4\r\n");
//delay(1000);
sendCommand("AT+DEVEUI=5E9D1E0857CF25F1\r\n");
delay(1000);
sendCommand("AT+APPEUI=5E9D1E0857CF25F1\r\n");
delay(1000);
sendCommand("AT+APPKEY=F921D50CD7D02EE3C5E6142154F274B2\r\n");
delay(1000);
delay(1000);
that working Class A with this settings. but Class C end node not receiving any message when i send hex on chirpstack
