HI,guys,I am using RAK3172 to control MCP3913 for data acquisition, using SPI for communication, but the information I receive using SPI.transfer() function is always FFFFFF (receiving 24-bit data), and I am using this function to read other data with the same problem as mentioned above, I would like to ask if it’s a problem with my SPI settings?
#include "Arduino.h"
#include <SPI.h>
int val_1 = 0;
uint8_t test_0 ;
uint8_t test_1 ;
uint8_t test_2 ;
uint8_t test_3 ;
void setup() {
// put your setup code here, to run once:
SPI.begin();
pinMode(PB2, INPUT);
pinMode(PB12, OUTPUT);
pinMode(PA4, OUTPUT);
digitalWrite(PA4, HIGH);
MCP3913_Init();
void loop() {
// put your main code here, to run repeatedly:
//if(i == 0){
SPI.beginTransaction(SPISettings(1000000, MSBFIRST, SPI_MODE0));
//发送读取命令
digitalWrite(PA4, LOW);
delayMicroseconds(10);
SPI.transfer(0x01); // 读寄存器命令
uint8_t receivedVal_0H = SPI.transfer(0x00);
uint8_t receivedVal_0M = SPI.transfer(0x00);
uint8_t receivedVal_0L = SPI.transfer(0x00); //
uint8_t receivedVal_1H = SPI.transfer(0x00); //
uint8_t receivedVal_1M = SPI.transfer(0x00); //
uint8_t receivedVal_1L = SPI.transfer(0x00); //
uint8_t receivedVal_2H = SPI.transfer(0x00); //
uint8_t receivedVal_2M = SPI.transfer(0x00); //
uint8_t receivedVal_2L = SPI.transfer(0x00); //
uint8_t receivedVal_3H = SPI.transfer(0x00); //
uint8_t receivedVal_3M = SPI.transfer(0x00); //
uint8_t receivedVal_3L = SPI.transfer(0x00); //
uint8_t receivedVal_4H = SPI.transfer(0x00); //
uint8_t receivedVal_4M = SPI.transfer(0x00); //
uint8_t receivedVal_4L = SPI.transfer(0x00); //
uint8_t receivedVal_5H = SPI.transfer(0x00); //
uint8_t receivedVal_5M = SPI.transfer(0x00); //
uint8_t receivedVal_5L = SPI.transfer(0x00); //
uint32_t adcData0 = (receivedVal_0H << 16) | (receivedVal_0M << 8) | receivedVal_0L;
uint32_t adcData1 = (receivedVal_1H << 16) | (receivedVal_1M << 8) | receivedVal_1L;
uint32_t adcData2 = (receivedVal_2H << 16) | (receivedVal_2M << 8) | receivedVal_2L;
uint32_t adcData3 = (receivedVal_3H << 16) | (receivedVal_3M << 8) | receivedVal_3L;
uint32_t adcData4 = (receivedVal_4H << 16) | (receivedVal_4M << 8) | receivedVal_4L;
uint32_t adcData5 = (receivedVal_5H << 16) | (receivedVal_5M << 8) | receivedVal_5L;
Serial.print("ADC ");
Serial.print(0);
Serial.print(": ");
Serial.println(adcData0);
Serial.print(1);
Serial.print(": ");
Serial.println(adcData1);
Serial.print(2);
Serial.print(": ");
Serial.println(adcData2);
Serial.print(3);
Serial.print(": ");
Serial.println(adcData3);
Serial.print(4);
Serial.print(": ");
Serial.println(adcData4);
Serial.print(5);
Serial.print(": ");
Serial.println(adcData5);
// Serial.println(test_0);
// Serial.println(test_1);
// Serial.println(test_2);
// Serial.println(test_3);
void MCP3913_Init() {
// digitalWrite(PB12, LOW);
// delay(1);
// digitalWrite(PB12, HIGH);
SPI.transfer(0x14);//
SPI.transfer(0xC9);
SPI.transfer(0x00);
SPI.transfer(0x00);
delay(1);
SPI.transfer(0x1A);
SPI.transfer(0x38);
SPI.transfer(0x60);
SPI.transfer(0x50); //
delay(1);
SPI.transfer(0x1E);
SPI.transfer(0x00);
SPI.transfer(0x00);
SPI.endTransaction();
