Wistrio RAK5205 not get data on TTN
(Akshay Verma) #1
Wistrio RAK 5205 broad connect to TTN but there show the status never seen. The Dev Eui is 60C5A8FFFE6D00F9. Please help me in that.
(Fomi Tong) #2
Can you tell me the detail about this issue? or some pictures to show the detail.
(Akshay Verma) #3
Hi Fomi,
Thank for the response please check attached Screenshot of TTN server. Can note get the data of broad on the TTN server.
(Fomi Tong) #4
Hi, @Alluvium_2019
Which frequency you are using?
Can you please try to use OTAA mode first?
I’ve tested RAK5205 with TTN successfully as follow:
(Akshay Verma) #5
I using 868 MHz frequency. Change it to OTAA mode please check the SS. Still not get the data. And I am using the RAK5205_Application_Note_V1.2 document for connecting to TTN.
(claudio roberto machado da rosa) #6
I have the same environment, I mean TTN with RAK5205 working fine.
One important point to pay attention it is that you need to follow the activation instructions because RAK5205 AT interface has some restrictions, if I am not wrong about APP EUI. You can´t use you automatically created by TTN Application. Follow the instruction in the manual: Application Note for
WisTrio LoRa Tracker.
Tell after about the results.
Problem to connect Raspberry Pi + RAK2245 gateway with RAK 5205 wistrio device
(wang) #7
Hi,Please refer to the newest firmware and its document:RAK5205-WisTrio-LoRa
(Akshay Verma) #8
Thanks for your suggestion. I got the data on TTN and the SS attached below. Can you please share the payload format for for thease.
(Fomi Tong) #9
Hi, @Alluvium_2019
Please check this tutorial for the payload format.
