We have a Chirpstack server running in production environment and if i want i need to change the servers for any reasons, we need to reset the field nodes to make a new Join Session with new devaddress.
¿it’s there any function to reconnect to Lora and recieve a new devaddress when i change the server?
I need to solve that for failover reasons, to make my network more robust.
I’m using wisblock boxes with RAK4630 inside and using Arduino Framework with SX126x-Arduino library from Begee-Tokyo.
I tried with “lmh_join();” before to send any message but doesnt works. I too tried with “int8_t loraInitResult = initLoRaWan();” before to send all my messages but neither worked it.
When staying with OTAA as join method, I see only one solution.
Use a confirmed packet send every now and then to check whether the connection to the LNS is still working.
If there is no ACK received from the LNS for the confirmed packet, you can restart joining with lmh_join() or reset the device to perform a new join request.
If you can switch to ABP as join method, the device should be able to send to the new LNS if it is registered with the same keys there. (not tested).
To add more information to any that have the same problem, i didn’t can’t to solve using just “lmh_join()” function but using all the “block of code” that make the connection for the first time, it’s worked flawlessly
This its the code that you need to run if you need to register your device in a new server without push the reset button:
// Initialize LoRaWan and start join request
#ifndef MAX_SAVE
if (loraInitResult != 0) {
switch (loraInitResult) {
case -1:
Serial.println("SX126x init failed");
break;
case -2:
Serial.println("LoRaWan init failed");
break;
case -3:
Serial.println("Subband init error");
break;
case -4:
Serial.println("LoRa Task init error");
break;
default:
Serial.println("LoRa init unknown error");
break;
// Without working LoRa we just stop here
while (1) {
Serial.println("LoRA doesnt works, freezing.");
delay(5000);
Serial.println("LoRaWan init success");
#endif
If i use lmh_join() instead the block of code that i posted 2 days ago, i receive the following logs in chirpstack (all deveui was change by XXXX):
gateway region_id="au915_1" topic="au915_1/gateway/XXXXXXXXXXXX/event/up" qos=0 json=false
2024-01-31T13:17:54.689599Z INFO up{deduplication_id=722720a7-fbcc-4efc-8637-XXXXXXXX}: chirpstack::uplink: Uplink received m_type=ConfirmedDataUp
2024-01-31T13:17:54.690220Z INFO up{deduplication_id=b81e1d67-6679-4980-a0bc-XXXXXXXX}: chirpstack::uplink: Uplink received m_type=ConfirmedDataUp
2024-01-31T13:17:54.694327Z INFO up{deduplication_id=b81e1d67-6679-4980-a0bc-XXXXXXXXX}:data_up: chirpstack::uplink::data: No device-session exists for dev_addr dev_addr=01e4dbff
2024-01-31T13:17:54.695075Z INFO up{deduplication_id=722720a7-fbcc-4efc-8637-XXXXXXXXX}:data_up: chirpstack::uplink::data: No device-session exists for dev_addr dev_addr=01e4dbff
2024-01-31T13:17:55.279596Z INFO chirpstack::gateway::backend::mqtt: Message received from gateway region_id="au915_1" topic="au915_1/gateway/XXXXXX/event/up" qos=0 json=false
2024-01-31T13:17:55.280957Z INFO chirpstack::gateway::backend::mqtt: Message received from gateway region_id="au915_1" topic="au915_1/gateway/XXXXXXX/event/up" qos=0 json=false
2024-01-31T13:17:55.482692Z INFO up{deduplication_id=efce245d-2641-494c-be00-XXXXXXX}: chirpstack::uplink: Uplink received m_type=ConfirmedDataUp
