Is it possible to set SPI to be slave mode via Arduino’s RUI3 API? Documentation doesn’t seem to mention that and the following code from Web is not working either as it is applied to Arduino DUE:
ISR (SPI_STC_vect) //Inerrrput routine function
receivedData = SPDR; // Get the received data from SPDR register
received = true; // Sets received as True
void setup()
pinMode(MISO,OUTPUT); //Sets MISO as OUTPUT
SPCR |= _BV(SPE); //Turn on SPI in Slave Mode
received = false;
SPI.attachInterrupt(); //Activate SPI Interuupt
void loop()
if(received) {
SPDR = receivedData; // send back the received data, this is not necessary, only for demo purpose
received = false;
Serial.print(receivedData, HEX);
