Hi, I have just purchased and am setting up a 7249 Gateway. I’m wanting to use ethernet, but also have lte available as a failover. I have a sim card (working, tested on phone), have checked to make sure the apn is correct, but it shows in the webui as “not connected”. Network is “undefined”, but it has ICCID, IMEI and IMSI…any thoughts as to why it won’t connect? I’m in Australia, and it looks like the lte card EG95 has our band available (B28)…
When your card is inserted correctly, ICCID, IMEI and other information will be displayed when the dialing fails. You’d better make sure your card is inserted correctly.
I have that information showing, so I’m assuming it’s inserted correctly…
I contacted the provider, and they assured me this was correct…also from a google search…
This link also has the details….
Are you connected to an LTE antenna? Can I make sure I don’t write the following items? Some need to be written into them.
Yep, all antennas are connected to the correct positions, the antenna is the correct frequency. I’m told I don’t have to put anything into User/Password/PIN Code…
After you set some parameters, you have to do the save Settings, if everything is correct, you can try to replace a card, I think your signal strength is normal.
Ok, thanks for the assistance, I’ll see how I go.I’ll try another sim and report back.
Have tried another sim card (from my working iphone), still no action at all…any other ideas? When I put the sim for the gateway in my phone, it connects no problem and has good data transfer speeds…
Still trying to get this working, haven’t had any luck over the last few days, although the tx packets are building…
In addition to LTE connections, how do you connect to the configuration interface?Finally, check your version number!
I’m using ethernet to connect to config interface, which will also be the connection to the wan whilst powered etc, the aim is to have it failover to lte when the network or power is down…is it possible it won’t show the connection whilst the ethernet is on and working? Here’s the version number…
Below is the log after disabling/reenabling the cellular…
Mon Jan 20 09:13:20 2020 kern.info quectel-CM[25889]: requestQueryDataCall IPv4ConnectionStatus: DISCONNECTED
Mon Jan 20 09:13:21 2020 kern.info quectel-CM[25889]: requestRegistrationState2 MCC: 0, MNC: 0, PS: Detached, DataCap: UNKNOW
Mon Jan 20 09:13:21 2020 daemon.notice netifd: wwan (25925): Sending discover…
Mon Jan 20 09:13:24 2020 daemon.notice netifd: wwan (25925): Sending discover…
Mon Jan 20 09:13:26 2020 kern.info quectel-CM[25889]: requestRegistrationState2 MCC: 0, MNC: 0, PS: Detached, DataCap: UNKNOW
Mon Jan 20 09:13:31 2020 kern.info quectel-CM[25889]: requestRegistrationState2 MCC: 0, MNC: 0, PS: Detached, DataCap: UNKNOW
Mon Jan 20 09:13:36 2020 kern.info quectel-CM[25889]: requestRegistrationState2 MCC: 0, MNC: 0, PS: Detached, DataCap: UNKNOW
Mon Jan 20 09:13:41 2020 kern.info quectel-CM[25889]: requestRegistrationState2 MCC: 0, MNC: 0, PS: Detached, DataCap: UNKNOW
Mon Jan 20 09:13:46 2020 kern.info quectel-CM[25889]: requestRegistrationState2 MCC: 0, MNC: 0, PS: Detached, DataCap: UNKNOW
Mon Jan 20 09:13:51 2020 kern.info quectel-CM[25889]: requestRegistrationState2 MCC: 0, MNC: 0, PS: Detached, DataCap: UNKNOW
Mon Jan 20 09:13:56 2020 kern.info quectel-CM[25889]: requestRegistrationState2 MCC: 0, MNC: 0, PS: Detached, DataCap: UNKNOW
Mon Jan 20 09:14:01 2020 kern.info quectel-CM[25889]: requestRegistrationState2 MCC: 0, MNC: 0, PS: Detached, DataCap: UNKNOW
Mon Jan 20 09:14:06 2020 kern.info quectel-CM[25889]: requestRegistrationState2 MCC: 0, MNC: 0, PS: Detached, DataCap: UNKNOW
Mon Jan 20 09:14:06 2020 kern.info quectel-CM[25889]: requestSetOperatingMode(1)
Mon Jan 20 09:14:06 2020 kern.info quectel-CM[25889]: requestSetOperatingMode(0)
Mon Jan 20 09:14:11 2020 kern.info quectel-CM[25889]: requestRegistrationState2 MCC: 0, MNC: 0, PS: Detached, DataCap: UNKNOW
Mon Jan 20 09:14:17 2020 kern.info quectel-CM[25889]: requestRegistrationState2 MCC: 0, MNC: 0, PS: Detached, DataCap: UNKNOW
Mon Jan 20 09:14:22 2020 kern.info quectel-CM[25889]: requestRegistrationState2 MCC: 0, MNC: 0, PS: Detached, DataCap: UNKNOW
Mon Jan 20 09:14:27 2020 kern.info quectel-CM[25889]: requestRegistrationState2 MCC: 0, MNC: 0, PS: Detached, DataCap: UNKNOW
Mon Jan 20 09:14:32 2020 kern.info quectel-CM[25889]: requestRegistrationState2 MCC: 0, MNC: 0, PS: Detached, DataCap: UNKNOW
Mon Jan 20 09:14:37 2020 kern.info quectel-CM[25889]: requestRegistrationState2 MCC: 0, MNC: 0, PS: Detached, DataCap: UNKNOW
Mon Jan 20 09:14:42 2020 kern.info quectel-CM[25889]: requestRegistrationState2 MCC: 0, MNC: 0, PS: Detached, DataCap: UNKNOW
Mon Jan 20 09:14:47 2020 kern.info quectel-CM[25889]: requestRegistrationState2 MCC: 0, MNC: 0, PS: Detached, DataCap: UNKNOW
Mon Jan 20 09:14:52 2020 kern.info quectel-CM[25889]: requestRegistrationState2 MCC: 0, MNC: 0, PS: Detached, DataCap: UNKNOW
Mon Jan 20 09:14:52 2020 kern.info quectel-CM[25889]: requestSetOperatingMode(1)
Mon Jan 20 09:14:52 2020 kern.info quectel-CM[25889]: requestSetOperatingMode(0)
Mon Jan 20 09:14:57 2020 kern.info quectel-CM[25889]: requestRegistrationState2 MCC: 0, MNC: 0, PS: Detached, DataCap: UNKNOW
Mon Jan 20 09:15:02 2020 kern.info quectel-CM[25889]: requestRegistrationState2 MCC: 0, MNC: 0, PS: Detached, DataCap: UNKNOW
Mon Jan 20 09:15:07 2020 kern.info quectel-CM[25889]: requestRegistrationState2 MCC: 0, MNC: 0, PS: Detached, DataCap: UNKNOW
Mon Jan 20 09:15:12 2020 kern.info quectel-CM[25889]: requestRegistrationState2 MCC: 0, MNC: 0, PS: Detached, DataCap: UNKNOW
Mon Jan 20 09:15:18 2020 kern.info quectel-CM[25889]: requestRegistrationState2 MCC: 0, MNC: 0, PS: Detached, DataCap: UNKNOW
Mon Jan 20 09:15:23 2020 kern.info quectel-CM[25889]: requestRegistrationState2 MCC: 0, MNC: 0, PS: Detached, DataCap: UNKNOW
We don’t see any useful information. Can U send more prints?
