After resetting to defaults and going step by step as described still the error “MIC mismatch” comes up.
I used this documentation to set things up: RAK3172 Module Quick Start Guide | RAKwireless Documentation Center
See the commands and values I typed in.
Here you can see the packet that arrived at the gateway (RAK7268).
(see screenshot above)
Here you can see what the TTN log says.
Here you can see what the packet decoder tells us.
To me it looks like the MIC is wrong as calculated by the module.
Is there a firmware update under way? What can I do about this? Thank you.
p.s. I have also a MIC mismatch when using the network server functionality of the RAK7268. So it does not seem to be an issue with TTN.
