Issue:After the firmwareupgrade to RUI_RAK7204_V3.0.0.12.H.T(EU868-US915-AU915-KR920-IN865) nothing is possible with the device. I can still access it and do further firmware and bootloader upgrades or downgrades but it does not report any data from the sensor with an AT STATUS or is the device able to join any lora network.
Setup: RAK7204 with firmware 3.0.0.12.H and bootloader 3_0_2 from the website downloaded. EU868 frequenzy and OTAA joining.
Server: Chirpstack newest version with RAK developer GW or PI-HAT RAK833 as gateway. both are receiving from other devices but nothing possible from this device.
Details: Bootloader upgrade and firmware upgrade went through without any issues. after the last reset by button and connecting by RAK serial tool the device shows the bootup screen with errors as shown below. Even tried a downgrade to 3.0.0.10H with the corresponding bootloader. but without any success also. Bootloader and firmware upgrades all done as shown in the guide including the jumper, these steps always working without errors. also tried to flash again and again as seen in the forum someone else had to flash twice.
also tried old bootloader with new firmware and vice versa, same result. I always get BME I2C WRITE and READ ERROR or RUI_AT_PARAMETER_INVALID2 see the log output below.
The set DevEui and AppKey works, just wiped out for posting.
The logs are produced with the bootloader 3_0_2 and firmware 3.0.0.12H
Direct after flash and reset button
| ___ / _ \ | | / / | | | () | |
| |/ / /\ | |/ / | | | | _ __ | | ___ ___ ___
| /| _ || \ | |/| | | '/ _ \ |/ _ / __/ __|
| |\ | | | || |\ \ \ /\ / | | | __/ | /_ _
_| __| |/_| _/ / /||| _|_|_||//
RAK7204 Version:3.0.0.12.H.T
Selected LoRaWAN 1.0.2 Region: EU868
UART1 work mode: RUI_UART_NORAMAL
BME680 init success.
autosend_interval: 600s
Initialization OK,Current work_mode:LoRaWAN, join_mode:OTAA, Class: A
ERROR: RUI_AT_PARAMETER_INVALID 2
Go to Sleep
OK
device status:
at+get_config=device:status
OK.
===============Device Status List================
Board Core: RAK811
MCU: STM32L151CB_A
LoRa chip: SX1276
Battery Voltage:3.646 V
BME I2C WRITE ERROR
BME I2C READ ERROR
BME I2C READ ERROR
BME I2C READ ERROR
BME I2C READ ERROR
BME680 set sensor settings ERROR
BME680 Error.
device join otaa
at+join
at+join
OTAA:
DevEui:XXXXXXXXXXXXXXXX
AppEui:0000000000000000
AppKey:YYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYY
OTAA Join Start…
ERROR: RUI_AT_UNSUPPORT 1
May someone has any idea or another firmware which I should trie to get this thing alive again…![]()
thanks!