Mon Jan 20 12:06:39 2020 kern.info kernel: [30716.320000] usb 1-1.1: GSM modem (1-port) converter now attached to ttyUSB5
Mon Jan 20 12:06:39 2020 kern.debug kernel: [30716.340000] qmi_wwan 1-1.1:1.4: no of_node; not parsing pinctrl DT
Mon Jan 20 12:06:39 2020 kern.info kernel: [30716.350000] qmi_wwan 1-1.1:1.4: cdc-wdm0: USB WDM device
Mon Jan 20 12:06:39 2020 kern.info kernel: [30716.360000] qmi_wwan 1-1.1:1.4: QuectelEC25&EC21&EG91&EG95&EG06&EP06&EM06&BG96&AG35 work on RawIP mode
Mon Jan 20 12:06:39 2020 kern.info kernel: [30716.380000] qmi_wwan 1-1.1:1.4 wwan0: register ‘qmi_wwan’ at usb-101c0000.ehci-1.1, WWAN/QMI device, 86:ef:13:51:ee:e6
Mon Jan 20 12:06:39 2020 daemon.notice netifd: Interface ‘wwan’ is enabled
Mon Jan 20 12:06:39 2020 daemon.notice netifd: Network device ‘wwan0’ link is up
Mon Jan 20 12:06:39 2020 daemon.notice netifd: Interface ‘wwan’ has link connectivity
Mon Jan 20 12:06:39 2020 daemon.notice netifd: Interface ‘wwan’ is setting up now
Mon Jan 20 12:06:39 2020 daemon.notice netifd: wwan (22374): udhcpc: option -h NAME is deprecated, use -x hostname:NAME
Mon Jan 20 12:06:39 2020 daemon.notice netifd: wwan (22374): udhcpc (v1.23.2) started
Mon Jan 20 12:06:39 2020 daemon.notice netifd: wwan (22374): Sending discover…
Mon Jan 20 12:06:42 2020 daemon.notice netifd: wwan (22374): Sending discover…
Mon Jan 20 12:06:45 2020 daemon.notice netifd: wwan (22374): Sending discover…
Mon Jan 20 12:06:50 2020 kern.info kernel: [30727.890000] usb 1-1.1: USB disconnect, device number 12
Mon Jan 20 12:06:50 2020 kern.info kernel: [30727.900000] option1 ttyUSB2: GSM modem (1-port) converter now disconnected from ttyUSB2
Mon Jan 20 12:06:50 2020 kern.info kernel: [30727.920000] option 1-1.1:1.0: device disconnected
Mon Jan 20 12:06:50 2020 kern.info kernel: [30727.930000] option1 ttyUSB3: GSM modem (1-port) converter now disconnected from ttyUSB3
Mon Jan 20 12:06:50 2020 kern.info kernel: [30727.940000] option 1-1.1:1.1: device disconnected
Mon Jan 20 12:06:50 2020 kern.info kernel: [30727.950000] option1 ttyUSB4: GSM modem (1-port) converter now disconnected from ttyUSB4
Mon Jan 20 12:06:50 2020 kern.info kernel: [30727.970000] option 1-1.1:1.2: device disconnected
Mon Jan 20 12:06:50 2020 kern.info kernel: [30727.980000] option1 ttyUSB5: GSM modem (1-port) converter now disconnected from ttyUSB5
Mon Jan 20 12:06:50 2020 kern.info kernel: [30728.000000] option 1-1.1:1.3: device disconnected
Mon Jan 20 12:06:50 2020 kern.info kernel: [30728.020000] qmi_wwan 1-1.1:1.4 wwan0: unregister ‘qmi_wwan’ usb-101c0000.ehci-1.1, WWAN/QMI device
Mon Jan 20 12:06:50 2020 daemon.notice netifd: Network device ‘wwan0’ link is down
Mon Jan 20 12:06:50 2020 daemon.notice netifd: Interface ‘wwan’ has link connectivity loss
Mon Jan 20 12:06:50 2020 daemon.notice netifd: wwan (22374): Read error: Network is down, reopening socket
Mon Jan 20 12:06:50 2020 daemon.notice netifd: Interface ‘wwan’ is disabled
Mon Jan 20 12:06:50 2020 daemon.notice netifd: wwan (22374): udhcpc: bind: No such device
Mon Jan 20 12:07:04 2020 kern.info kernel: [30741.700000] usb 1-1.1: new high-speed USB device number 13 using ehci-platform
Mon Jan 20 12:07:04 2020 kern.debug kernel: [30741.830000] usb 1-1.1: no of_node; not parsing pinctrl DT
Mon Jan 20 12:07:04 2020 kern.debug kernel: [30741.830000] option 1-1.1:1.0: no of_node; not parsing pinctrl DT
Mon Jan 20 12:07:04 2020 kern.info kernel: [30741.830000] option 1-1.1:1.0: GSM modem (1-port) converter detected
Mon Jan 20 12:07:04 2020 kern.debug kernel: [30741.840000] option1 ttyUSB2: no of_node; not parsing pinctrl DT
Mon Jan 20 12:07:04 2020 kern.info kernel: [30741.840000] usb 1-1.1: GSM modem (1-port) converter now attached to ttyUSB2
Mon Jan 20 12:07:04 2020 kern.debug kernel: [30741.860000] option 1-1.1:1.1: no of_node; not parsing pinctrl DT
Mon Jan 20 12:07:04 2020 kern.info kernel: [30741.860000] option 1-1.1:1.1: GSM modem (1-port) converter detected
Mon Jan 20 12:07:04 2020 kern.debug kernel: [30741.870000] option1 ttyUSB3: no of_node; not parsing pinctrl DT
Mon Jan 20 12:07:04 2020 kern.info kernel: [30741.870000] usb 1-1.1: GSM modem (1-port) converter now attached to ttyUSB3
Mon Jan 20 12:07:04 2020 kern.debug kernel: [30741.880000] option 1-1.1:1.2: no of_node; not parsing pinctrl DT
Mon Jan 20 12:07:04 2020 kern.info kernel: [30741.880000] option 1-1.1:1.2: GSM modem (1-port) converter detected
Mon Jan 20 12:07:04 2020 kern.debug kernel: [30741.900000] option1 ttyUSB4: no of_node; not parsing pinctrl DT
Mon Jan 20 12:07:04 2020 kern.info kernel: [30741.900000] usb 1-1.1: GSM modem (1-port) converter now attached to ttyUSB4
Mon Jan 20 12:07:04 2020 kern.debug kernel: [30741.910000] option 1-1.1:1.3: no of_node; not parsing pinctrl DT
Mon Jan 20 12:07:04 2020 kern.info kernel: [30741.910000] option 1-1.1:1.3: GSM modem (1-port) converter detected
Mon Jan 20 12:07:04 2020 kern.debug kernel: [30741.920000] option1 ttyUSB5: no of_node; not parsing pinctrl DT
Mon Jan 20 12:07:04 2020 kern.info kernel: [30741.920000] usb 1-1.1: GSM modem (1-port) converter now attached to ttyUSB5
Mon Jan 20 12:07:04 2020 kern.debug kernel: [30741.940000] qmi_wwan 1-1.1:1.4: no of_node; not parsing pinctrl DT
