RAK3172 Reset to Factory Defaults
I was trying to set the baud rate to 115.2kbps, but I accidentally set the baud rate to something like 115bps. At least that is what I measured looking at the bit time during the power-on boot message.
I have tried using CoolTerm custom baud rate to communicate, but no luck. I was going to re-flash it, but the tool doesn’t work for this baud rate.
Any ideas before I scrap the board?
Thanks,
Russ
If you have a JLink or a DAPlink adapter, you could do a chip erase (deletes your factory credentials as well !!! ) and then flash a new RUI3 firmware.
Thank you for your reply. Since the part was “in circuit”, it was just easier to remove and replace it. It only took 10 minutes.
And I have learned from a mistake that I will not make again!
Thanks “Beegee” for all the content you put onto this forum. Very helpful!
Russ
