RAK7201V2: First press of a different button sends previous button's data
RAK7201V2: First press of a different button sends previous button’s data (stale TX buffer)
Summary
[!Note]
I have examined RAK7201 always sends button one payload and this is not the same issue.
The RAK7201V2 WisNode Button 4K sends the previous button’s fPort and payload data when a different button is pressed for the first time. Pressing the same button a second time sends the correct data. The device’s serial console (minicom) correctly identifies which button was physically pressed — the issue is in the LoRaWAN uplink that gets transmitted.
This makes it impossible to reliably determine which button was pressed from the network server side, effectively rendering the 4-button functionality unusable.
Firmware and Environment
Component Version / Detail
Device RAK7201V2 WisNode Button 4K
Firmware AT+VER=RUI_3.5.2+user (latest from RAK download server)
Network Server ChirpStack v4.16.2
Gateway RAK7289CV2
Region US915 (channels 0-7 + 64), sub-band 1
MAC Version LoRaWAN 1.0.3
Regional Parameters RP002-1.0.3
How to Reproduce
Step 1: Configure buttons with distinct fPorts and data
AT+BUTTON=1:1:1
AT+BUTTON=2:2:2
AT+BUTTON=3:3:3
AT+BUTTON=4:4:4
ATZ
After rejoin, verify config:
AT+BUTTON=?
buton1:1,1
buton2:2,2
buton3:3,3
buton4:4,4
(Note: firmware returns “buton” with one T despite accepting “BUTTON” with two.)
Step 2: Press buttons in sequence, waiting 10+ seconds between presses
Action Minicom Output ChirpStack Event (fPort / data) Correct?
Press Button 1 shortPress! BUTTON_1_PIN fPort=1, data=0x31 (“1”) Yes
Wait 10 seconds
Press Button 2 shortPress! BUTTON_2_PIN fPort=1, data=0x31 (“1”) No — stale
Press Button 2 again shortPress! BUTTON_2_PIN fPort=2, data=0x32 (“2”) Yes
Wait 10 seconds
Press Button 3 shortPress! BUTTON_3_PIN fPort=2, data=0x32 (“2”) No — stale
Press Button 3 again shortPress! BUTTON_3_PIN fPort=3, data=0x33 (“3”) Yes
The pattern is 100% reproducible: the first press of a different button always transmits the previous button’s complete LoRaWAN frame (fPort + payload). The second press of the same button transmits correctly.
Step 3: Verify with raw LoRaWAN frames
Inspecting the raw uplink event JSON in ChirpStack confirms both fPort and data (base64-decoded FRMPayload) are stale. This is not a codec/decoder issue — the wrong bytes are on the wire.
What I Have Tried
Attempt Result
AT+CFM=0 (unconfirmed uplinks) Same stale behavior
AT+CFM=1 (confirmed uplinks) Same stale behavior
Factory reset (ATR) — done multiple times Same stale behavior after reconfiguration
Reflashed latest firmware (RAK7201_V2.0.6_APP.bin) Same stale behavior (was already on latest)
All buttons on same fPort, different data (AT+BUTTON=1:1:A, AT+BUTTON=2:1:B, etc.) Stale data persists (also, ChirpStack template codec expects bytes 49-52 not 65-68)
All buttons with same data, different fPort (AT+BUTTON=1:1:1234, AT+BUTTON=2:2:1234, etc.) fPort is also stale — confirmed by switching codec to fPort-based identification
Waited 10+ seconds between presses to rule out Class A busy window Same stale behavior — not timing-related
fPort-based codec (ignoring payload, using only input.fPort for button ID) fPort is stale too, confirming entire TX frame is wrong
Analysis
The device’s serial output correctly identifies which physical button was pressed (BUTTON_1_PIN, BUTTON_2_PIN, etc.) and reports +EVT:SEND_CONFIRMED_OK for each press. The button interrupt and local detection are working correctly.
The problem is in the LoRaWAN TX path. Both fPort and FRMPayload contain the previous button’s values, indicating the LoRaWAN send function is called with stale parameters before the application firmware updates them with the new button’s data. Since fPort is set in the MAC frame header (not the payload), this rules out any payload-encoding issue — the entire frame is prepared from stale state.
This appears to be a race condition or incorrect ordering in the firmware’s button press handler: the TX is triggered before the button-specific parameters (port and data) are updated.
Expected Behavior
Pressing any button should immediately transmit that button’s configured fPort and data, regardless of which button was pressed previously.
Request
Could the RAK firmware team investigate and provide a fix? This bug makes the 4-button functionality unreliable for any automation or alerting use case.
Thank you.
Welcome to RAK forum @c.m.w.44 .
I haven’t experienced yet this issue so I tried again on my RAK7201V2 button. In my test with TTN at AS923-3, it is working ok.
I did tried to press the button near 10seconds interval as well.
How many buttons do you have (does it behave the same as well)?
Is there anything unusual on the Chirpstack logs?
Maybe you can try to test as well on Built-in LNS instead of Chirpstack? Or maybe TTN just to isolate that it is LNS related?
Resolved — this was not a firmware bug.
Thank you for the very fast response.
The root cause was our Nginx reverse proxy configuration in front of ChirpStack v4. ChirpStack v4 uses gRPC for real-time event streaming to the browser. Our Nginx config was only doing standard HTTP
proxying:
location / {
proxy_pass http://chirpstack:8080;
This caused the Events tab to fall back to batched polling (~30 second intervals) instead of real-time streaming. When pressing a different button, the browser was displaying stale cached event data from
the previous button press — not the current uplink. The device was transmitting the correct fPort and payload the entire time.
The fix was adding gRPC support and HTTP/2 to the Nginx config:
server {
listen 8080 ssl http2;
  # gRPC API — required for real-time event and frame streaming
  location /api {
      grpc_pass grpc://chirpstack:8080;
      grpc_set_header Host $host;
      grpc_set_header X-Real-IP $remote_addr;
  # Web interface and static assets
  location / {
      proxy_set_header   Host $host;
After adding the location /api block with grpc_pass and http2 on the listen directive, events stream in real time and every button press displays correctly.
Apologies for the false alarm — the RAK7201V2 firmware is working correctly.
