RAK3172 P2P SYNCWORD issue
I am using the 2 x RAK3172 in p2p mode. I am using a terminal program to test (no code involved). I can send data back and forth.
When I change the syncword from the default, if it contains a ‘0’ character, I don’t get a RX event at the receiving end.
The new syncword is accepted (both devices) -
AT+SYNCWORD=?
AT+SYNCWORD=0017\r\nOK\r\n
As soon as I change the syncword so that there are no zeros, the packets appear.
Is this expected behaviour? or am I missing something?
Welcome to RAK forum @nigel ,
Can you please share me your P2P settings, payload you try to send as well as the SYNC word? I can try to replicate your setup.
On my testing, 0x0011 and 0x0017 works ok without any issues.
My LoRa P2P setting is AT+P2P=915000000:7:0:0:20:14 and uses RAK3172 Evaluation Board.
Hi, thanks for the reply. When I discovered which parameter that was causing the issue, I reset the modules using ATR and set the work mode to P2P - here is the output from querying the p2p commands using a python script
b'\r\nRAKwireless RAK3172\r\n------------------------------------------------------\r\nVersion: RUI_4.0.6_RAK3172-E\r\nCurrent Work Mode: LoRaWAN.\r\n'
b'OK\r\nRAKwireless RAK3172\r\n------------------------------------------------------\r\nVersion: RUI_4.0.6_RAK3172-E\r\nCurrent Work Mode: LoRa P2P.\r\n'
b'OK\r\n'
AT+UID=?
b'AT+UID=203134573941500500380012\r\nOK\r\n'
AT+CLIVER=?
b'AT+CLIVER=1.5.11\r\nOK\r\n'
AT+VER=?
b'AT+VER=RUI_4.0.6_RAK3172-E\r\nOK\r\n'
AT+LPM=?
b'AT+LPM=0\r\nOK\r\n'
AT+NWM=?
b'AT+NWM=0\r\nOK\r\n'
AT+PFREQ=?
b'AT+PFREQ=867100000\r\nOK\r\n'
AT+PSF=?
b'AT+PSF=7\r\nOK\r\n'
AT+PBW=?
b'AT+PBW=0\r\nOK\r\n'
AT+PCR=?
b'AT+PCR=0\r\nOK\r\n'
AT+PPL=?
b'AT+PPL=200\r\nOK\r\n'
AT+PTP=?
b'AT+PTP=5\r\nOK\r\n'
AT+PBR=?
b'AT_MODE_NO_SUPPORT\r\n'
AT+PFDEV=?
AT+PSEND=?
b'AT_PARAM_ERROR\r\n'
AT+CAD=?
b'AT+CAD=0\r\nOK\r\n'
AT+PRECV=?
b'P2P_RX_OFF\r\nOK\r\n'
AT+ENCRY=?
b'AT+ENCRY=0\r\nOK\r\n'
AT+ENCKEY=?
b'AT+ENCKEY=00000000000000000000000000000000\r\nOK\r\n'
AT+PCRYPT=?
b'AT_COMMAND_NOT_FOUND\r\n'
AT+PKEY=?
AT+CRYPIV=?
b'AT+CRYPIV=00000000000000000000000000000000\r\nOK\r\n'
AT+P2P=?
b'AT+P2P=867100000:7:0:0:200:5\r\nOK\r\n'
AT+IQINVER=?
b'AT+IQINVER=0\r\nOK\r\n'
AT+SYNCWORD=?
b'AT+SYNCWORD=1424\r\nOK\r\n'
AT+RFFREQUENCY=?
b'AT+RFFREQUENCY=867100000\r\nOK\r\n'
AT+TXOUTPUTPOWER=?
b'AT+TXOUTPUTPOWER=5\r\nOK\r\n'
AT+BANDWIDTH=?
b'AT+BANDWIDTH=0\r\nOK\r\n'
AT+SPREADINGFACTOR=?
b'AT+SPREADINGFACTOR=7\r\nOK\r\n'
AT+CODINGRATE=?
b'AT+CODINGRATE=0\r\nOK\r\n'
AT+PREAMBLELENGTH=?
b'AT+PREAMBLELENGTH=200\r\nOK\r\n'
AT+SYMBOLTIMEOUT=?
b'AT+SYMBOLTIMEOUT=0\r\nOK\r\n'
AT+FIXLENGTHPAYLOAD=?
b'AT+FIXLENGTHPAYLOAD=0\r\nOK\r\n'
To perform the test I used Realterm to send the strings - I used AT+PRECV=65533 to put both units in listening mode. Sorry I don’t have copy of the string, it was a modbus request formatted for the RAK. Sorry I didn’t capture the replies from the modules.
I am not sure how I can help further.
  1. The sync word you use seems ok AT+SYNCWORD=1424
  2. Your FW version is too old. I recommend you update to the latest one.
More info about SYNC word.
Hi, thanks for your reply. Re. SYNC word, that makes sense and covers my issue.
Re. firmware, where can I find the latest version with the changelog to see if it applies to P2P mode?
You can check FW and change logs here - Release Versions | RAKwireless Documentation Center
Hi
Looking at the firmware available, which version of the 3172 do I use? I have the 3172 not the T variant and I’m not using the E evaluation board.
For standard RAK3172, you must use the RAK3172 Evaluation Board.
