Hello RAK support.
I’m having communication problems with a device that uses the RAK3172.
The gateway used is the RAK7289V2/RAK7289CV2 WisGate Edge Pro configured on Chirpstack.
The configured band is AU-915.
The device can join and send data.
Data is sent at DR = 2, TX-Power = 0, fPort = 97 and with confirmation request.
Sometimes the system date and time are requested.
Communication is working, but with flaws.
On the Chirpstack dashboard, I can monitor communication with the device.
I’m sending some screenshots and data I took from the Chirpstack Dashboard.
In figure 1 I show the communication event log. I highlighted two events:
EVENT_1: 2024-05-27 14:40:31 with FCnt = 7, details can be seen in the “Event FCnt=7.json” file;
EVENT_2: 2024-05-27 14:42:36 with FCnt = 8, details can be seen in the “Event FCnt=8.json” file’.
In figure 2 I show the communication frame log. I also highlighted the frames corresponding to the two events I mentioned:
FRAME_1: 2024-05-27 14:40:31 ConfirmedDataUp, details can be seen in the “Frame_ConfirmedDataUp FCnt=7.json” file;
FRAME_2: 2024-05-27 14:40:32 UnconfirmedDataDown “frame after FRAME_1”, details can be seen in the “Frame_UnconfirmedDataDown (1) FCnt=7.json” file;
FRAME_3: 2024-05-27 14:40:32 UnconfirmedDataDown “frame after FRAME_2”, details can be seen in the “Frame_UnconfirmedDataDown (2) FCnt=7.json” file;
FRAME_4: 2024-05-27 14:42:36 UnconfirmedDataUp, details can be seen in the “Frame_UnconfirmedDataUp FCnt=8.json” file;
FRAME_5: 2024-05-27 14:42:37 UnconfirmedDataDown “frame after FRAME_4”, details can be seen in the “Frame_UnconfirmedDataDown (1) FCnt=8.json” file;
FRAME_6: 2024-05-27 14:42:37 UnconfirmedDataDown “frame after FRAME_5”, details can be seen in the “Frame_UnconfirmedDataDown (2) FCnt=8.json” file.
On the Chirpstack Forum, I found a related post:
In this post they commented that the problem could be because the message size exceeds the payload allowed by the Data Rate used.
However, the size of my message is 9 bytes, which is smaller than the 11 bytes allowed by DR 2.
Continuing reading the post, I saw a comment that I thought was relevant and highlighted it in figure 3.
I would like to know if the message from my application can be ignored to the detriment of internal communication from the RAK3172?
I see that when reception occurs on FPort = 0, I am not notified, neither by the “api.lorawan.send” or any other “+EVT” event message.
Best regards.
Figure 1.
Figure 2.
Figure 3.
Chirstack JSON.tgz (1.9 KB)