Mon Jan 20 12:07:04 2020 kern.info kernel: [30741.940000] qmi_wwan 1-1.1:1.4: cdc-wdm0: USB WDM device
Mon Jan 20 12:07:04 2020 kern.info kernel: [30741.960000] qmi_wwan 1-1.1:1.4: QuectelEC25&EC21&EG91&EG95&EG06&EP06&EM06&BG96&AG35 work on RawIP mode
Mon Jan 20 12:07:04 2020 kern.info kernel: [30741.980000] qmi_wwan 1-1.1:1.4 wwan0: register ‘qmi_wwan’ at usb-101c0000.ehci-1.1, WWAN/QMI device, 86:ef:13:51:ee:e6
Mon Jan 20 12:07:04 2020 daemon.notice netifd: Interface ‘wwan’ is enabled
Mon Jan 20 12:07:04 2020 daemon.notice netifd: Network device ‘wwan0’ link is up
Mon Jan 20 12:07:04 2020 daemon.notice netifd: Interface ‘wwan’ has link connectivity
Mon Jan 20 12:07:04 2020 daemon.notice netifd: Interface ‘wwan’ is setting up now
Mon Jan 20 12:07:05 2020 daemon.notice netifd: wwan (22660): udhcpc: option -h NAME is deprecated, use -x hostname:NAME
Mon Jan 20 12:07:05 2020 daemon.notice netifd: wwan (22660): udhcpc (v1.23.2) started
Mon Jan 20 12:07:05 2020 daemon.notice netifd: wwan (22660): Sending discover…
Mon Jan 20 12:07:05 2020 kern.info quectel-CM[22687]: WCDMA<E_QConnectManager_Linux&Android_V1.1.38
Mon Jan 20 12:07:05 2020 kern.info quectel-CM[22687]: /usr/sbin/quectel profile[1] = telstra.wap///0, pincode = (null)
Mon Jan 20 12:07:05 2020 kern.info quectel-CM[22687]: Find /sys/bus/usb/devices/1-1.1 idVendor=2c7c idProduct=0195
Mon Jan 20 12:07:05 2020 kern.info quectel-CM[22687]: Find /sys/bus/usb/devices/1-1.1:1.4/net/wwan0
Mon Jan 20 12:07:05 2020 kern.info quectel-CM[22687]: Find usbnet_adapter = wwan0
Mon Jan 20 12:07:05 2020 kern.info quectel-CM[22687]: Find /sys/bus/usb/devices/1-1.1:1.4/usbmisc/cdc-wdm0
Mon Jan 20 12:07:05 2020 kern.info quectel-CM[22687]: Find qmichannel = /dev/cdc-wdm0
Mon Jan 20 12:07:05 2020 kern.info quectel-CM[22687]: cdc_wdm_fd = 7
Mon Jan 20 12:07:07 2020 kern.info quectel-CM[22687]: Get clientWDS = 4
Mon Jan 20 12:07:07 2020 kern.info quectel-CM[22687]: Get clientDMS = 1
Mon Jan 20 12:07:07 2020 kern.info quectel-CM[22687]: Get clientNAS = 3
Mon Jan 20 12:07:07 2020 kern.info quectel-CM[22687]: Get clientUIM = 1
Mon Jan 20 12:07:07 2020 kern.info quectel-CM[22687]: Get clientWDA = 1
Mon Jan 20 12:07:07 2020 kern.info quectel-CM[22687]: requestBaseBandVersion EG95EFBR06A05M4G
Mon Jan 20 12:07:07 2020 kern.info quectel-CM[22687]: requestGetSIMStatus SIMStatus: SIM_READY
Mon Jan 20 12:07:08 2020 kern.info quectel-CM[22687]: requestGetICCID DeviceICCID: 89610182000548436529
Mon Jan 20 12:07:08 2020 kern.info quectel-CM[22687]: requestGetIMSI DeviceIMSI: 505014504844436
Mon Jan 20 12:07:08 2020 kern.info quectel-CM[22687]: requestSetProfile[1] telstra.wap///0
Mon Jan 20 12:07:08 2020 kern.info quectel-CM[22687]: requestGetProfile[1] telstra.wap///0
Mon Jan 20 12:07:08 2020 daemon.notice netifd: wwan (22660): Sending discover…
Mon Jan 20 12:07:08 2020 kern.info quectel-CM[22687]: requestRegistrationState2 MCC: 0, MNC: 0, PS: Detached, DataCap: UNKNOW
Mon Jan 20 12:07:08 2020 kern.info quectel-CM[22687]: requestQueryDataCall IPv4ConnectionStatus: DISCONNECTED
Mon Jan 20 12:07:11 2020 daemon.notice netifd: wwan (22660): Sending discover…
Mon Jan 20 12:07:13 2020 kern.info quectel-CM[22687]: requestRegistrationState2 MCC: 0, MNC: 0, PS: Detached, DataCap: UNKNOW
Mon Jan 20 12:07:15 2020 kern.info kernel: [30752.210000] usb 1-1.1: USB disconnect, device number 13
Mon Jan 20 12:07:15 2020 kern.info kernel: [30752.220000] option1 ttyUSB2: GSM modem (1-port) converter now disconnected from ttyUSB2
Mon Jan 20 12:07:15 2020 kern.info kernel: [30752.240000] option 1-1.1:1.0: device disconnected
Mon Jan 20 12:07:15 2020 kern.info kernel: [30752.250000] option1 ttyUSB3: GSM modem (1-port) converter now disconnected from ttyUSB3
Mon Jan 20 12:07:15 2020 kern.info kernel: [30752.260000] option 1-1.1:1.1: device disconnected
Mon Jan 20 12:07:15 2020 kern.info kernel: [30752.270000] option1 ttyUSB4: GSM modem (1-port) converter now disconnected from ttyUSB4
Mon Jan 20 12:07:15 2020 kern.info kernel: [30752.290000] option 1-1.1:1.2: device disconnected
Mon Jan 20 12:07:15 2020 kern.info kernel: [30752.300000] option1 ttyUSB5: GSM modem (1-port) converter now disconnected from ttyUSB5
Mon Jan 20 12:07:15 2020 kern.info kernel: [30752.320000] option 1-1.1:1.3: device disconnected
Mon Jan 20 12:07:15 2020 daemon.notice netifd: Network device ‘wwan0’ link is down
Mon Jan 20 12:07:15 2020 daemon.notice netifd: Interface ‘wwan’ has link connectivity loss
Mon Jan 20 12:07:15 2020 kern.info kernel: [30752.340000] qmi_wwan 1-1.1:1.4 wwan0: unregister ‘qmi_wwan’ usb-101c0000.ehci-1.1, WWAN/QMI device
Mon Jan 20 12:07:15 2020 daemon.notice netifd: wwan (22660): Read error: Network is down, reopening socket
Mon Jan 20 12:07:15 2020 kern.info quectel-CM[22687]: QmiWwanThread poll err/hup/inval
Mon Jan 20 12:07:15 2020 kern.info quectel-CM[22687]: poll fd = 7, events = 0x0018
Mon Jan 20 12:07:15 2020 kern.info quectel-CM[22687]: QmiWwanThread exit
Mon Jan 20 12:07:15 2020 kern.info quectel-CM[22687]: main exit
Mon Jan 20 12:07:15 2020 daemon.notice netifd: Interface ‘wwan’ is disabled
Mon Jan 20 12:07:15 2020 daemon.notice netifd: wwan (22660): udhcpc: bind: No such device
Mon Jan 20 12:07:17 2020 kern.info quectel-CM[22811]: WCDMA<E_QConnectManager_Linux&Android_V1.1.38
