I’m implemtening an API using the latest RUI3 firmware. So far everything works fine, but the command for setting the network mode gives no reply. According to the docs, the response should be “OK” or “AT_PARAM_ERROR”, but it seems the devices just reboots.
See the following transcript, i enabled command echos for clarity:
AT+VER=?
AT+VER=3.4.2-rui3_22q1_update.112
OK
AT+NWM=?
AT+NWM=0
OK
AT+NWM=1
RAKwireless RAK3172-E Example
Current Work Mode: LoRaWAN.
Rebooting the device should not be an issue, however, it should at least respond before that.
I just looked at the latest changelog from RUI 3.5.1 and noticed this bug was not addressed. I also tried the latest version and the issue is still there.
