I have a gateway module based on sx1302 which is on the band of EU868. I am trying to connect my RAK3272 modules to the gateway via following LoRaWan_Class_B example. I have changed the OTAA_DEVUI and OTAA_APPEUI with the concentrator EUI. What might I have missing?
Why would you change the DevEUI and AppEUI to the concentrators EUI? That makes no sense at all.
Do you have you concentrator connected to a LoRaWAN server?
You have to setup an application on the LoRaWAN server and register the device there with it’s own DevEUI/AppEUI and AppKey. They came pre-flashed with the device. But you can use any other EUI/Key combination of course.
You have to choose in the LoRaWAN server the EU868 region as well.
*Yes I setup the RAK3172 to EU868 Band.
*No I did not setup the LoRaWAN Server. I thought that I can do it through the concentrater without needing to an Server. I am using packet forwarder script and it’s forwarding packets to the localhost. If it’s not too much to ask, is there a way that I can do without public LoRaWan Server like TTN. I would like to use concentrator as server.
Thank you in advence