Mon Jan 20 12:07:17 2020 kern.info quectel-CM[22811]: /usr/sbin/quectel profile[1] = telstra.wap///0, pincode = (null)
Mon Jan 20 12:07:17 2020 kern.info quectel-CM[22811]: Cannot find qmichannel((null)) usbnet_adapter((null)) for Quectel modules
Mon Jan 20 12:07:19 2020 kern.info quectel-CM[22824]: WCDMA<E_QConnectManager_Linux&Android_V1.1.38
Mon Jan 20 12:07:19 2020 kern.info quectel-CM[22824]: /usr/sbin/quectel profile[1] = telstra.wap///0, pincode = (null)
Mon Jan 20 12:07:19 2020 kern.info quectel-CM[22824]: Cannot find qmichannel((null)) usbnet_adapter((null)) for Quectel modules
Mon Jan 20 12:07:21 2020 kern.info quectel-CM[22838]: WCDMA<E_QConnectManager_Linux&Android_V1.1.38
Mon Jan 20 12:07:21 2020 kern.info quectel-CM[22838]: /usr/sbin/quectel profile[1] = telstra.wap///0, pincode = (null)
Mon Jan 20 12:07:21 2020 kern.info quectel-CM[22838]: Cannot find qmichannel((null)) usbnet_adapter((null)) for Quectel modules
Mon Jan 20 12:07:23 2020 kern.info quectel-CM[22853]: WCDMA<E_QConnectManager_Linux&Android_V1.1.38
Mon Jan 20 12:07:23 2020 kern.info quectel-CM[22853]: /usr/sbin/quectel profile[1] = telstra.wap///0, pincode = (null)
Mon Jan 20 12:07:23 2020 kern.info quectel-CM[22853]: Cannot find qmichannel((null)) usbnet_adapter((null)) for Quectel modules
Mon Jan 20 12:07:25 2020 kern.info quectel-CM[22868]: WCDMA<E_QConnectManager_Linux&Android_V1.1.38
Mon Jan 20 12:07:25 2020 kern.info quectel-CM[22868]: /usr/sbin/quectel profile[1] = telstra.wap///0, pincode = (null)
Mon Jan 20 12:07:25 2020 kern.info quectel-CM[22868]: Cannot find qmichannel((null)) usbnet_adapter((null)) for Quectel modules
Mon Jan 20 12:07:27 2020 kern.info quectel-CM[22880]: WCDMA<E_QConnectManager_Linux&Android_V1.1.38
Mon Jan 20 12:07:27 2020 kern.info quectel-CM[22880]: /usr/sbin/quectel profile[1] = telstra.wap///0, pincode = (null)
Mon Jan 20 12:07:27 2020 kern.info quectel-CM[22880]: Cannot find qmichannel((null)) usbnet_adapter((null)) for Quectel modules
Mon Jan 20 12:07:29 2020 kern.info kernel: [30766.280000] usb 1-1.1: new high-speed USB device number 14 using ehci-platform
Mon Jan 20 12:07:29 2020 kern.debug kernel: [30766.420000] usb 1-1.1: no of_node; not parsing pinctrl DT
Mon Jan 20 12:07:29 2020 kern.debug kernel: [30766.420000] option 1-1.1:1.0: no of_node; not parsing pinctrl DT
Mon Jan 20 12:07:29 2020 kern.info kernel: [30766.420000] option 1-1.1:1.0: GSM modem (1-port) converter detected
Mon Jan 20 12:07:29 2020 kern.debug kernel: [30766.430000] option1 ttyUSB2: no of_node; not parsing pinctrl DT
Mon Jan 20 12:07:29 2020 kern.info kernel: [30766.430000] usb 1-1.1: GSM modem (1-port) converter now attached to ttyUSB2
Mon Jan 20 12:07:29 2020 kern.debug kernel: [30766.450000] option 1-1.1:1.1: no of_node; not parsing pinctrl DT
Mon Jan 20 12:07:29 2020 kern.info kernel: [30766.450000] option 1-1.1:1.1: GSM modem (1-port) converter detected
Mon Jan 20 12:07:29 2020 kern.debug kernel: [30766.460000] option1 ttyUSB3: no of_node; not parsing pinctrl DT
Mon Jan 20 12:07:29 2020 kern.info kernel: [30766.460000] usb 1-1.1: GSM modem (1-port) converter now attached to ttyUSB3
Mon Jan 20 12:07:29 2020 kern.debug kernel: [30766.470000] option 1-1.1:1.2: no of_node; not parsing pinctrl DT
Mon Jan 20 12:07:29 2020 kern.info kernel: [30766.470000] option 1-1.1:1.2: GSM modem (1-port) converter detected
Mon Jan 20 12:07:29 2020 kern.debug kernel: [30766.490000] option1 ttyUSB4: no of_node; not parsing pinctrl DT
Mon Jan 20 12:07:29 2020 kern.info kernel: [30766.490000] usb 1-1.1: GSM modem (1-port) converter now attached to ttyUSB4
Mon Jan 20 12:07:29 2020 kern.debug kernel: [30766.500000] option 1-1.1:1.3: no of_node; not parsing pinctrl DT
Mon Jan 20 12:07:29 2020 kern.info kernel: [30766.500000] option 1-1.1:1.3: GSM modem (1-port) converter detected
Mon Jan 20 12:07:29 2020 kern.debug kernel: [30766.510000] option1 ttyUSB5: no of_node; not parsing pinctrl DT
Mon Jan 20 12:07:29 2020 kern.info kernel: [30766.510000] usb 1-1.1: GSM modem (1-port) converter now attached to ttyUSB5
Mon Jan 20 12:07:29 2020 kern.debug kernel: [30766.530000] qmi_wwan 1-1.1:1.4: no of_node; not parsing pinctrl DT
Mon Jan 20 12:07:29 2020 kern.info kernel: [30766.550000] qmi_wwan 1-1.1:1.4: cdc-wdm0: USB WDM device
Mon Jan 20 12:07:29 2020 kern.info kernel: [30766.560000] qmi_wwan 1-1.1:1.4: QuectelEC25&EC21&EG91&EG95&EG06&EP06&EM06&BG96&AG35 work on RawIP mode
Mon Jan 20 12:07:29 2020 kern.info kernel: [30766.580000] qmi_wwan 1-1.1:1.4 wwan0: register ‘qmi_wwan’ at usb-101c0000.ehci-1.1, WWAN/QMI device, 86:ef:13:51:ee:e6
Mon Jan 20 12:07:29 2020 kern.info quectel-CM[22897]: WCDMA<E_QConnectManager_Linux&Android_V1.1.38
Mon Jan 20 12:07:29 2020 kern.info quectel-CM[22897]: /usr/sbin/quectel profile[1] = telstra.wap///0, pincode = (null)
Mon Jan 20 12:07:29 2020 kern.info quectel-CM[22897]: Find /sys/bus/usb/devices/1-1.1 idVendor=2c7c idProduct=0195
Mon Jan 20 12:07:29 2020 kern.info quectel-CM[22897]: Find /sys/bus/usb/devices/1-1.1:1.4/net/wwan0
Mon Jan 20 12:07:29 2020 kern.info quectel-CM[22897]: Find usbnet_adapter = wwan0
Mon Jan 20 12:07:29 2020 kern.info quectel-CM[22897]: Find /sys/bus/usb/devices/1-1.1:1.4/usbmisc/cdc-wdm0
