Greetings.
We have two RAK1372 EVB on which we are performing tests for an application based on the LoRaWAN End Node sample.
For some reason one of the two evaluation boards (that was working properly as of a few weeks ago when we last used it) is now experiencing a massive slowdown regarding the radio (as an example, where the working board would complete the join procedure in about two seconds, the other board takes upward of forty five seconds) that eventually results in the board resetting itself (likely because of the watchdog).
The only modification done to the hardware was to solder four pins on the RAK5005-O i2c sockets
Is there a way for us to better diagnose (and hopefully fix) this issue?
