Hey, i was in the page from the RAK3212 featuring RAK3112. I wanted the 3d file for a design, but when clicking on the link in leads nowhere. Can you share the 3d file for RAK3212.
Seems the file is missing in the Download Center. I will check with our team.
In the meantime, I attached the STEP file.
3D-RAK3212.zip (623.6 KB)
Hi, do you have the STEP file of the module itself? RAK3112 LoRaWAN Module with Wi-Fi & BLE | Low Power IoT MCU
The attached STEP file in the first post should cover the RAK3212 board outline, so that may be what you need rather than going through the Download Center again. For the RAK3112 module itself, the reply pointing to the Download Center’s 3D_File section is probably the right place to look, since the module geometry is often packaged separately from the carrier board. If the STEP inside the zip only shows the board without the module, it’s worth asking the team whether a combined assembly exists, as that matters for enclosure clearance checks.
