I am trying to connect my RAK3172 to TTN by OTAA. But the device join is failing with error “Wait for LoRaWAN join…+EVT:JOIN_FAILED_RX_TIMEOUT” or “Wait for LoRaWAN join…Restricted_Wait_3478478_ms”
Bin File Version: RUI_4.0.1_RAK3172_E
Board Version in Arduino: 4.1.0
My Code:
// Timers
static uint64_t last = 0;
static uint64_t elapsed;
// Frame Counter
uint32_t frame_counter;
// Max Frame Counter
uint32_t max_frame_counter = 264950;
// Frequency Band of LoRa Radio
#define OTAA_BAND (RAK_REGION_IN865)
// EUIs & Keys for LoRaWAN
#define OTAA_APPEUI \
{ 0xXX, 0xXX, 0x75, 0x1B, 0x1E, 0x4E, 0x4B, 0xF0 }
#define OTAA_DEVEUI \
{ 0x70, 0xB3, 0xXX, 0xXX, 0xD0, 0x06, 0x77, 0x9D }
#define OTAA_APPKEY \
{ 0x77, 0x33, 0x12, 0xC6, 0xXX, 0xXX, 0x37, 0xF6, 0x96, 0xEB, 0xXX, 0xXX, 0xBA, 0xD4, 0x8B, 0xD5 }
void setup() {
/* Begin Serial Communication */
Serial.begin(115200, RAK_AT_MODE);
Serial.println("Initializing LoRa Node");
/* LoRa initialization */
// OTAA Device EUI MSB first
uint8_t node_device_eui[8] = OTAA_DEVEUI;
// OTAA Application EUI MSB first
uint8_t node_app_eui[8] = OTAA_APPEUI;
// OTAA Application Key MSB first
uint8_t node_app_key[16] = OTAA_APPKEY;
// Set Network mode to LoRaWAN
if (api.lorawan.nwm.get() != 1) {
Serial.printf("Set Node device work mode %s\r\n",
api.lorawan.nwm.set(1) ? "Success" : "Fail");
api.system.reboot();
if (!api.lorawan.appeui.set(node_app_eui, 8)) {
Serial.printf("LoRaWan OTAA - set application EUI is incorrect! \r\n");
return;
if (!api.lorawan.appkey.set(node_app_key, 16)) {
Serial.printf("LoRaWan OTAA - set application key is incorrect! \r\n");
return;
if (!api.lorawan.deui.set(node_device_eui, 8)) {
Serial.printf("LoRaWan OTAA - set device EUI is incorrect! \r\n");
return;
if (!api.lorawan.band.set(OTAA_BAND)) {
Serial.printf("LoRaWan OTAA - set band is incorrect! \r\n");
return;
if (!api.lorawan.deviceClass.set(RAK_LORA_CLASS_A)) {
Serial.printf("LoRaWan OTAA - set device class is incorrect! \r\n");
return;
if (!api.lorawan.njm.set(RAK_LORA_OTAA)) // Set the network join mode to OTAA
Serial.printf("LoRaWan OTAA - set network join mode is incorrect! \r\n");
return;
if (!api.lorawan.join()) // Join to Gateway
Serial.printf("LoRaWan OTAA - join fail! \r\n");
return;
/** Wait for Join success */
api.lorawan.join();
delay(10000);
if (!api.lorawan.adr.set(0)) {
Serial.printf("LoRaWan OTAA - set adaptive data rate is incorrect! \r\n");
return;
if (!api.lorawan.txp.set(1)) {
Serial.printf("LoRaWan OTAA - set TX power is incorrect! \r\n");
return;
if (!api.lorawan.dr.set(4)) {
Serial.printf("LoRaWan OTAA - set data rate is incorrect! \r\n");
return;
if (!api.lorawan.rety.set(1)) {
Serial.printf("LoRaWan OTAA - set retry times is incorrect! \r\n");
return;
if (!api.lorawan.cfm.set(1)) {
Serial.printf("LoRaWan OTAA - set confirm mode is incorrect! \r\n");
return;
/** Check LoRaWan Status*/
Serial.println("Device Configuration");
Serial.printf("Network working mode = %s\r\n", api.lorawan.nwm.get() ? "LoRaWan" : "P2P");
Serial.printf("Packet is %s\r\n", api.lorawan.cfm.get() ? "CONFIRMED" : "UNCONFIRMED"); // Check Confirm status
Serial.printf("Adaptive data rate is %s\r\n", api.lorawan.adr.get() ? "Enable" : "Disable");
Serial.printf("The transmit power is %d\r\n", api.lorawan.txp.get());
Serial.printf("The data rate is %d\r\n", api.lorawan.dr.get());
switch (api.lorawan.deviceClass.get()) {
case 0:
Serial.println("Device is in Class A");
break;
case 1:
Serial.println("Device is in Class B");
break;
case 2:
Serial.println("Device is in Class C");
break;
Serial.printf("Duty cycle is %s\r\n", api.lorawan.dcs.get() ? "ON" : "OFF"); // Check Duty Cycle status
uint8_t assigned_dev_addr[4] = { 0 };
Serial.printf("Device Address is %02X%02X%02X%02X\r\n", assigned_dev_addr[0], assigned_dev_addr[1], assigned_dev_addr[2], assigned_dev_addr[3]); // Check Device Address
Serial.printf("Uplink period is %ums\r\n", SLEEP_PERIOD);
void loop() {
if ((elapsed = millis() - last) > SLEEP_PERIOD) {
uplink_routine();
last = millis();
stop();
api.system.sleep.all(SLEEP_PERIOD);
void uplink_routine() {
// Custom Code
void recvCallback(SERVICE_LORA_RECEIVE_T *data) {
if (data->BufferSize > 0) {
Serial.print("\r\n");
void joinCallback(int32_t status) {
void sendCallback(int32_t status) {
if (status == 0) {
Serial.println("Successfully sent");
} else {
Serial.println("Sending failed");
Can anyone help me with this issue?
