My current issue is:
After sending the payload I wait for the “SendCallback” and go to Sleep. It works most of the times. But, when the extra +EVT:TX_DONE comes it wakes the system up!
I haven’t found a way to detect this and prevent the system from being waked up.
Please, how to handle this extra +EVT:TX_DONE ?
You cannot handle the +EVT:TX_DONE message, it is generated automatically by RUI3 for the AT command interface.
If you setup your code well, this message will only shortly wake-up the device and it will go immediately into sleep again if you use api.system.lpmlvl.set(2); and api.system.lpm.set(1); and do not use the loop.
However, if you are using api.system.sleep.xxxx(yyyy) in your loop(), it is quite difficult.
Check our RUI3-Best-Practices repo for examples for RUI3.
Specially the RUI3-LowPower-Example is a good example how to use RUI3 as an event driven system and achieve lowest power consumption.
You can try to use api.system.lpm.set(1) and api.system.lpm.set(0) to enable/disable the sleep mode if you need to use UART1, but I never used that.
What “interrupt source” do you mean?
If you setup interrupts, you have to define the interrupt handler.
For LoRa/LoRaWAN, only the callbacks mentioned in the documentation are available.
I found a way to use the “api.system.sleep.all()” and not setting the Low Power Mode “api.system.lpm.set(0)”.
It is not the most elegant solution, but is working very well.
In general I retry the sleep command as soon as the system wakes and the reason is different from my expected frequent timer.
I set a flag in my main timer callback:
* Wakeup Timer function to start the short time timers
void WakeupTimer_Callback(void *data)
//Serial.println("Interrupt 10min");
gui8_WakeupSource = 1U; // Wakeup indicated as this timer
api.system.timer.start(RAK_TIMER_1, TASK_500ms, NULL);
api.system.timer.start(RAK_TIMER_2, TASK_100ms, NULL);
And test this flag when the system wakes up, if not set, sleep again:
Serial.println("Going to sleep");
gui8_WakeupSource = 0U; // Reset the flag waiting for the next interrupt
api.system.sleep.all(); // Sleep all
if(gui8_WakeupSource != 1U) {
Serial.println("Sleep again 1...");
api.system.sleep.all(); // Sleep all again, due to unexpected interrupt (UART ??)
Serial.println("Sleep again 2...");
Serial.println("Sleep again 3...");
Serial.println("Sleep again 4...");
Serial.println("Waking up");
I repeated 4 times the sleep again check. During my tests I could see it waking up max 2 times. And most of the times only the first Sleep is executed.
