TTN Payload Decoder for example
Hi
Anybody done a decoder for the example :EndDeviceDemo?
Temp is sent in C and F in ASCII.
Data : 31 39 2E 36 43 2F 36 37 2E 33 46
leads to :
19.6C/67.3F
A solution from Nick gives : TypeError("‘substring’ is not a function") or TypeError("‘substr’ is not a function")
function Decoder(bytes, port) {
var str = '';
for (var n = 0; n < bytes.length; n += 2) {
	str += String.fromCharCode(parseInt(bytes.substring(n, n + 2), 16));
return str;
Hope you can help.
bytes isn’t a string, it’s a sequence of bytes, so the first byte would be 0x31 which can’t be extracted as two characters. And you have to return an object. Try this:
  var decoded = {};
  var str = '';
  for (var n = 0; n < bytes.length; n ++) {
	  str += String.fromCharCode(parseInt(bytes[n]));
  decoded.result = str;
  return decoded;
which yields:
  "result": "19.6C/67.3F"
Hi Nick
Thank you it works!