Mon Jan 20 12:07:29 2020 kern.info quectel-CM[22897]: Find qmichannel = /dev/cdc-wdm0
Mon Jan 20 12:07:29 2020 kern.info quectel-CM[22897]: cdc_wdm_fd = 7
Mon Jan 20 12:07:29 2020 daemon.notice netifd: Interface ‘wwan’ is enabled
Mon Jan 20 12:07:29 2020 daemon.notice netifd: Network device ‘wwan0’ link is up
Mon Jan 20 12:07:29 2020 daemon.notice netifd: Interface ‘wwan’ has link connectivity
Mon Jan 20 12:07:29 2020 daemon.notice netifd: wwan (22933): udhcpc: option -h NAME is deprecated, use -x hostname:NAME
Mon Jan 20 12:07:29 2020 daemon.notice netifd: wwan (22933): udhcpc (v1.23.2) started
Mon Jan 20 12:07:29 2020 daemon.notice netifd: wwan (22933): Sending discover…
Mon Jan 20 12:07:30 2020 kern.info quectel-CM[22897]: QmiThreadSendQMITimeout pthread_cond_timeout_np=145, errno: 2 (No such file or directory)
Mon Jan 20 12:07:31 2020 kern.info quectel-CM[22897]: Get clientWDS = 5
Mon Jan 20 12:07:32 2020 kern.info quectel-CM[22897]: Get clientDMS = 1
Mon Jan 20 12:07:32 2020 kern.info quectel-CM[22897]: Get clientNAS = 3
Mon Jan 20 12:07:32 2020 kern.info quectel-CM[22897]: Get clientUIM = 1
Mon Jan 20 12:07:32 2020 kern.info quectel-CM[22897]: Get clientWDA = 1
Mon Jan 20 12:07:32 2020 kern.info quectel-CM[22897]: requestBaseBandVersion EG95EFBR06A05M4G
Mon Jan 20 12:07:32 2020 kern.info quectel-CM[22897]: requestGetSIMStatus SIMStatus: SIM_READY
Mon Jan 20 12:07:32 2020 kern.info quectel-CM[22897]: requestGetICCID DeviceICCID: 89610182000548436529
Mon Jan 20 12:07:32 2020 kern.info quectel-CM[22897]: requestGetIMSI DeviceIMSI: 505014504844436
Mon Jan 20 12:07:32 2020 kern.info quectel-CM[22897]: requestSetProfile[1] telstra.wap///0
Mon Jan 20 12:07:32 2020 daemon.notice netifd: wwan (22933): Sending discover…
Mon Jan 20 12:07:32 2020 kern.info quectel-CM[22897]: requestGetProfile[1] telstra.wap///0
Mon Jan 20 12:07:32 2020 kern.info quectel-CM[22897]: requestRegistrationState2 MCC: 0, MNC: 0, PS: Detached, DataCap: UNKNOW
Mon Jan 20 12:07:32 2020 kern.info quectel-CM[22897]: requestQueryDataCall IPv4ConnectionStatus: DISCONNECTED
Mon Jan 20 12:07:35 2020 daemon.notice netifd: wwan (22933): Sending discover…
Mon Jan 20 12:07:37 2020 kern.info quectel-CM[22897]: requestRegistrationState2 MCC: 0, MNC: 0, PS: Detached, DataCap: UNKNOW
Mon Jan 20 12:07:42 2020 kern.info quectel-CM[22897]: requestRegistrationState2 MCC: 0, MNC: 0, PS: Detached, DataCap: UNKNOW
Mon Jan 20 12:07:48 2020 kern.info quectel-CM[22897]: requestRegistrationState2 MCC: 0, MNC: 0, PS: Detached, DataCap: UNKNOW
Hi mate,
Try apn telstra.internet, this is what I am using.
If it does not work, ask Telstra staff.
Cheers,
Paul
Yep, have tried both .wap & .internet, both give the same results…here is the system log for .internet…
Tue Jan 21 06:53:19 2020 daemon.notice netifd: Interface ‘wwan’ has link connectivity
Tue Jan 21 06:53:19 2020 daemon.notice netifd: Interface ‘wwan’ is setting up now
Tue Jan 21 06:53:19 2020 daemon.notice netifd: wwan (20087): udhcpc: option -h NAME is deprecated, use -x hostname:NAME
Tue Jan 21 06:53:19 2020 daemon.notice netifd: wwan (20087): udhcpc (v1.23.2) started
Tue Jan 21 06:53:19 2020 daemon.notice netifd: wwan (20087): Sending discover…
Tue Jan 21 06:53:22 2020 daemon.notice netifd: wwan (20087): Sending discover…
Tue Jan 21 06:53:25 2020 daemon.notice netifd: wwan (20087): Sending discover…
Tue Jan 21 06:53:41 2020 kern.info kernel: [98339.040000] usb 1-1.1: USB disconnect, device number 17
Tue Jan 21 06:53:41 2020 kern.info kernel: [98339.050000] option1 ttyUSB2: GSM modem (1-port) converter now disconnected from ttyUSB2
Tue Jan 21 06:53:41 2020 kern.info kernel: [98339.070000] option 1-1.1:1.0: device disconnected
Tue Jan 21 06:53:41 2020 kern.info kernel: [98339.080000] option1 ttyUSB3: GSM modem (1-port) converter now disconnected from ttyUSB3
Tue Jan 21 06:53:41 2020 kern.info kernel: [98339.090000] option 1-1.1:1.1: device disconnected
Tue Jan 21 06:53:41 2020 kern.info kernel: [98339.100000] option1 ttyUSB4: GSM modem (1-port) converter now disconnected from ttyUSB4
Tue Jan 21 06:53:41 2020 kern.info kernel: [98339.120000] option 1-1.1:1.2: device disconnected
Tue Jan 21 06:53:41 2020 kern.info kernel: [98339.130000] option1 ttyUSB5: GSM modem (1-port) converter now disconnected from ttyUSB5
Tue Jan 21 06:53:41 2020 kern.info kernel: [98339.150000] option 1-1.1:1.3: device disconnected
Tue Jan 21 06:53:41 2020 kern.info kernel: [98339.170000] qmi_wwan 1-1.1:1.4 wwan0: unregister ‘qmi_wwan’ usb-101c0000.ehci-1.1, WWAN/QMI device
Tue Jan 21 06:53:41 2020 daemon.notice netifd: Network device ‘wwan0’ link is down
Tue Jan 21 06:53:41 2020 daemon.notice netifd: Interface ‘wwan’ has link connectivity loss
Tue Jan 21 06:53:41 2020 daemon.notice netifd: wwan (20087): Read error: Network is down, reopening socket
Tue Jan 21 06:53:41 2020 daemon.notice netifd: Interface ‘wwan’ is disabled
Tue Jan 21 06:53:42 2020 daemon.notice netifd: wwan (20087): udhcpc: bind: No such device
Tue Jan 21 06:53:55 2020 kern.info kernel: [98352.850000] usb 1-1.1: new high-speed USB device number 18 using ehci-platform
Tue Jan 21 06:53:55 2020 kern.debug kernel: [98352.980000] usb 1-1.1: no of_node; not parsing pinctrl DT
Tue Jan 21 06:53:55 2020 kern.debug kernel: [98352.980000] option 1-1.1:1.0: no of_node; not parsing pinctrl DT
