I have RAK3172 breakout board and using STM32CubeIDE to do low level development. I followed this guide [RAK3172 Module Low Level Development Reference | RAKwireless Documentation Center] and work with Milesight UG model as a LoRaWAN concentrator with Region AS923-1, RX2 Channel Frequency = 923.4 DR2 on both RAK3172 and UG. Following are the outputs of both RAK3172 and UG. Obviously, UG already sent out the JOIN Acceptance msg but RAK3172 does not receive it. I already verified on functions SUBGHZ_Radio_IRQHandler() & HAL_SUBGHZ_IRQHandler(&hsubghz), it indeeds does not generate any received interrupt. Question is there any else i need to check? (note: i already copied and verified these files are modified based on link above: radio_board_if.c , radio_board_if.h , and radio_conf.h
UG
JSON up: {"rxpk":[{"jver":1,"tmst":3782460598,"time":"2023-06-30T04:45:25.738772Z","tmms":1372135543738,"chan":1,"rfch":0,"freq":923.400000,"mid": 8,"stat":1,"modu":"LORA","datr":"SF10BW125","codr":"4/5","rssis":-44,"lsnr":14.5,"foff":-5694,"rssi":-43,"size":23,"data":"AAEBAQEBAQEBfigI/v8JH6w0a2dCBwg="}]}
data [00 01 01 01 01 01 01 01 01 7e 28 08 fe ff 09 1f ac 34 6b 67 42 07 08 ]
Message_Type = Join Request
MHDR = 00
Major = 00
APPEUI = 0101010101010101
DevEUI = <<<STRIPPED>>>>
DevNonce = 6b34
MIC = 67420708
JSON down: {"txpk":{"imme":false,"tmst":3787460598,"freq":923.4,"rfch":0,"powe":16,"modu":"LORA","datr":"SF10BW125","codr":"4/5","ipol":true,"size":17,"data":"IEaxM4W6hDcUprkrR5CZu/8=","brd":0,"ant":0}}
data [20 46 b1 33 85 ba 84 37 14 a6 b9 2b 47 90 99 bb ff ]
Message_Type = Join Accept
MHDR = 20
Major = 00
INFO: [down] PULL_ACK received in 0 ms
sx1250 27 rf_power: 16 idx: 10 pa: 1 ur_pa: 10
RAK3172
APPLICATION_VERSION: V1.3.0
MW_LORAWAN_VERSION: V2.5.0
MW_RADIO_VERSION: V1.3.0
L2_SPEC_VERSION: V1.0.3
RP_SPEC_VERSION: V1-1.0.3
###### AppKey: <<<STRIPPED>>>>
###### NwkKey: 2B:7E:15:16:28:AE:D2:A6:AB:F7:15:88:09:CF:4F:3C
###### AppSKey: 2B:7E:15:16:28:AE:D2:A6:AB:F7:15:88:09:CF:4F:3C
###### NwkSKey: 2B:7E:15:16:28:AE:D2:A6:AB:F7:15:88:09:CF:4F:3C
###### DevEUI: <<<STRIPPED>>>>
###### AppEUI: 01:01:01:01:01:01:01:01
###### DevAddr: 05:55:D4:4A
0s127:TX on freq 923400000 Hz at DR 2
0s512:MAC txDone
5s502:RX_1 on freq 923400000 Hz at DR 2
5s570:IRQ_RX_TX_TIMEOUT
5s572:MAC rxTimeOut
6s502:RX_2 on freq 923400000 Hz at DR 2
6s571:IRQ_RX_TX_TIMEOUT
6s572:MAC rxTimeOut
###### = JOIN FAILED
