I’ve been trying to connect to an external I2C eeprom memory using the Wire library in Arduino.
This is my hardware configuration:
SCL → PA12
SDA → PA11
I2C pull up → 2K2
This is my code:
RUI version 4.2.0
#include <Arduino.h>
#include <Wire.h>
#define I2C_ADDR 0x55
bool halI2c_Read (uint8_t addr, uint8_t regAddr, uint8_t *data, size_t size)
Wire.beginTransmission(addr);
Wire.write(regAddr);
Wire.endTransmission(false);
size_t bytesToRead = Wire.requestFrom (addr, size);
if ( 0 == bytesToRead || bytesToRead != size )
Serial.printf("Error reading... expected: %d and available %d\r\n", size, bytesToRead);
return false;
size_t bytesRead = Wire.readBytes(data, bytesToRead);
if ( bytesRead != bytesToRead )
Serial.printf("Error! Read %d and requested %d", bytesRead, bytesToRead);
return ( bytesRead == bytesToRead ) ? true : false;
bool halEeprom_Id (void)
uint8_t id;
bool rc = halI2c_Read(I2C_ADDR, 0, &id, 1);
if ( true == rc && 0x04 == id )
Serial.println("Eeprom detected!");
rc = true;
else
Serial.println("Eeprom not detected !!!!!!!");
rc = false;
return rc;
void setup()
Wire.begin();
Wire.setClock(100000);
void loop()
delay(1000);
bool detected = halEeprom_Id();
if ( true == detected )
Serial.println("NFC detected!");
else
Serial.println("NFC not detected");
The code doesn’t detect the external eeprom. I’ve checked it with an ESP32, using the same code, and it’s working, so I checked with the scope the SCL signal
This is the SCL signal with the RAK3172LP-SiP
This is the SCL signal with the ESP32
The clock is not generated correctly in the RAK3172.
I’m sure I’m doing something wrong, but I cannot see what.
Anyone could help me.
Thank you
Regards,
David
