Hello all,
I’m evaluating the RAK3172-F for a battery-powered application using a fixed 3.0 V or 3.3 V supply.
I found the F-specific supply range in the linked documentation, but would appreciate clarification on the following points. Please specify the applicable hardware revision and RUI3 version.
- Operating voltage
Does the specified 2.3–3.6 V range cover all module functions, including startup, radio operation and external-flash programming/erasing?
Is continuous 3.0 V operation supported across the module’s rated temperature range? Are there additional voltage requirements for firmware updates or flash writes?
- ADC reference and voltage measurement
Is the RAK3172-F ADC reference internally connected to VDD, or can another reference be selected?
If it follows VDD:
- Does analogRead() return raw ADC counts without assuming a 3.3 V reference?
- Is there a supported RUI3 method to read VREFINT and its factory calibration value to compensate for actual supply voltage?
- Does api.system.bat.get() assume a specific board, divider ratio or supply voltage?
Please provide the supported ADC pins, input-voltage limits, recommended source impedance and available sampling-time settings. A minimal F-specific voltage-measurement example would help.
- RF output and current consumption
For the US915 variant, are measured TX-current and conducted-output-power figures available at 3.0 V and 3.3 V, particularly for +20 and +22 dBm settings?
What happens if +22 dBm is requested at 3.0 V? Is the setting limited, or does actual RF output differ from the requested value?
Please also clarify RX and MCU-active current, including the measurement conditions and whether figures include the complete module.
- Sleep current and GPIO states
What firmware settings and peripheral states are required to achieve the specified sleep current? Does that figure include the external flash and TCXO?
Are sleep-current measurements available at 3.0 V and across temperature? Can GPIO outputs retain their states during sleep, and what states should be expected during reset and bootloader operation?
- Startup and brownout behavior
What supply-ramp, decoupling and startup peak-current requirements should a custom PCB follow?
What are the recommended brownout settings, particularly to prevent corruption during flash writes or interrupted firmware updates?
- Max current and voltage requirement while FUOTA
Subhadeep
