I have the 7243 + LTE.
It should work for few minutes and than I turned off the ttn-gateway and the lora services for 30min and than back (all that in a loop).
After few hours the GPS stop working. also reboot of the RAK doesn’t help.
I tried to stop ttn-gateway service and run only the lora_pkt_fwd. Got the following messages -
INFO: Disabling GPS mode for concentrator’s counter…
INFO: [down] PULL_ACK received in 0 ms
INFO: host/sx1301 time offset=(1585216968s:535125µs) - drift=374156373µs
INFO: Enabling GPS mode for concentrator’s counter.
##### 2020-03-26 10:03:21 GMT #####
### [UPSTREAM] ###
# RF packets received by concentrator: 1
# CRC_OK: 0.00%, CRC_FAIL: 100.00%, NO_CRC: 0.00%
# RF packets forwarded: 0 (0 bytes)
# PUSH_DATA datagrams sent: 0 (0 bytes)
# PUSH_DATA acknowledged: 0.00%
### [DOWNSTREAM] ###
# PULL_DATA sent: 3 (100.00% acknowledged)
# PULL_RESP(onse) datagrams received: 0 (0 bytes)
# RF packets sent to concentrator: 0 (0 bytes)
# TX errors: 0
# BEACON queued: 0
# BEACON sent so far: 0
# BEACON rejected: 0
### [JIT] ###
# SX1301 time (PPS): 2673059
src/jitqueue.c:448:jit_print_queue(): INFO: [jit] queue is empty
### [GPS] ###
# Invalid time reference (age: 1585217001 sec)
# no valid GPS coordinates available yet
##### END #####
also the GPS device is outside, the GPS cable looks ok, turn off and on the i2c from the raspi-config.