Tue Jan 21 06:53:55 2020 kern.info kernel: [98352.980000] option 1-1.1:1.0: GSM modem (1-port) converter detected
Tue Jan 21 06:53:55 2020 kern.debug kernel: [98352.990000] option1 ttyUSB2: no of_node; not parsing pinctrl DT
Tue Jan 21 06:53:55 2020 kern.info kernel: [98352.990000] usb 1-1.1: GSM modem (1-port) converter now attached to ttyUSB2
Tue Jan 21 06:53:55 2020 kern.debug kernel: [98353.010000] option 1-1.1:1.1: no of_node; not parsing pinctrl DT
Tue Jan 21 06:53:55 2020 kern.info kernel: [98353.010000] option 1-1.1:1.1: GSM modem (1-port) converter detected
Tue Jan 21 06:53:55 2020 kern.debug kernel: [98353.020000] option1 ttyUSB3: no of_node; not parsing pinctrl DT
Tue Jan 21 06:53:55 2020 kern.info kernel: [98353.020000] usb 1-1.1: GSM modem (1-port) converter now attached to ttyUSB3
Tue Jan 21 06:53:55 2020 kern.debug kernel: [98353.030000] option 1-1.1:1.2: no of_node; not parsing pinctrl DT
Tue Jan 21 06:53:55 2020 kern.info kernel: [98353.030000] option 1-1.1:1.2: GSM modem (1-port) converter detected
Tue Jan 21 06:53:55 2020 kern.debug kernel: [98353.050000] option1 ttyUSB4: no of_node; not parsing pinctrl DT
Tue Jan 21 06:53:55 2020 kern.info kernel: [98353.050000] usb 1-1.1: GSM modem (1-port) converter now attached to ttyUSB4
Tue Jan 21 06:53:55 2020 kern.debug kernel: [98353.060000] option 1-1.1:1.3: no of_node; not parsing pinctrl DT
Tue Jan 21 06:53:55 2020 kern.info kernel: [98353.060000] option 1-1.1:1.3: GSM modem (1-port) converter detected
Tue Jan 21 06:53:55 2020 kern.debug kernel: [98353.070000] option1 ttyUSB5: no of_node; not parsing pinctrl DT
Tue Jan 21 06:53:55 2020 kern.info kernel: [98353.070000] usb 1-1.1: GSM modem (1-port) converter now attached to ttyUSB5
Tue Jan 21 06:53:55 2020 kern.debug kernel: [98353.090000] qmi_wwan 1-1.1:1.4: no of_node; not parsing pinctrl DT
Tue Jan 21 06:53:55 2020 kern.info kernel: [98353.100000] qmi_wwan 1-1.1:1.4: cdc-wdm0: USB WDM device
Tue Jan 21 06:53:55 2020 kern.info kernel: [98353.110000] qmi_wwan 1-1.1:1.4: QuectelEC25&EC21&EG91&EG95&EG06&EP06&EM06&BG96&AG35 work on RawIP mode
Tue Jan 21 06:53:55 2020 kern.info kernel: [98353.130000] qmi_wwan 1-1.1:1.4 wwan0: register ‘qmi_wwan’ at usb-101c0000.ehci-1.1, WWAN/QMI device, 86:ef:13:51:ee:e6
Tue Jan 21 06:53:56 2020 daemon.notice netifd: Interface ‘wwan’ is enabled
Tue Jan 21 06:53:56 2020 daemon.notice netifd: Network device ‘wwan0’ link is up
Tue Jan 21 06:53:56 2020 daemon.notice netifd: Interface ‘wwan’ has link connectivity
Tue Jan 21 06:53:56 2020 daemon.notice netifd: Interface ‘wwan’ is setting up now
Tue Jan 21 06:53:56 2020 daemon.notice netifd: wwan (20363): udhcpc: option -h NAME is deprecated, use -x hostname:NAME
Tue Jan 21 06:53:56 2020 daemon.notice netifd: wwan (20363): udhcpc (v1.23.2) started
Tue Jan 21 06:53:56 2020 daemon.notice netifd: wwan (20363): Sending discover…
Tue Jan 21 06:53:57 2020 kern.info quectel-CM[20389]: WCDMA<E_QConnectManager_Linux&Android_V1.1.38
Tue Jan 21 06:53:57 2020 kern.info quectel-CM[20389]: /usr/sbin/quectel profile[1] = telstra.internet///0, pincode = (null)
Tue Jan 21 06:53:57 2020 kern.info quectel-CM[20389]: Find /sys/bus/usb/devices/1-1.1 idVendor=2c7c idProduct=0195
Tue Jan 21 06:53:57 2020 kern.info quectel-CM[20389]: Find /sys/bus/usb/devices/1-1.1:1.4/net/wwan0
Tue Jan 21 06:53:57 2020 kern.info quectel-CM[20389]: Find usbnet_adapter = wwan0
Tue Jan 21 06:53:57 2020 kern.info quectel-CM[20389]: Find /sys/bus/usb/devices/1-1.1:1.4/usbmisc/cdc-wdm0
Tue Jan 21 06:53:57 2020 kern.info quectel-CM[20389]: Find qmichannel = /dev/cdc-wdm0
Tue Jan 21 06:53:57 2020 kern.info quectel-CM[20389]: cdc_wdm_fd = 7
Tue Jan 21 06:53:58 2020 kern.info quectel-CM[20389]: Get clientWDS = 4
Tue Jan 21 06:53:58 2020 kern.info quectel-CM[20389]: Get clientDMS = 1
Tue Jan 21 06:53:58 2020 kern.info quectel-CM[20389]: Get clientNAS = 3
Tue Jan 21 06:53:58 2020 kern.info quectel-CM[20389]: Get clientUIM = 1
Tue Jan 21 06:53:58 2020 kern.info quectel-CM[20389]: Get clientWDA = 1
Tue Jan 21 06:53:58 2020 kern.info quectel-CM[20389]: requestBaseBandVersion EG95EFBR06A05M4G
Tue Jan 21 06:53:58 2020 kern.info quectel-CM[20389]: requestGetSIMStatus SIMStatus: SIM_READY
Tue Jan 21 06:53:58 2020 kern.info quectel-CM[20389]: requestGetICCID DeviceICCID: 89610182000548436529
Tue Jan 21 06:53:58 2020 kern.info quectel-CM[20389]: requestGetIMSI DeviceIMSI: 505014504844436
Tue Jan 21 06:53:58 2020 kern.info quectel-CM[20389]: requestSetProfile[1] telstra.internet///0
Tue Jan 21 06:53:58 2020 kern.info quectel-CM[20389]: requestGetProfile[1] telstra.internet///0
Tue Jan 21 06:53:59 2020 kern.info quectel-CM[20389]: requestRegistrationState2 MCC: 0, MNC: 0, PS: Detached, DataCap: UNKNOW
Tue Jan 21 06:53:59 2020 kern.info quectel-CM[20389]: requestQueryDataCall IPv4ConnectionStatus: DISCONNECTED
Tue Jan 21 06:53:59 2020 daemon.notice netifd: wwan (20363): Sending discover…
Tue Jan 21 06:54:01 2020 kern.info kernel: [98359.010000] usb 1-1.1: USB disconnect, device number 18
Tue Jan 21 06:54:01 2020 kern.info kernel: [98359.020000] option1 ttyUSB2: GSM modem (1-port) converter now disconnected from ttyUSB2
Tue Jan 21 06:54:01 2020 kern.info kernel: [98359.040000] option 1-1.1:1.0: device disconnected
