Hello RAK Team,
I’m trying to configure the RAK3172 in “Class C” mode and have it running at the lowest power consumption possible.
At the moment I have the module by itself, only with 10uF and 0.1uF caps connected to VDD. I upgraded to the latest FW (AT+VER=3.4.2-rui3_22q1_update.112) and I run the following commands using an FTDI adapter to configure the module and join the network:
RAKwireless RAK3172-E Example
Current Work Mode: LoRaWAN.
AT+VER=?
OK
AT+DEVEUI=xxxxx
OK
AT+APPKEY=xxxxx
OK
AT+CLASS=C
OK
AT+BAND=6
OK
AT+CHE=6
OK
AT+NJM=1
OK
AT+CFM=0
OK
AT+TXP=0
OK
AT+DR=2
OK
AT+ADR=1
OK
AT+JOIN=1:0:255:0
OK
+EVT:JOINED
AT+SLEEP=1000000
OK
The image attached shows the power profile, and you can see, that after joining the IDLE consumption is around 8.18mA. I disconnected the FTDI at the end to make sure there is no current leak.
The datasheet specifies an RX consumption of 5.22mA, but it’s far from it.
If I run the unit as Class A, the unit goes down to 1.5uA after AT+SLEEP, which is great. Am I missing anything to get down to 5.22mA in Class C?
Thanks and Regards,
Mike
