shirtna
(Nick Shirtcliffe)
June 5, 2024, 11:29pm
1
Issue: Connect script fails due to space in APN
Setup: RAK2013. rpi4. Bullseye os.
Details:
Hello again. Hoping someone can help.
When running “sudo pppd call gprs” the output is:
pppd options in effect:
debug # (from /etc/ppp/peers/gprs)
nodetach # (from /etc/ppp/peers/gprs)
dump # (from /etc/ppp/peers/gprs)
noauth # (from /etc/ppp/peers/gprs)
remotename 3gppp # (from /etc/ppp/peers/gprs)
/dev/ttyAMA0 # (from /etc/ppp/peers/gprs)
115200 # (from /etc/ppp/peers/gprs)
lock # (from /etc/ppp/peers/gprs)
connect chat -s -v -f /etc/chatscripts/quectel-chat-connect -T Spark NZ # (from /etc/ppp/peers/gprs)
disconnect chat -s -v -f /etc/chatscripts/quectel-chat-disconnect # (from /etc/ppp/peers/gprs)
nocrtscts # (from /etc/ppp/peers/gprs)
modem # (from /etc/ppp/peers/gprs)
asyncmap 0 # (from /etc/ppp/options)
lcp-echo-failure 4 # (from /etc/ppp/options)
lcp-echo-interval 30 # (from /etc/ppp/options)
hide-password # (from /etc/ppp/peers/gprs)
novj # (from /etc/ppp/peers/gprs)
novjccomp # (from /etc/ppp/peers/gprs)
ipcp-accept-local # (from /etc/ppp/peers/gprs)
ipcp-accept-remote # (from /etc/ppp/peers/gprs)
ipparam 3gppp # (from /etc/ppp/peers/gprs)
noipdefault # (from /etc/ppp/peers/gprs)
ipcp-max-failure 30 # (from /etc/ppp/peers/gprs)
defaultroute # (from /etc/ppp/peers/gprs)
usepeerdns # (from /etc/ppp/peers/gprs)
noipv6 # (from /etc/ppp/options)
noccp # (from /etc/ppp/peers/gprs)
noipx # (from /etc/ppp/options)
Usage: chat [-e] [-E] [-v] [-V] [-t timeout] [-r report-file]
[-T phone-number] [-U phone-number2] {-f chat-file | chat-script}
Script chat -s -v -f /etc/chatscripts/quectel-chat-connect -T Spark NZ finished (pid 8090), status = 0x1
Connect script failed
I think this is due to my APN having a space in it (“Spark NZ”). When i try without a space (“SparkNZ”) the connect script runs but obviously does not connect.
Minicom:
output from “at+cops=?”
+COPS: (1,"Spark NZ","Spark NZ","53005",7)
Output from “at+csq”
+CSQ: 30,99
output from “at+cops=1,0,Spark NZ,7”
+CME ERROR: 30
Thank you for reading and any info would be great.
Cheers,
shirtna
(Nick Shirtcliffe)
June 5, 2024, 11:41pm
2
I have just tried this with a different sim card and APN with no space (“2degrees”) and it worked fine.
Also, to be clear i am required to use the “Spark NZ” sim.
Thank you!
felmue
(Felix)
June 6, 2024, 11:27am
3
Hello @shirtna
you could try to use the numeric value instead. E.g. something like:
at+cops=1,2,53005,7
Felix
shirtna
(Nick Shirtcliffe)
June 7, 2024, 3:59am
4
Hello @felix
Thank you for your reply.
How would i apply that to the pppd connect script?
Would it just be
sudo /usr/local/rak/lte/ppp-creator.sh '53005' ttyAMA0 921600
Thanks again
felmue
(Felix)
June 7, 2024, 7:42am
5
Hello @shirtna
no, I don’t think so. I understand the script expects the APN as parameter which is different from the operator name or number.
Check with your provider about the correct APN. Maybe see here .
