Issue: I am using the RAK Wireless Breakout Board with the code example from this Github Repo, DEMO_1. I am unable to join the network with my breakout device. I am repeatly getting a “Joining Denied” response.
Setup: I was able to successfully upload and the install the device software. I am able to access the program and request the device to join the network. I used a working Chirpstack and also tested another vendor outside of TTN to run this demo with. Other development devices using a different chip work with these gateways and networks. I used the deviceEUI on the chip itself, and the default application key and application eui which was changed in the conf_app.h file.
Details: It’s likely due to some configuration issue or other incompatibility, but would like to know if anyone has an idea to do any of the following.
- Get more detailed information about why the request is being denied.
- Change any setting which may be effecting the decline.
Thank you in advanced.
