RAK5860 WisBlock Nb-Iot BG77 Series GNSS
Hi
Any RAKWireless technical Team member have some advices/examples about using GPS functionality of the RAK5860 ?
I read the Quectel BG77 documentation, but the recommended AT commands are not work with RAK5860.
Any idea/recommendation are welcome !
I can’t use LoraWan at remote farms/sea for individual assets GPS tracking ! …
Zoltan Magdo
Hi @magdoz59,
I’m following your request as this is my next step too to take after I got a valid WAN connection.
BR,
Jeroen
Hi Jeroen
I also followed your AT commands. Got connection to Hologram and MQTT Broker. Thanks.
I read/tried everything with my RAK5860 GNSS, but alvays I got +CME ERROR : 516 // No fix
I have no more ideas to try !
Zoltan
can you share your code/commands so I can check if my device got a fix or not?
From the Quectel documentation I understand that GPS on the BG77 has a conflict with normal usage.
But I have no example how to solve it.
I talked with the SW team. They will look into it,
Hi Bernd
Thank You. Yes, I read the documentation and tried to use the AT+QGPSCFG=“priority”, 0 AT command but without any success.
It’s very urgent for me, all my project with WisBlock pending …
Zoltan
Hi Jeroen
I can share my code to You Dear, no problem, but to save your time, I have to tell you, I tested same code on many different WisBlocks with same results. I have 10pce of them to do testing…
Bernd: “I talked with the SW team. They will look into it,”
I’m wondering how much time days/weeks/… will take ?
Zoltan
Hi Jeroen
I think, our conversation was deleted ! Never mind…
The issue still persist and my projects/invested money goes nowhere !
Zoltan
Hi Friends,
Some news about BG77 GNSS usage with the RAK5860 ?
In this business no sleep ! I practiced this for over 35y.
Zoltan
Hi Bernd
Any news from the “SW Team” regarding the GNSS not fix issue ?
Zoltan Magdo
Hi
It’s something specific what it’s need to be set at RAK5860 WisBlock module to use the GNSS functionality ?
I used the Quectel recommendations to setup my RAK5860 with the following code:
#define BG77_POWER_KEY 17
String bg77_rsp = “”;
//this function is suitable for most AT commands of bg96. e.g. bg96_at(“ATI”)
void bg77_at(char *at, uint16_t timeout)
char tmp[256] = {0};
int len = strlen(at);
strncpy(tmp, at, len);
uint16_t t = timeout;
tmp[len] = ‘\r’;
Serial1.write(tmp);
delay(10);
while (t–)
if (Serial1.available())
bg77_rsp += char(Serial1.read());
delay(1);
Serial.println(bg77_rsp);
bg77_rsp = “”;
void ping_at(char *at)
uint16_t timeout = 10000;
tmp[len] = ‘\r’;
Serial1.write(tmp);
delay(10);
while (timeout–)
delay(1);
bg77_rsp = “”;
void setup()
// Open serial communications and wait for port to open:
while (!Serial)
delay(10); // for nrf52840 with native usb
Serial.println(“RAK5860 Cellular TEST With Hologram sim card!”);
//BG77 init
pinMode(BG77_POWER_KEY, OUTPUT);
digitalWrite(BG77_POWER_KEY, 0);
delay(1000);
digitalWrite(BG77_POWER_KEY, 1);
delay(2000);
Serial1.begin(115200);
delay(1000);
Serial.println("BG77 power up!");
bg77_at("ATI", 500);
delay(2000);
//Cellular
Serial.println("**Start Setup Cellular ");
bg77_at(“AT+CGDCONT=1,“IP”,“hologram””, 500);
delay(2000);
bg77_at(“AT+CGACT?”, 500);
delay(2000);
bg77_at(“AT+COPS=1,2,“53001"”, 1000);
delay(2000);
bg77_at(“AT+CFUN=1,0”, 500);
delay(2000);
bg77_at(“AT+CPIN?”, 500);
delay(2000);
bg77_at(“AT+QNWINFO”, 500);
delay(2000);
bg77_at(“AT+QCSQ”, 500);
delay(2000);
bg77_at(“AT+CSQ”, 500);
delay(2000);
bg77_at(“AT+QIACT=1”, 3000);
delay(2000);
Serial.println(”**End Setup Cellurar “);
// GPS
Serial.println(”**Start Setup GPS ");
bg77_at(“AT+QGPS?”, 1000);
delay(2000);
bg77_at(“AT+QPSMS?”, 1000);
delay(2000);
bg77_at(“AT+CPSMS=0”, 1000);
delay(2000);
// bg77_at(“AT+QGPSCFG=“priority”,0”, 1000);
// delay(2000);
bg77_at(“AT+QGPSEND”, 1000);
delay(2000);
bg77_at(“AT+QGPS=1”, 1000);
delay(2000);
Serial.println("Begin receive GPS Data ! ");
void loop() // run over and over//
bg77_at(“AT+QGPSLOC?”, 2000);
The result is:
11:19:59.270 -> RAK5860 Cellular TEST With Hologram sim card!
