My gateway can not receive the data from node. It ok connect to server.
My gateway is config as basicstation with connect to AWS IoT server
Hi @Vincent1 Are you sure that that the gateway is connected to the AWS IoT core? The gateway is for the US915 band, correct? Did you test the same flow with LNS like TTN?
Hi @Todor , i have a confirmation on server AWS as the gateway is well connected.
May be I can try on TTY also.
I can Find a tool to view the node upload on the gateway ?
It’s i can send you the trace my log start?
PS:My gateway is us915 buy from your store
Envoyé de mon iPhone
