Issue:Rak7204 is sending only base 64 ‘CAIBaw==’
Setup:
Server:
Details:
We are using / testing RAK7204 for few months now and it is quite stable and reliable.
We received two additional RAK7204 today which were configured and joined with our LORAWAN. The one is working perfectly but the other is send only a short base64 message ‘CAIBaw==’ hex ‘0802016b’.
the status is presented below and from what we see we get BME680 error and zero parameter values!!.
Could you please explain what is wrong? Is the node defect? if yes we have to return it and get a new one?
thanks
Stelios Papageorgiou
[LoRa]:Joined Successed!
Battery Voltage = 3.598 V
at+version
BME I2C WRITE ERROR
BME I2C READ ERROR
BME I2C READ ERROR
BME I2C READ ERROR
BME I2C READ ERROR
BME680 set sensor settings ERROR
BME680 Error.
[LoRa]: send out
OK3.0.0.11.H
[LoRa]: Unconfirm data send OK
Go to Sleep.
at+get_config=device:status
Wake up.
OK.
===============Device Status List================
Board Core: RAK811
MCU: STM32L151CB_A
LoRa chip: SX1276
Battery Voltage:3.598 V
BME680 sensor data:
Humidity:0.0 %RH
Temperature:0.0 degree
Pressure:0.0 hPa
Gas_resistance: 0 ohms