11:20:03.234 -> BG77 power up!
11:20:03.749 ->
11:20:03.749 -> RDY
11:20:03.749 ->
11:20:03.749 -> +CFUN: 1
11:20:03.749 ->
11:20:03.749 -> +QSIMSTAT: 1,1
11:20:03.749 ->
11:20:03.749 -> +CPIN: READY
11:20:03.749 ->
11:20:03.749 -> +QUSIM:
11:20:05.752 -> **Start Setup Cellular
11:20:06.264 ->
11:20:06.264 -> APP RDY
11:20:06.264 -> AT+CGDCONT=1,“IP”,“hologram”
11:20:06.264 -> OK
11:20:06.264 ->
11:20:08.736 -> AT+CGACT?
11:20:08.736 -> +CGACT: 1,0
11:20:08.736 -> +CGACT: 2,0
11:20:08.736 ->
11:20:08.736 -> OK
11:20:08.736 ->
11:20:11.718 -> AT+COPS=1,2,“53001”
11:20:14.240 ->
11:20:14.240 -> OK
11:20:14.240 ->
11:20:16.714 -> AT+CPIN?
11:20:16.714 -> +CPIN: READY
11:20:16.714 ->
11:20:16.714 -> OK
11:20:16.714 ->
11:20:19.229 -> AT+QNWINFO
11:20:19.229 -> +QNWINFO: “eMTC”,“53001”,“LTE BAND 3”,1917
11:20:19.229 ->
11:20:19.229 -> OK
11:20:19.229 ->
11:20:21.704 -> AT+QCSQ
11:20:21.704 -> +QCSQ: “eMTC”,-83,-105,194,-8
11:20:21.704 ->
11:20:21.704 -> OK
11:20:21.704 ->
11:20:24.224 -> AT+CSQ
11:20:24.224 -> +CSQ: 15,99
11:20:24.224 ->
11:20:24.224 -> OK
11:20:24.224 ->
11:20:29.166 -> AT+QIACT=1
11:20:29.166 -> OK
11:20:29.166 ->
11:20:31.175 -> **End Setup Cellurar
11:20:31.175 -> **Start Setup GPS
11:20:32.156 -> AT+QGPS?
11:20:32.156 -> +QGPS: 1
11:20:32.156 ->
11:20:32.156 -> OK
11:20:32.156 ->
11:20:35.141 -> AT+QPSMS?
11:20:35.141 -> +QPSMS: 0,“0”,“0”
11:20:35.141 ->
11:20:35.141 -> OK
11:20:35.141 ->
11:20:38.128 -> AT+CPSMS=0
11:20:38.128 -> OK
11:20:38.128 ->
11:20:41.116 -> AT+QGPSCFG=“priority”,0
11:20:41.116 -> OK
11:20:41.116 ->
11:20:44.102 -> AT+QGPSEND
11:20:47.091 ->
11:20:47.091 -> OK
11:20:47.091 -> AT+QGPS=1
11:20:49.098 -> Begin receive GPS Data !
