Rak7289 to helium
Hallo,
I want to connect an Rak7289 to the helium network, but I can‘t find any explenation or tutorial. Is there somebody how cloud help me
Greeds
Hey,
Are you referring to making a Data-only Hotspot which will not get rewards from Witnessing. This is the only way you can use RAK7268 on the Helium network.
Vladislav
Yes this is what I found out until now.
Hey,
Try this one:
It is a guide for the V1, but should get you started.
Vladislav
Hallo, thank you yes this worked to enable the data only hotspot.
but now I m trying to register it.
I found this site,
but I stacked at the point of Register the Gateway on Helium network. I wanted to use my wallet but it seams I need to create a command line wallet.
Now I searching a way to install it using busy box.
Hey @Manjo ,
This is the oficial doc, it is not very difficult to use the CLI wallet, just foloow the instructions in the link:
If you follow that article from disk91 you will be able to pay the feed (I used this exact one that first time I did this too).
You will have to pay both the onboarding and location assertion feed.
Vladislav
Hello, has this worked for you @Manjo ? I am currently trying to create a data only gateway registered to helium but failed to do so.
I managed to ssh into it and download the gateway-rs but i cannot install rust…
Any help is much appreciated, thank you very much!
