May I kindly request the test report for Rak3172(H)? This information is essential as we are integrating it into our product, and having the test report is crucial for our product certification process.
Welcome to RAK forum @Vikas_Bhatt
On what particular certificate test report you need? Would that be FCC, RED, etc.?
We require the test reports for FCC, CE, and UL certifications.
Hi @Vikas_Bhatt ,
I message you my email via direct message here in forum. Please send me an email for the request then I’ll coordinate.
hi Carl, we have designed a GW using the RAK2287 module and all things are working ok. Now it is time to do the CE/RED tests and within some months also FCC tests for the complete product. As I understand, this module has some certificates used with a calibrated antenna and standard LoRa software. From our earlier experience of RED testing (telecom and ISM), there will be a requirement from the CB(test house) that we provide support software to configure the RF parts to do some predefined transmissions in the ISM bands (868,915Mhz), Do you have software(or examples) that would make this test process easier - and certificates from your earlier tests we can provide to CB ? Another test that perhaps may require specialized software is BER (error rate) of the link when applied external EM field to test immunity and recover perhaps also from cable bound external energy… do you have such software (examples) also ?
thanks, kjell
Welcome to RAK forum @kjell_upwis ,
I have to check with from our certification engineer. I’ll update you asap once I got the details.
Hi Carl,
Thanks this is good news. Actaully, we are a long time customer of RAK, I just have not used this forum earlier !
Vänliga hälsningar/Best regards
Kjell Brunberg, CEO, mobile +46(0)733660707, office +46(0)184957090, email: [email protected] , http://www.upwis.com
Office and delivery adress: Kungsgatan 16, SE 753 32 Uppsala, Postal address: Box 3000, SE 750 03 Uppsala, Sweden
This e-mail message together with attachement(s) is confidential and intended solely for the adressee(s). Any unauthorized review, use or distribution is prohibited. If you believe this message has been sent to you in error, please notify the sender by replying to above and delete the message without disclosing it.
-------- Originalmeddelande --------