11:20:51.056 ->
11:20:53.015 ->
11:20:54.971 ->
11:20:56.930 ->
11:20:58.916 ->
11:21:00.900 ->
11:21:02.811 ->
11:21:04.773 ->
11:21:06.737 ->
11:21:08.692 ->
11:21:10.698 ->
11:21:12.659 ->
11:21:14.618 ->
11:21:14.618 -> OK
11:21:14.618 ->
11:21:16.576 -> AT+QGPSLOC?
11:21:16.576 -> +CME ERROR: 516
11:21:16.576 ->
11:21:18.541 -> AT+QGPSLOC?
11:21:18.541 -> +CME ERROR: 516
11:21:18.541 ->
11:21:20.496 -> AT+QGPSLOC?
11:21:20.496 -> +CME ERROR: 516
11:21:20.496 ->
11:21:22.454 -> AT+QGPSLOC?
11:21:22.454 -> +CME ERROR: 516
11:21:22.454 ->
11:21:24.409 -> AT+QGPSLOC?
11:21:24.409 -> +CME ERROR: 516
11:21:24.409 ->
11:21:26.370 -> AT+QGPSLOC?
11:21:26.370 -> +CME ERROR: 516
11:21:26.370 ->
11:21:28.335 -> AT+QGPSLOC?
11:21:28.335 -> +CME ERROR: 516
11:21:28.335 ->
11:21:30.292 -> AT+QGPSLOC?
11:21:30.292 -> +CME ERROR: 516
11:21:30.292 ->
11:21:32.253 -> AT+QGPSLOC?
11:21:32.253 -> +CME ERROR: 516
11:21:32.253 ->
11:21:34.213 -> AT+QGPSLOC?
11:21:34.213 -> +CME ERROR: 516
11:21:34.213 ->
11:21:36.176 -> AT+QGPSLOC?
11:21:36.176 -> +CME ERROR: 516
11:21:36.176 ->
11:21:38.180 -> AT+QGPSLOC?
11:21:38.180 -> +CME ERROR: 516
11:21:38.180 ->
11:21:40.144 -> AT+QGPSLOC?
11:21:40.144 -> +CME ERROR: 516
11:21:40.144 ->
11:21:42.106 -> AT+QGPSLOC?
11:21:42.106 -> +CME ERROR: 516
11:21:42.106 ->
11:21:44.083 -> AT+QGPSLOC?
11:21:44.083 -> +CME ERROR: 516
11:21:44.083 ->
11:21:45.990 -> AT+QGPSLOC?
11:21:45.990 -> +CME ERROR: 516
11:21:45.990 ->
11:21:47.980 -> AT+QGPSLOC?
11:21:47.980 -> +CME ERROR: 516
11:21:47.980 ->
11:21:49.943 -> AT+QGPSLOC?
11:21:49.943 -> +CME ERROR: 516
11:21:49.943 ->
11:21:51.908 -> AT+QGPSLOC?
11:21:51.908 -> +CME ERROR: 516
11:21:51.908 ->
11:21:53.878 -> AT+QGPSLOC?
11:21:53.878 -> +CME ERROR: 516
11:21:53.878 ->
11:21:55.840 -> AT+QGPSLOC?
11:21:55.840 -> +CME ERROR: 516
11:21:55.840 ->
11:21:57.801 -> AT+QGPSLOC?
11:21:57.801 -> +CME ERROR: 516
11:21:57.801 ->
11:21:59.766 -> AT+QGPSLOC?
11:21:59.766 -> +CME ERROR: 516
11:21:59.766 ->
11:22:01.728 -> AT+QGPSLOC?
11:22:01.728 -> +CME ERROR: 516
11:22:01.728 ->
11:22:03.687 -> AT+QGPSLOC?
11:22:03.687 -> +CME ERROR: 516
11:22:03.687 ->
11:22:05.648 -> AT+QGPSLOC?