2024-01-31T13:17:55.487849Z INFO up{deduplication_id=efce245d-2641-494c-be00-XXXXXXX}:data_up: chirpstack::storage::device_session: Device-session saved dev_eui=XXXXXXXX dev_addr=01c27e99
The devaddress “01e4dbff” it’s from the old chirpstack server, the server that im simulating a “crash” so i need to create a new server that will recieve the data from field nodes. The logs from the new server says that “No device-session exists for dev_addr dev_addr=01e4dbff”
This it’s the block of code that send a confirmed message and make a lmh_join if recieves error -1
@brief Enviamos un keep alive por LoRAWAN. Si no se recibe respuesta del server, hacemos un Join
@return result of send request
bool sendLoraKeepAlive(uint8_t dataFlags, uint8_t batteryLevel) {
m_lora_app_data.port = LORAWAN_APP_PORT;
unsigned long age;
//Prueba Gabriel
int32_t ilat = 0;
int32_t ilon = 0;
// m_lora_app_data.port = gAppPort;
m_lora_app_data.buffer[0] = 0x09;
//lat data
m_lora_app_data.buffer[1] = (ilat & 0xFF000000) >> 24;
m_lora_app_data.buffer[2] = (ilat & 0x00FF0000) >> 16;
m_lora_app_data.buffer[3] = (ilat & 0x0000FF00) >> 8;
m_lora_app_data.buffer[4] = ilat & 0x000000FF;
m_lora_app_data.buffer[6] = (ilon & 0xFF000000) >> 24;
m_lora_app_data.buffer[7] = (ilon & 0x00FF0000) >> 16;
m_lora_app_data.buffer[8] = (ilon & 0x0000FF00) >> 8;
m_lora_app_data.buffer[9] = ilon & 0x000000FF;
m_lora_app_data.buffer[10] = dataFlags;
m_lora_app_data.buffer[11] = batteryLevel;
// m_lora_app_data.buffer[12] = (val_y & 0x0000FF00) >> 8;
// m_lora_app_data.buffer[13] = val_y & 0xFF;
// m_lora_app_data.buffer[14] = (val_z & 0x0000FF00) >> 8;
// m_lora_app_data.buffer[15] = val_z & 0xFF;
m_lora_app_data.buffsize = 16;
//Intentamos reconexión antes de mandar el paquete (por si cambió la ip o el servidor)
// lmh_join();
//Era lmh_send pero a veces se perdía el paquete de las ventanas RX porque se duerme el uC
// lmh_error_status error = lmh_send(&m_lora_app_data, LMH_UNCONFIRMED_MSG); //Era unconfirmed, pero lo cambiamos por esto https://github.com/beegee-tokyo/SX126x-Arduino/issues/42#issuecomment-862039568
lmh_error_status error = lmh_send_blocking(&m_lora_app_data, LMH_CONFIRMED_MSG, 20000);
if (error == -1) {
//VAMOS A PROBAR LA CONFIG DE BEEGEE TOKYO
// #ifndef MAX_SAVE
// Serial.println("lmh error = Error -1, reintentamos conexión con LNS");
// #endif
// // Initialize LoRaWan and start join request
// int8_t loraInitResult = initLoRaWan();
// #ifndef MAX_SAVE
// if (loraInitResult != 0) {
// switch (loraInitResult) {
// case -1:
// Serial.println("SX126x init failed");
// break;
// case -2:
// Serial.println("LoRaWan init failed");
// break;
// case -3:
// Serial.println("Subband init error");
// break;
// case -4:
// Serial.println("LoRa Task init error");
// break;
// default:
// Serial.println("LoRa init unknown error");
// break;
// // Without working LoRa we just stop here
// while (1) {
// Serial.println("Reiniciamos Microcontrolador");
// delay(100);
// NVIC_SystemReset(); //Comando para reiniciar RAK4630
// Serial.println("LoRaWan init success");
// #endif
// #ifndef MAX_SAVE
// Serial.println("ya terminamos la inicialización lorawan, intentamos reenviar mensaje");
// #endif
lmh_join();
#ifndef MAX_SAVE
if (error == -1) Serial.println("lmh error = Error -1 2da vez");
if (error == 0) Serial.println("lmh error = envío exitoso 2da vez");
if (error == 1) Serial.println("lmh error = Error 1 (busy) 2da vez");
#endif
#ifndef MAX_SAVE
if (error == 0) Serial.println("lmh error = envío exitoso");
if (error == 1) Serial.println("lmh error = Error 1 (busy)");
#endif
return (error == 0);