Tue Jan 21 06:54:01 2020 kern.info kernel: [98359.050000] option1 ttyUSB3: GSM modem (1-port) converter now disconnected from ttyUSB3
Tue Jan 21 06:54:01 2020 kern.info kernel: [98359.060000] option 1-1.1:1.1: device disconnected
Tue Jan 21 06:54:01 2020 kern.info kernel: [98359.070000] option1 ttyUSB4: GSM modem (1-port) converter now disconnected from ttyUSB4
Tue Jan 21 06:54:01 2020 kern.info kernel: [98359.090000] option 1-1.1:1.2: device disconnected
Tue Jan 21 06:54:01 2020 kern.info kernel: [98359.100000] option1 ttyUSB5: GSM modem (1-port) converter now disconnected from ttyUSB5
Tue Jan 21 06:54:01 2020 kern.info kernel: [98359.110000] option 1-1.1:1.3: device disconnected
Tue Jan 21 06:54:01 2020 daemon.notice netifd: Network device ‘wwan0’ link is down
Tue Jan 21 06:54:01 2020 daemon.notice netifd: Interface ‘wwan’ has link connectivity loss
Tue Jan 21 06:54:01 2020 daemon.notice netifd: wwan (20363): Read error: Network is down, reopening socket
Tue Jan 21 06:54:01 2020 kern.info kernel: [98359.140000] qmi_wwan 1-1.1:1.4 wwan0: unregister ‘qmi_wwan’ usb-101c0000.ehci-1.1, WWAN/QMI device
Tue Jan 21 06:54:01 2020 kern.info quectel-CM[20389]: QmiWwanThread poll err/hup/inval
Tue Jan 21 06:54:01 2020 kern.info quectel-CM[20389]: poll fd = 7, events = 0x0018
Tue Jan 21 06:54:01 2020 kern.info quectel-CM[20389]: QmiWwanThread exit
Tue Jan 21 06:54:01 2020 kern.info quectel-CM[20389]: main exit
Tue Jan 21 06:54:01 2020 daemon.notice netifd: Interface ‘wwan’ is disabled
Tue Jan 21 06:54:02 2020 daemon.notice netifd: wwan (20363): udhcpc: bind: No such device
Tue Jan 21 06:54:03 2020 kern.info quectel-CM[20514]: WCDMA<E_QConnectManager_Linux&Android_V1.1.38
Tue Jan 21 06:54:03 2020 kern.info quectel-CM[20514]: /usr/sbin/quectel profile[1] = telstra.internet///0, pincode = (null)
Tue Jan 21 06:54:03 2020 kern.info quectel-CM[20514]: Cannot find qmichannel((null)) usbnet_adapter((null)) for Quectel modules
Tue Jan 21 06:54:05 2020 kern.info quectel-CM[20529]: WCDMA<E_QConnectManager_Linux&Android_V1.1.38
Tue Jan 21 06:54:05 2020 kern.info quectel-CM[20529]: /usr/sbin/quectel profile[1] = telstra.internet///0, pincode = (null)
Tue Jan 21 06:54:05 2020 kern.info quectel-CM[20529]: Cannot find qmichannel((null)) usbnet_adapter((null)) for Quectel modules
Tue Jan 21 06:54:07 2020 kern.info quectel-CM[20543]: WCDMA<E_QConnectManager_Linux&Android_V1.1.38
Tue Jan 21 06:54:07 2020 kern.info quectel-CM[20543]: /usr/sbin/quectel profile[1] = telstra.internet///0, pincode = (null)
Tue Jan 21 06:54:07 2020 kern.info quectel-CM[20543]: Cannot find qmichannel((null)) usbnet_adapter((null)) for Quectel modules
Tue Jan 21 06:54:09 2020 kern.info quectel-CM[20558]: WCDMA<E_QConnectManager_Linux&Android_V1.1.38
Tue Jan 21 06:54:09 2020 kern.info quectel-CM[20558]: /usr/sbin/quectel profile[1] = telstra.internet///0, pincode = (null)
Tue Jan 21 06:54:09 2020 kern.info quectel-CM[20558]: Cannot find qmichannel((null)) usbnet_adapter((null)) for Quectel modules
Tue Jan 21 06:54:11 2020 kern.info quectel-CM[20573]: WCDMA<E_QConnectManager_Linux&Android_V1.1.38
Tue Jan 21 06:54:11 2020 kern.info quectel-CM[20573]: /usr/sbin/quectel profile[1] = telstra.internet///0, pincode = (null)
Tue Jan 21 06:54:11 2020 kern.info quectel-CM[20573]: Cannot find qmichannel((null)) usbnet_adapter((null)) for Quectel modules
Tue Jan 21 06:54:14 2020 kern.info quectel-CM[20586]: WCDMA<E_QConnectManager_Linux&Android_V1.1.38
Tue Jan 21 06:54:14 2020 kern.info quectel-CM[20586]: /usr/sbin/quectel profile[1] = telstra.internet///0, pincode = (null)
Tue Jan 21 06:54:14 2020 kern.info quectel-CM[20586]: Cannot find qmichannel((null)) usbnet_adapter((null)) for Quectel modules
Tue Jan 21 06:54:15 2020 kern.info kernel: [98372.560000] usb 1-1.1: new high-speed USB device number 19 using ehci-platform
Tue Jan 21 06:54:15 2020 kern.debug kernel: [98372.690000] usb 1-1.1: no of_node; not parsing pinctrl DT
Tue Jan 21 06:54:15 2020 kern.debug kernel: [98372.690000] option 1-1.1:1.0: no of_node; not parsing pinctrl DT
Tue Jan 21 06:54:15 2020 kern.info kernel: [98372.690000] option 1-1.1:1.0: GSM modem (1-port) converter detected
Tue Jan 21 06:54:15 2020 kern.debug kernel: [98372.700000] option1 ttyUSB2: no of_node; not parsing pinctrl DT
Tue Jan 21 06:54:15 2020 kern.info kernel: [98372.700000] usb 1-1.1: GSM modem (1-port) converter now attached to ttyUSB2
Tue Jan 21 06:54:15 2020 kern.debug kernel: [98372.720000] option 1-1.1:1.1: no of_node; not parsing pinctrl DT
Tue Jan 21 06:54:15 2020 kern.info kernel: [98372.720000] option 1-1.1:1.1: GSM modem (1-port) converter detected
Tue Jan 21 06:54:15 2020 kern.debug kernel: [98372.730000] option1 ttyUSB3: no of_node; not parsing pinctrl DT
Tue Jan 21 06:54:15 2020 kern.info kernel: [98372.730000] usb 1-1.1: GSM modem (1-port) converter now attached to ttyUSB3
Tue Jan 21 06:54:15 2020 kern.debug kernel: [98372.740000] option 1-1.1:1.2: no of_node; not parsing pinctrl DT
Tue Jan 21 06:54:15 2020 kern.info kernel: [98372.740000] option 1-1.1:1.2: GSM modem (1-port) converter detected
Tue Jan 21 06:54:15 2020 kern.debug kernel: [98372.760000] option1 ttyUSB4: no of_node; not parsing pinctrl DT