11:22:05.648 -> +CME ERROR: 516
11:22:05.648 ->
11:22:07.607 -> AT+QGPSLOC?
11:22:07.607 -> +CME ERROR: 516
11:22:07.607 ->
11:22:09.607 -> AT+QGPSLOC?
11:22:09.607 -> +CME ERROR: 516
11:22:09.607 ->
11:22:11.523 -> AT+QGPSLOC?
11:22:11.523 -> +CME ERROR: 516
How I get the GPS Data ?
Zoltan
Hi
No solution until end of February ! The RAK SoftwareTeam don’t have a solution…
Please, If somebody find a solution, share to us !
Zoltan
Dear RAK team,
As I also want to proceed with this module (GPS function), is any update available?
Also please report when it is a hardware bug or something RAK cannot fix yet.
thanks Jeroen
(Happy Chinese New Year in advance!)
Here is an example for RAK5860 to use data connection and collect GPS coordinates.
It is only tested by our SW team. I cannot verify, because the RAK5860 is not working in my country.
Please report any problems with the sketch. Once confirmed it works, we will add this to the WisBlock repo.
Sorry for copying the code here, but I cannot attach sketch files:
   @file Hologram_Tcp.ino
   @author rakwireless.com
   @brief BG77 tcp test with Hologram, send gps data to server
   @version 0.1
   @date 2020-12-28
   @copyright Copyright (c) 2020
String bg77_rsp = "";
//Hologarm tcp message format is jason. Remember to replace the card key in type k.
//About key details: https://support.hologram.io/hc/en-us/articles/360035212714-Device-keys
//About message details: https://www.hologram.io/references/embedded-apis#send-a-message-to-the-hologram-cloud
String hologram_msg_pre = "{\"k\":\"+C7pOb8=\",\"d\":";
String hologram_msg_suff = ",\"t\":\"TOPIC1\"}";
String hologram_msg = "";
String send_data_length_at = "";
String gps_data = "";
void setup()
  while (!Serial)
    if ((millis() - serial_timeout) < 5000)
      delay(100);
    else
      break;
  Serial.println("RAK11200 Cellular TEST With Hologram sim card!");
  //BG77 init , Check if the modem is already awake
  time_t timeout = millis();
  bool moduleSleeps = true;
  delay(1000);
  Serial1.println("ATI");
  //BG77 init
  while ((millis() - timeout) < 4000)
      String result = Serial1.readString();
      Serial.println("Modem response after start:");
      Serial.println(result);
      moduleSleeps = false;
  if (moduleSleeps)
    // Module slept, wake it up
    delay(1000);
    delay(2000);
    delay(1000);
  //active and join to the net, this part may depend on some information of your operator.
  bg77_at("AT+CFUN=1,0", 500);
  delay(2000);
  bg77_at("AT+CPIN?", 500);
  delay(2000);
  bg77_at("AT+QNWINFO", 500);
  delay(2000);
  bg77_at("AT+QCSQ", 500);
  delay(2000);
  bg77_at("AT+CSQ", 500);
  delay(2000);
  bg77_at("AT+QIACT=1", 3000);
  delay(2000);
  //open tcp link with Hologram server
  bg77_at("AT+QIOPEN=1,0,\"TCP\",\"cloudsocket.hologram.io\",9999,0,1", 5000);
  delay(2000);
//this function is suitable for most AT commands of bg96. e.g. bg96_at("ATI")
  int gps_count = 100;
  tmp[len] = '\r';
  if(strstr(tmp,"AT+QGPSLOC?") != NULL)
    while (gps_count--)
      t = timeout;
      Serial1.write(tmp);
      while (t--)
          gps_data += char(Serial1.read());
        delay(1);
      if(strstr(gps_data.c_str(),"OK") != NULL)
        break;
