Hi Chris,
I literally just managed to resolve this
From a fresh clone from the repo I did a make platform=corecell variant to pull in the dependencies (mainly GitHub - Lora-net/sx1302_hal: SX1302/SX1303 Hardware Abstraction Layer and Tools (packet forwarder...)).
After that I edited ~/basicstation/deps/lgw1302/platform-corecell/libloragw/src/loragw_stts751.c to comment out any I2C calls, and return a static temperature value as below;
/ _____) _ | |
( (____ _____ ____ _| |_ _____ ____| |__
\____ \| ___ | (_ _) ___ |/ ___) _ \
_____) ) ____| | | || |_| ____( (___| | | |
(______/|_____)_|_|_| \__)_____)\____)_| |_|
(C)2019 Semtech
Description:
Basic driver for ST ts751 temperature sensor
License: Revised BSD License, see LICENSE.TXT file include in the project
/* --- DEPENDANCIES --------------------------------------------------------- */
#include <stdint.h> /* C99 types */
#include <stdbool.h> /* bool type */
#include <stdio.h> /* printf fprintf */
#include "loragw_i2c.h"
#include "loragw_stts751.h"
/* --- PRIVATE MACROS ------------------------------------------------------- */
#define ARRAY_SIZE(a) (sizeof(a) / sizeof((a)[0]))
#if DEBUG_I2C == 1
#define DEBUG_MSG(str) fprintf(stdout, str)
#define DEBUG_PRINTF(fmt, args...) fprintf(stdout,"%s:%d: "fmt, __FUNCTION__, __LINE__, args)
#define CHECK_NULL(a) if(a==NULL){fprintf(stderr,"%s:%d: ERROR: NULL POINTER AS ARGUMENT\n", __FUNCTION__, __LINE__);return LGW_REG_ERROR;}
#else
#define CHECK_NULL(a) if(a==NULL){return LGW_REG_ERROR;}
#endif
/* --- PRIVATE CONSTANTS ---------------------------------------------------- */
#define STTS751_REG_TEMP_H 0x00
#define STTS751_REG_STATUS 0x01
#define STTS751_STATUS_TRIPT BIT(0)
#define STTS751_STATUS_TRIPL BIT(5)
#define STTS751_STATUS_TRIPH BIT(6)
#define STTS751_REG_TEMP_L 0x02
#define STTS751_REG_CONF 0x03
#define STTS751_CONF_RES_MASK 0x0C
#define STTS751_CONF_RES_SHIFT 2
#define STTS751_CONF_EVENT_DIS BIT(7)
#define STTS751_CONF_STOP BIT(6)
#define STTS751_REG_RATE 0x04
#define STTS751_REG_HLIM_H 0x05
#define STTS751_REG_HLIM_L 0x06
#define STTS751_REG_LLIM_H 0x07
#define STTS751_REG_LLIM_L 0x08
#define STTS751_REG_TLIM 0x20
#define STTS751_REG_HYST 0x21
#define STTS751_REG_SMBUS_TO 0x22
#define STTS751_REG_PROD_ID 0xFD
#define STTS751_REG_MAN_ID 0xFE
#define STTS751_REG_REV_ID 0xFF
#define STTS751_0_PROD_ID 0x00
#define STTS751_1_PROD_ID 0x01
#define ST_MAN_ID 0x53
/* --- PRIVATE VARIABLES ---------------------------------------------------- */
/* --- PRIVATE FUNCTIONS ---------------------------------------------------- */
/* --- PUBLIC FUNCTIONS DEFINITION ------------------------------------------ */
int stts751_configure(int i2c_fd, uint8_t i2c_addr) {
#if 0
int err;
uint8_t val;
/* Check Input Params */
if (i2c_fd <= 0) {
printf("ERROR: invalid I2C file descriptor\n");
return LGW_I2C_ERROR;
DEBUG_PRINTF("INFO: configuring STTS751 temperature sensor on 0x%02X...\n", i2c_addr);
/* Get product ID and test which sensor is mounted */
err = i2c_linuxdev_read(i2c_fd, i2c_addr, STTS751_REG_PROD_ID, &val);
if (err != 0) {
DEBUG_PRINTF("ERROR: failed to read I2C device 0x%02X (err=%i)\n", i2c_addr, err);
switch (val) {
case STTS751_0_PROD_ID:
DEBUG_MSG("INFO: Product ID: STTS751-0\n");
break;
case STTS751_1_PROD_ID:
DEBUG_MSG("INFO: Product ID: STTS751-1\n");
break;
default:
printf("ERROR: Product ID: UNKNOWN\n");
/* Get Manufacturer ID */
err = i2c_linuxdev_read(i2c_fd, i2c_addr, STTS751_REG_MAN_ID, &val);
if (err != 0) {
if (val != ST_MAN_ID) {
printf("ERROR: Manufacturer ID: UNKNOWN\n");
} else {
DEBUG_PRINTF("INFO: Manufacturer ID: 0x%02X\n", val);
/* Get revision number */
err = i2c_linuxdev_read(i2c_fd, i2c_addr, STTS751_REG_REV_ID, &val);
if (err != 0) {
DEBUG_PRINTF("INFO: Revision number: 0x%02X\n", val);
/* Set conversion resolution to 12 bits */
err = i2c_linuxdev_write(i2c_fd, i2c_addr, STTS751_REG_CONF, 0x8C); /* TODO: do not hardcode the whole byte */
if (err != 0) {
DEBUG_PRINTF("ERROR: failed to write I2C device 0x%02X (err=%i)\n", i2c_addr, err);
/* Set conversion rate to 1 / second */
err = i2c_linuxdev_write(i2c_fd, i2c_addr, STTS751_REG_RATE, 0x04);
if (err != 0) {
#endif
return LGW_I2C_SUCCESS;
int stts751_get_temperature(int i2c_fd, uint8_t i2c_addr, float * temperature) {
#if 0
int err;
uint8_t high_byte, low_byte;
int8_t h;
if (i2c_fd <= 0) {
/* Read Temperature LSB */
err = i2c_linuxdev_read(i2c_fd, i2c_addr, STTS751_REG_TEMP_L, &low_byte);
if (err != 0) {
printf("ERROR: failed to read I2C device 0x%02X (err=%i)\n", i2c_addr, err);
/* Read Temperature MSB */
err = i2c_linuxdev_read(i2c_fd, i2c_addr, STTS751_REG_TEMP_H, &high_byte);
if (err != 0) {
h = (int8_t)high_byte;
*temperature = ((h << 8) | low_byte) / 256.0;
#endif
*temperature = 25.0;
DEBUG_PRINTF("Temperature: %f C (h:0x%02X l:0x%02X)\n", *temperature, 0, 0);
/* --- EOF ------------------------------------------------------------------ */