Tue Jan 21 06:54:15 2020 kern.info kernel: [98372.760000] usb 1-1.1: GSM modem (1-port) converter now attached to ttyUSB4
Tue Jan 21 06:54:15 2020 kern.debug kernel: [98372.770000] option 1-1.1:1.3: no of_node; not parsing pinctrl DT
Tue Jan 21 06:54:15 2020 kern.info kernel: [98372.770000] option 1-1.1:1.3: GSM modem (1-port) converter detected
Tue Jan 21 06:54:15 2020 kern.debug kernel: [98372.780000] option1 ttyUSB5: no of_node; not parsing pinctrl DT
Tue Jan 21 06:54:15 2020 kern.info kernel: [98372.780000] usb 1-1.1: GSM modem (1-port) converter now attached to ttyUSB5
Tue Jan 21 06:54:15 2020 kern.debug kernel: [98372.800000] qmi_wwan 1-1.1:1.4: no of_node; not parsing pinctrl DT
Tue Jan 21 06:54:15 2020 kern.info kernel: [98372.800000] qmi_wwan 1-1.1:1.4: cdc-wdm0: USB WDM device
Tue Jan 21 06:54:15 2020 kern.info kernel: [98372.820000] qmi_wwan 1-1.1:1.4: QuectelEC25&EC21&EG91&EG95&EG06&EP06&EM06&BG96&AG35 work on RawIP mode
Tue Jan 21 06:54:15 2020 kern.info kernel: [98372.840000] qmi_wwan 1-1.1:1.4 wwan0: register ‘qmi_wwan’ at usb-101c0000.ehci-1.1, WWAN/QMI device, 86:ef:13:51:ee:e6
Tue Jan 21 06:54:15 2020 daemon.notice netifd: Interface ‘wwan’ is enabled
Tue Jan 21 06:54:15 2020 daemon.notice netifd: Network device ‘wwan0’ link is up
Tue Jan 21 06:54:15 2020 daemon.notice netifd: Interface ‘wwan’ has link connectivity
Tue Jan 21 06:54:15 2020 daemon.notice netifd: Interface ‘wwan’ is setting up now
Tue Jan 21 06:54:15 2020 daemon.notice netifd: wwan (20646): udhcpc: option -h NAME is deprecated, use -x hostname:NAME
Tue Jan 21 06:54:15 2020 daemon.notice netifd: wwan (20646): udhcpc (v1.23.2) started
Tue Jan 21 06:54:15 2020 daemon.notice netifd: wwan (20646): Sending discover…
Tue Jan 21 06:54:16 2020 kern.info quectel-CM[20656]: WCDMA<E_QConnectManager_Linux&Android_V1.1.38
Tue Jan 21 06:54:16 2020 kern.info quectel-CM[20656]: /usr/sbin/quectel profile[1] = telstra.internet///0, pincode = (null)
Tue Jan 21 06:54:16 2020 kern.info quectel-CM[20656]: Find /sys/bus/usb/devices/1-1.1 idVendor=2c7c idProduct=0195
Tue Jan 21 06:54:16 2020 kern.info quectel-CM[20656]: Find /sys/bus/usb/devices/1-1.1:1.4/net/wwan0
Tue Jan 21 06:54:16 2020 kern.info quectel-CM[20656]: Find usbnet_adapter = wwan0
Tue Jan 21 06:54:16 2020 kern.info quectel-CM[20656]: Find /sys/bus/usb/devices/1-1.1:1.4/usbmisc/cdc-wdm0
Tue Jan 21 06:54:16 2020 kern.info quectel-CM[20656]: Find qmichannel = /dev/cdc-wdm0
Tue Jan 21 06:54:16 2020 kern.info quectel-CM[20656]: cdc_wdm_fd = 7
Tue Jan 21 06:54:17 2020 kern.info quectel-CM[20656]: QmiThreadSendQMITimeout pthread_cond_timeout_np=145, errno: 2 (No such file or directory)
Tue Jan 21 06:54:18 2020 kern.info quectel-CM[20656]: Get clientWDS = 4
Tue Jan 21 06:54:18 2020 kern.info quectel-CM[20656]: Get clientDMS = 1
Tue Jan 21 06:54:18 2020 kern.info quectel-CM[20656]: Get clientNAS = 3
Tue Jan 21 06:54:18 2020 kern.info quectel-CM[20656]: Get clientUIM = 1
Tue Jan 21 06:54:18 2020 kern.info quectel-CM[20656]: Get clientWDA = 1
Tue Jan 21 06:54:18 2020 kern.info quectel-CM[20656]: requestBaseBandVersion EG95EFBR06A05M4G
Tue Jan 21 06:54:18 2020 kern.info quectel-CM[20656]: requestGetSIMStatus SIMStatus: SIM_READY
Tue Jan 21 06:54:18 2020 kern.info quectel-CM[20656]: requestGetICCID DeviceICCID: 89610182000548436529
Tue Jan 21 06:54:18 2020 kern.info quectel-CM[20656]: requestGetIMSI DeviceIMSI: 505014504844436
Tue Jan 21 06:54:18 2020 kern.info quectel-CM[20656]: requestSetProfile[1] telstra.internet///0
Tue Jan 21 06:54:19 2020 daemon.notice netifd: wwan (20646): Sending discover…
Tue Jan 21 06:54:19 2020 kern.info quectel-CM[20656]: requestGetProfile[1] telstra.internet///0
Tue Jan 21 06:54:19 2020 kern.info quectel-CM[20656]: requestRegistrationState2 MCC: 0, MNC: 0, PS: Detached, DataCap: UNKNOW
Tue Jan 21 06:54:19 2020 kern.info quectel-CM[20656]: requestQueryDataCall IPv4ConnectionStatus: DISCONNECTED
Tue Jan 21 06:54:22 2020 daemon.notice netifd: wwan (20646): Sending discover…
Tue Jan 21 06:54:24 2020 kern.info quectel-CM[20656]: requestRegistrationState2 MCC: 0, MNC: 0, PS: Detached, DataCap: UNKNOW
Tue Jan 21 06:54:29 2020 kern.info quectel-CM[20656]: requestRegistrationState2 MCC: 0, MNC: 0, PS: Detached, DataCap: UNKNOW
Tue Jan 21 06:54:34 2020 kern.info quectel-CM[20656]: requestRegistrationState2 MCC: 0, MNC: 0, PS: Detached, DataCap: UNKNOW
Tue Jan 21 06:54:39 2020 kern.info quectel-CM[20656]: requestRegistrationState2 MCC: 0, MNC: 0, PS: Detached, DataCap: UNKNOW
Tue Jan 21 06:54:44 2020 kern.info quectel-CM[20656]: requestRegistrationState2 MCC: 0, MNC: 0, PS: Detached, DataCap: UNKNOW
Tue Jan 21 06:54:49 2020 kern.info quectel-CM[20656]: requestRegistrationState2 MCC: 0, MNC: 0, PS: Detached, DataCap: UNKNOW
Tue Jan 21 06:54:54 2020 kern.info quectel-CM[20656]: requestRegistrationState2 MCC: 0, MNC: 0, PS: Detached, DataCap: UNKNOW
Tue Jan 21 06:54:59 2020 kern.info quectel-CM[20656]: requestRegistrationState2 MCC: 0, MNC: 0, PS: Detached, DataCap: UNKNOW
Tue Jan 21 06:55:04 2020 kern.info quectel-CM[20656]: requestRegistrationState2 MCC: 0, MNC: 0, PS: Detached, DataCap: UNKNOW
Tue Jan 21 06:55:04 2020 kern.info quectel-CM[20656]: requestSetOperatingMode(1)
Tue Jan 21 06:55:04 2020 kern.info quectel-CM[20656]: requestSetOperatingMode(0)