      if(strstr(gps_data.c_str(),"CME ERROR") != NULL)
        gps_data = "";
      delay(100);
    return;
  Serial1.write(tmp);
  delay(10);
  while (t--)
    delay(1);
  bg77_rsp = "";
void send_test_data()
  //open gps, gsm/nb will stop work now
  bg77_at("AT+QGPS=1,1", 1000);
  //get gps data, this will cost some time
  bg77_at("AT+QGPSLOC?", 1000);
  //close gps
  bg77_at("AT+QGPSEND", 1000);
  //combine the data packet
  hologram_msg = hologram_msg_pre+gps_data+hologram_msg_suff;
  gps_data = "";
  //send data length command
  send_data_length_at = "AT+QISEND=0," + hologram_msg.length();
  strncpy(tmp, send_data_length_at.c_str(), send_data_length_at.length());
  bg77_at(tmp, 3000);
  delay(2000);
  //send data
  memset(tmp,0,256);
  strncpy(tmp, hologram_msg.c_str(), hologram_msg.length());
  bg77_at(tmp, 1000);
  delay(1000);
void loop()
  Serial.println("Send test data to Hologram via TCP!");
  send_test_data();
  //consider the gps fix time, interval should be long
  delay(300000);
Thank You Bernd
Just saw your post. I will check tomorrow morning and feedback my test results/
Zoltan
HI
Bad news. No GPS fix If I run your code. I got Error code 516 and no GPS data…
13:04:21.788 → RAK11200 Cellular TEST With Hologram sim card!
13:04:25.755 → Modem response after start:
13:04:25.755 → ATI
13:04:25.755 → Quectel
13:04:25.755 → BG77
13:04:25.755 → Revision: BG77LAR02A02
13:04:25.755 →
13:04:25.755 → OK
13:04:25.755 →
13:04:25.755 → BG77 power up!
13:04:26.275 → AT+CFUN=1,0
13:04:26.275 → OK
13:04:26.275 →
13:04:28.759 → AT+CPIN?
13:04:28.759 → +CPIN: READY
13:04:28.759 →
13:04:28.759 → OK
13:04:28.759 →
13:04:31.259 → AT+QNWINFO
13:04:31.259 → +QNWINFO: “eMTC”,“53001”,“LTE BAND 3”,1917
13:04:31.259 →
13:04:31.259 → OK
13:04:31.259 →
13:04:33.770 → AT+QCSQ
13:04:33.770 → +QCSQ: “eMTC”,-79,-100,202,-7
13:04:33.770 →
13:04:33.770 → OK
13:04:33.770 →
13:04:36.261 → AT+CSQ
13:04:36.261 → +CSQ: 17,99
13:04:36.261 →
13:04:36.261 → OK
13:04:36.261 →
13:04:41.216 → AT+QIACT=1
13:04:41.216 → ERROR
13:04:41.216 →
13:04:48.071 → AT+QIOPEN=1,0,“TCP”,“cloudsocket.hologram.io”,9999,0,1
13:04:48.071 → OK
13:04:48.071 →
13:04:48.071 → +Q,
13:04:50.086 → Send test data to Hologram via TCP!
13:04:51.057 → AT+QGPS=1,1
13:04:56.264 → AT+QGPSEND
13:04:56.264 → OK
13:04:56.264 →
13:04:56.264 → *** hologram_msg: {“k”:“j%fe$L8l”,“d”:
13:04:56.264 → OK
13:04:56.264 → ,“t”:“TOPIC1”}
13:04:59.222 →
13:05:02.211 →
Is this the complete log?
I do not see the ‘AT+QGPSLOC?’ in your log file.
I will forward the log to our R&D, but I want to make sure it is complete. They tested at their location (China) and it worked.
give empty string as You can see the hologram_msg .
I inserted one extra debug line to print the hologram_msg
Serial.println("*** hologram_msg: "+ hologram_msg); // My extra line of code
To be sure, I reset everything and I ran the code again. Got same log like before.
Hmm. worked in China… Can they show the China log file or some another country/continent where this code worked ?
I very appreciate if they can do it. Maybe it’s only a local issue to NZ and I have to change my approach to this issue ?!
I’m open to do more tests If it’s necessary to solve this technical/design issue…
Zoltan