Felix
shirtna
(Nick Shirtcliffe)
June 20, 2024, 5:02am
6
Hello again @felix .
Thank you for your response and apologies for not replying, I’ve been away.
I have tried all the APNs in that link and none of them seem to work. The only way I can get the rak2013 to connect is by putting in a sim card from 2degrees and setting the APN to “2degrees”. 2degrees APN (internet etc) settings don’t seem to work either.
Cheers.
shirtna
(Nick Shirtcliffe)
June 20, 2024, 5:08am
7
Hey Felix,
This didn’t work either (in Minicom)
at+cops=1,2,53005,7
shirtna
(Nick Shirtcliffe)
June 20, 2024, 5:09am
8
This is the output from sudo pppd call gprs
admin@rpimon:~ $ sudo pppd call gprs
921600 # (from /etc/ppp/peers/gprs)
connect chat -s -v -f /etc/chatscripts/quectel-chat-connect -T internet # (from /etc/ppp/peers/gprs)
abort on (BUSY)
abort on (NO CARRIER)
abort on (NO DIALTONE)
abort on (ERROR)
abort on (NO ANSWER)
timeout set to 30 seconds
send (AT^M)
expect (OK)
^M
OK
-- got it
send (ATE0^M)
expect (OK)
^M
^M
OK
-- got it
send (ATI;+CSUB;+CSQ;+COPS?;+CGREG?;&D2^M)
expect (OK)
^M
^M
Quectel^M
EG95^M
Revision: EG95EFBR06A06M4G^M
^M
SubEdition: V02^M
^M
+CSQ: 31,99^M
^M
+COPS: 0^M
^M
+CGREG: 0,3^M
^M
OK
-- got it
send (AT+CGDCONT=1,"IP","internet",,0,0^M)
expect (OK)
^M
^M
OK
-- got it
send (ATD*99#^M)
expect (CONNECT)
^M
^M
CONNECT
-- got it
Script chat -s -v -f /etc/chatscripts/quectel-chat-connect -T internet finished (pid 12248), status = 0x0
Serial connection established.
using channel 2
Using interface ppp0
Connect: ppp0 <--> /dev/ttyAMA0
sent [LCP ConfReq id=0x1 <asyncmap 0x0> <magic 0xc871694d> <pcomp> <accomp>]
rcvd [LCP ConfReq id=0x3 <asyncmap 0x0> <auth chap MD5> <magic 0x7418827f> <pcomp> <accomp>]
No auth is possible
sent [LCP ConfRej id=0x3 <auth chap MD5>]
rcvd [LCP ConfAck id=0x1 <asyncmap 0x0> <magic 0xc871694d> <pcomp> <accomp>]
rcvd [LCP ConfReq id=0x4 <asyncmap 0x0> <magic 0x7418827f> <pcomp> <accomp>]
sent [LCP ConfAck id=0x4 <asyncmap 0x0> <magic 0x7418827f> <pcomp> <accomp>]
sent [LCP EchoReq id=0x0 magic=0xc871694d]
sent [IPCP ConfReq id=0x1 <addr 0.0.0.0> <ms-dns1 0.0.0.0> <ms-dns2 0.0.0.0>]
sent [IPV6CP ConfReq id=0x1 <addr fe80::f06f:c45a:880d:b9af>]
rcvd [LCP DiscReq id=0x5 magic=0x7418827f]
rcvd [LCP EchoRep id=0x0 magic=0x7418827f c8 71 69 4d]
sent [LCP EchoReq id=0x1 magic=0xc871694d]
IPCP: timeout sending Config-Requests
IPV6CP: timeout sending Config-Requests
sent [LCP TermReq id=0x2 "No network protocols running"]
sent [LCP TermReq id=0x3 "No network protocols running"]
Connection terminated.
abort on (ERROR)
unterminated quote (line 4)
Script chat -s -v -f /etc/chatscripts/quectel-chat-disconnect finished (pid 13275), status = 0x1
disconnect script failed
Modem hangup
