and now, after power cycle the RAK3172-T module, I am getting the error message +EVT:JOIN_FAILED_TX_TIMEOUT. refer to snapshot below and this keeps on repeating despite several retries, at first i thought it might be a Gateway issue, but not!! my gateway is up and running, as I can see live traces for other devices except for this RAK3172-T module.
I did a test with another RAK3172-T module and this issue keeps on repeating, that is the device first connect to TTN and after power cycling getting +EVT:JOIN_FAILED_TX_TIMEOUT
Can someone please advise what is the issue please?.
I have checked the DevEUI, AppEUI & AppKey for the RAK3172-T Modules having this issue, they are still the same, even the LoRaWAN region is set to AT+BAND=4, which is EU868 and is correct.
the only change I can see is highlighted in the snapshot below.
Before:
After:
I have attached the part of my code that is the setup part.
void setup(){
Serial.begin(115200);while(!Serial){}
//MCP23017 I2C setup
Wire.begin();delay(500);
Wire.beginTransmission(0x20);
mcp23017_activeStatus = Wire.endTransmission();
write_SingleRegister(IODIRA, 0xFF); //pinA configured as input
write_SingleRegister(IODIRB, 0xFF); //pinB configured as input
write_SingleRegister(IPOLA, 0xFF); //pinA opposite state of input
write_SingleRegister(IPOLB, 0xFF); //pinB opposite state of input
write_SingleRegister(GPINTENA, 0xFF); //enable pinA for interrupt on change event
write_SingleRegister(GPINTENB, 0xFF); //enable pinB for interrupt on change event
write_SingleRegister(DEFVALA, 0xFF); //default value set to 1 pull-up configured
write_SingleRegister(DEFVALB, 0xFF); //default value set to 1 pull-up configured
write_SingleRegister(INTCONA, 0x00); //pin value is compared against the previous value
write_SingleRegister(INTCONB, 0x00); //pin value is compared against the previous value
byte temp=read_SingleRegister(IOCON);
write_SingleRegister(IOCON,temp|=0x42); //INT pin combines INTA+INTB, set polarity of INT pin to Active-High
write_SingleRegister(GPPUA, 0xFF); //pull-up enabled for PINA
write_SingleRegister(GPPUB, 0xFF); //pull-up enabled for PINB
//Led Indication
// pinMode(RAK3172_LEDPIN, OUTPUT);
// digitalWrite(RAK3172_LEDPIN, LOW);
//Interrupt
pinMode(RAK3172_INTPIN, INPUT);
attachInterrupt(RAK3172_INTPIN, interruptEvent, RISING);
//LoRaWAN Setup
api.lorawan.deviceClass.set(RAK_LORA_CLASS_A); //set to class A mode.
api.lorawan.njm.set(RAK_LORA_OTAA); //network join mode-OTAA
api.lorawan.cfm.set(false); //confirm msg disabled
api.lorawan.band.set(4); //EU868
api.lorawan.dr.set(5);
api.lorawan.registerRecvCallback(recv_cb);
api.lorawan.registerJoinCallback(join_cb);
api.lorawan.registerSendCallback(send_cb);
api.lorawan.join();
while(api.lorawan.njs.get()==0){Serial.print("Lorawan join req...");api.lorawan.join();delay(10000);}
api.lorawan.adr.set(true); //adaptive data rate enabled
construct_lora_pkt(0x01);
mcp23017_pinAB_prev=mcp23017_pinAB;
api.lorawan.send(sizeof(lora_payload), lora_payload, 129);
if(api.system.timer.create(RAK_TIMER_0, (RAK_TIMER_HANDLER)heartBeat, RAK_TIMER_PERIODIC) != true){Serial.printf("LoRaWan- Creating timer failed.\r\n");return;}
if(api.system.timer.start(RAK_TIMER_0, TIME_INTERVAL, NULL) != true){Serial.printf("LoRaWan- Starting timer failed.\r\n");return;}
//startTime=millis();
Thanks for your swift response and your usual support.
Yes exactly, I used the same code that is available on the RUI3 API available in RAK Documentation Center.
I did apply the AT+JOIN=0:0 like you mentioned before. Still no change notice.
Another thing to note here is that I cannot see the Join Request Packets on TTN sent from the RAK3172-T to my Gateways in total I have 3 Gateways.
Note: earlier I used the RAK3172 Breakout Board ( SKU: 316043) to carry on all my tests with success. I am now using the same arduino code on this RAK3172-T and I have having this issue and this happened with the 3rd RAK3172-T module that I have tested this morning.
Can you please help, as we have a custom PCB already implemented with the RAK3172-T module.
